Author Topic: Arduino interrupter  (Read 529 times)
Offline octopus1
Arduino interrupter
« on: November 09, 2020, 03:19:14 PM »
Hello! I am almost done with my arduino interrupter (photos soon). It has two modes, pwm and music. it can create a pwm signal with a adjustable duty cycle of 3% to 10% and frequencies from htz to 100htz. the midi mode samples a music input, looks for peaks and pitch in the music and generators a pwm signal. it transmits this signal over a industrial fiber optic transmitter. Any suggestions would be appreciated!
Offline acobaugh
Re: Arduino interrupter
« Reply #1 on: November 10, 2020, 03:25:28 AM »
I'd be interested in this once you have a wiring diagram and code to share. I started down the path of building one last year, but never completed it.
Offline Zipdox
    • Zipdox
« Reply #2 on: November 10, 2020, 01:11:18 PM »
I think the code is more interesting than the hardware.
Offline octopus1
« Reply #3 on: November 10, 2020, 07:36:25 PM »
as promised heres a small video and the code
(secondary coil in the background  :) )
green light is just a visual
red light is the end of the fiber
playing music off youtube
it doesn't look like a square wave on the scope but it is!
both visual green led and transmitter are on pin 12, anolog in from my computers audio jack is pin A0.
Im using a ife96e transmitter
boolean clipping = 0;
//storage variables
byte newData = 0;
byte prevData = 0;
void setup(){
  pinMode(13,OUTPUT);//led indicator pin
  pinMode(12,OUTPUT);//slope indicator
  cli();
  //set up continuous sampling of analog pin 0
  ADCSRA = 0;
  ADCSRB = 0;
  ADMUX |= (1 << REFS0);
  ADMUX |= (1 << ADLAR);
  ADCSRA |= (1 << ADPS2) | (1 << ADPS0);
  ADCSRA |= (1 << ADATE);
  ADCSRA |= (1 << ADIE);
  ADCSRA |= (1 << ADEN);
  ADCSRA |= (1 << ADSC);
  sei();//enable interrupts
ISR(ADC_vect) {
  prevData = newData;
  newData = ADCH;
  if (newData > prevData){
    PORTB |= B00010000;
  else if (newData < prevData){
    PORTB &= B11101111;
  if (newData == 0 || newData == 1023){
    PORTB |= B00100000;
    clipping = 1;
void loop(){
  if (clipping){
    PORTB &= B11011111;
    clipping = 0;
  delay(100);
Offline Max
    • My Youtube Channel
« Reply #4 on: November 11, 2020, 12:22:32 AM »
I'd love to see the video. Unfortunately there's none as far as I can see...  ???
What surprises me a bit is that the unfiltered differentiation results in meaningful ontimes. I'd expect a very very "noisy" signal. Or in more appropriate terms for a digital signal: I'd expect it to jump permanently between low and high - in average it should equal to the actual derivative of the input signal. This is probably fine for an SSTC but if it actually looks like what I described it's not suited for DRSSTCs.
Another issue - again more for DRSSTCs than SSTCs: you have no control over the duty cycle. In theory the derivative should be DC-free, which means as much as your signal should be exactly 50% duty cycle.
Considering those limitations I wonder what are the advantages and disadvantages of this solution compared to a (simpler?) "analog-to-pwm interrupter" - which again should work fine for SSTCs but not for DRSSTCs.
Small but important note about the code: global variables that are used inside the ISR must be declared as "volatile". Because the compiler can't know when the ISR is called it can't know when it is safe to use the cached variable and when it should (re)load it from memory. "volatile" tells the compiler to always assume it got changed since the last access (which is exactly what an ISR causes: unpredictable changes at any moment) and the compiler will always load it properly from memory. For simple programs and with no optimization active it may work without this but you really don't want to rely on that.
I don't know if it's visible in reality but as far as I can tell the clipping LED won't blink the same every time. since the delay in your loop is independant of the clipping detection the LED will actually be on for any random amount of time between 0 and 100ms. Reason: the interrupt that sets "clipping" to "true" can happen at any time within the "delay(100)". The LED will be on for the - random - remaining time only. If you want the LED to be on for exactly 100ms, put the delay(100) at the beginning of your if, before you turn the pin off. What's the effect? When - and only when - clipping is detected (LED is on) the delay starts. So every time clipping occurs a "fresh" delay will start and you'll always get a 100ms blink.
Kind regards,
Offline octopus1
« Reply #5 on: November 11, 2020, 04:57:29 AM »
shoot i kinda just pushed all of that out of my mind lol, back to the draw.. coding board.
Offline octopus1
« Reply #6 on: November 12, 2020, 04:31:03 AM »
okay new code, but my 1$ ardiuno kind exploded, so ill post the code when i can test it. it has pw control and actual midi shit (mostly stolen from the 4hv post)
Offline Max
« Reply #7 on: November 14, 2020, 10:09:22 PM »
Arduino exploded?! How did you manage that?  :o
TBH I feel a little bad. While I was sceptical about your initial code I really hoped this would evolve into a usable (and controllable) audio interrupter. By now there're a couple MIDI interrupters available - all with different pros and cons, but there aren't many audio interrupters at all. That made your initial project so exciting IMO and the last thing I wanted is to stop you from making improvements.
Another reason why this interested me is that eventually I want to implement an audio interrupter mode on my Syntherrupter.
Nonetheless I'm looking forward to seeing your results! :)
Kind regards,
Offline octopus1
« Reply #8 on: November 16, 2020, 08:53:03 PM »
hello! new arduino arrived today (got another 1$ one lol) gonna work on writing some more code and then i should be done. trying to make this as simple as possible (no external components, just a arduino, fiber, and audio jack) to make it more useable for beginners. the one that i tied form the 4hv post didn't work in the slightest lol. dont know why im getting .05v output instead of 5v, that really my only problem right now, gonna need to find a way to internal amplify the signal from the audio jack (because i managed to step on and kill my last op amp and also becuase i hate tiny ics and have no breadboard)
      reagards, octopus
panjaksli
panjaksli
panjaksli
panjaksli
buchtawill
panjaksli
panjaksli
Genterman
post Re: DRSSTC trouble
buchtawill
NOOBPASTE51
Genterman
buchtawill
post DRSSTC trouble
buchtawill
