Author Topic: Complete 300 watt audio amplifier project  (Read 552 times)
« on: November 13, 2020, 01:17:41 PM »
I have designed and made available schematics, gerbers, heatsink drill patterns, and construction documentation for a 300 watt class AB BJT-based audio amplifier.   It is intended to be a complete design for educational study that also has flexible part substitution.  It can be found at the github
http://www.github.com/profdc9/PowerAmpAudio
It is a high quality amplifier you can build yourself, save some money over an expensive commercial amp, and learn how to do it in the process.   It includes the amplifier, a power conditioning PCB, a soft start PCB to limit current inrush, and an balanced (XLR) to unbalanced input.
Check out the github, there's a lot of stuff there.
Re: Complete 300 watt audio amplifier project
« Reply #1 on: November 13, 2020, 11:57:45 PM »
Thanks for sharing, and motivation to dust off Github registration here.
Reminds me of a basic audio amplifier kit from 1970's, Universal Tiger by Southwest Technical Products. Mine probably need new capacitors.  Occasionally discussed in the past decade at DIY Audio forum.
Here's a question that's more easily asked on a forum than answered by measuring.
How do amplifiers like these handle frequencies much above 20 kHz?
Would they be practical for driving 30 kHz or 60 kHz sine waves at 100 watts?
Into an 8 ohm resistive load, or an ultrasonic transducer, or a ferrite-cored high voltage transformer?
« Reply #2 on: November 15, 2020, 03:11:16 AM »
Generally they will drive frequencies up to about 100 kHz into 8 ohms with increased distortion.  The amplifier uses the high open loop gain to minimize distortion and this is reduced at higher frequencies.  Capacitive loads can definitely destabilize the feedback, and many ultrasonic devices are capacitive.  Some combination of resistance/inductance network is usually used to limit the current through capacitive loads.  Inductive loads are less of a problem but of course high inductance means that the effective load impedance is increased at high frequencies (and current is less).
With the ON Semi transistors with 30 MHz fT and good SOA (MJL1302/MJL3281), you can drive hundreds of watts using 4 NPN/PNP pairs so 100 watts should be no problem.
Today at 03:51:26 AM
Today at 01:27:18 AM
Today at 01:19:19 AM
SimonNwardUK
April 22, 2021, 10:36:43 PM
April 22, 2021, 06:52:48 PM
April 22, 2021, 01:20:02 PM
post Re: Corona discharge
April 22, 2021, 12:57:35 PM
April 22, 2021, 10:59:28 AM
April 22, 2021, 05:56:48 AM
April 22, 2021, 05:38:10 AM
post Re: UD2.7 Thru Hole
April 22, 2021, 02:41:13 AM
April 22, 2021, 02:41:08 AM
April 21, 2021, 09:18:14 PM
April 21, 2021, 08:38:20 PM
April 21, 2021, 08:15:13 PM
April 21, 2021, 08:08:15 PM
April 21, 2021, 07:59:41 PM
April 21, 2021, 07:40:40 PM
April 21, 2021, 04:29:42 PM
April 21, 2021, 06:12:33 AM
post UD2.7 Thru Hole
April 21, 2021, 03:52:44 AM
post Corona discharge
April 21, 2021, 12:16:22 AM
Vdekje
April 20, 2021, 10:48:45 PM
Vdekje
April 20, 2021, 10:33:53 PM
April 20, 2021, 07:32:37 PM
April 20, 2021, 07:29:04 PM
April 20, 2021, 07:25:30 PM
April 20, 2021, 06:55:36 PM
April 20, 2021, 06:48:29 PM
April 20, 2021, 03:42:58 PM
mrsebe
April 20, 2021, 01:54:01 PM
April 20, 2021, 04:53:09 AM
April 20, 2021, 02:32:21 AM
April 20, 2021, 02:28:12 AM
April 20, 2021, 12:20:45 AM
April 19, 2021, 09:59:08 PM
April 19, 2021, 09:35:16 PM
April 19, 2021, 08:48:07 PM
April 19, 2021, 05:03:29 PM
post Intensifying screen
Merces
April 19, 2021, 04:45:03 PM
mrsebe
April 19, 2021, 04:36:43 PM
post Whoohoooooo
April 19, 2021, 12:29:03 PM
hashtala
April 19, 2021, 10:02:46 AM
April 19, 2021, 06:04:03 AM
April 19, 2021, 02:48:40 AM
April 18, 2021, 08:04:18 PM
April 18, 2021, 07:10:24 PM
April 18, 2021, 01:11:28 PM
iw1esu
April 18, 2021, 12:26:48 PM
April 18, 2021, 02:36:34 AM
