Author Topic: AGFA ADC 5155 X-ray Scanner Teardown (4 part series)  (Read 160 times)
« on: November 18, 2020, 08:47:27 PM »
Part 1: AGFA ADC 5155 System teardown
Teardown of a AGFA ADC 5155 x-ray image scanner / digitizer. Also known as Computerized Radiography (CR) it fulfills the job of scanning a x-ray exposed image plate with a laser beam and extract each pixel illumination with a photo multiplier tube setup.
This particular unit has a very interesting computer that runs on VME framework developed for the Motorola 68000 series CPUs.
Coming soon, part 2: Computer teardown and reverse engineering
Coming soon, part 3: Laser scanner module teardown
Coming soon, part 4: Photomultiplier tube teardown and reverse engineering
Re: AGFA ADC 5155 X-ray Scanner Teardown (4 part series)
« Reply #1 on: November 26, 2020, 12:27:05 PM »
This is the reverse engineering and teardown of a very interesting computer that runs on VME framework developed for the Motorola 68000 series CPUs. It runs a custom operating system called Monitor 4.28 developed by Agfa-Gevaert NV, Belgium.
List of commands:
ATX = Execute ASTRX shell command
BF = Block fill
BI = Block initialize
BM = Block move
BS = Block search
BT = Block test
BR = Breakpoints (BR -* clear)
BRS = Set Breakpoints cmd string
BO = Boot from disk
CPU = Set CPU parameters
CWS = Show Clock and Wait states
DA = Display or set DATE
DCP = Disk copy from 10 to 00
DI = Disassembler
DOS = Enter DOS mode
DU = Dump sector from disk
GO = Go target
GN = Go target, break at next instr
GT = Go target, set temporary break
HE = Help
fep = Show FEP info
IOP = IO disk read and write
IOT = IO teach
JSR = Jub to subroutine
LO = Load S-records
LOG = Show OS RAM logging
MAP = Select memory map
MD = Memory display
ML = Memory display link (range) == address1,address2 or address:count
MM = Memory modify
MS = Memory set
NAM = Show symbolic name
PF = Set Port format
PRJ = Select project
RAM = RAM test
RD = Register display
RDF = Display floating point regs
RDM = Display MMU regs
RES = Reset
SC = Set Control options
ST = Start clock
-swi = Switch CPU
T = Trace next (step into JSR)
TR = Trace next (skip over JSR)
TC = Trace on change of flow
TM = Transparent mode
TI = Display & Set clock time
TE = Switch to TEST menu
US = Start user program
VE = Verify S-records
VEC = Show vectors
VIC = Show VIC & hardware
VME = VME remote control
VIX = Boot from disk
X = Execute external shell command
XT = File transfer protocol
« Last Edit: November 26, 2020, 01:04:33 PM by Mads Barnkob »
post Re: steam engine
bogdan
bogdan
bogdan
bozidar
bozidar
Max Seiringer
Jesperb123
Max Seiringer
Jesperb123
Jesperb123
