Author Topic: ud2.7 list of components so other's dont have to struggle like i did  (Read 461 times)
Offline octopus1
Here is a full digikey shopping cart containing all the components needed to assemble a ud2.7c. to cut costs I went with the industrial fiber optics receiver. (note that to save even more cost you can omit the fiber cable and transmitter I simply needed them for my project). the only things missing from this cart are the variable inductors (coil craft is the best place) and pcb, as well as two of the power mosfets and one mosfet driver (I did not need both gdt outputs).
finished component cart without the fiber cable and transmitter is just 34$
https://www.digikey.com/short/zd5r1j
regards
Offline acobaugh
Re: ud2.7 list of components so other's dont have to struggle like i did
« Reply #1 on: November 03, 2020, 10:51:46 PM »
Just my $.02, tt would be super helpful for others if you included component references as well. I found this extremely helpful during assembly. Just went through one baggie at a time until the board was put together without having to do a ton of cross references and risk messing something up.
Offline octopus1
« Reply #2 on: November 03, 2020, 11:54:02 PM »
oh wait is that what the costumer reference is?
Offline TMaxElectronics
« Reply #3 on: November 04, 2020, 12:06:49 AM »
You can sometimes find very good deals for the HFBR optical hardware on ebay. I recently found some for less than 2€ a piece. New old stock, but I haven't had issues with them so far.
Offline octopus1
« Reply #4 on: November 04, 2020, 12:26:55 AM »
I actually prefer the industrial fiber ones. since i'm using a arduino for my interrupter ease of connection is nice.
new cart with reference numbers
https://www.digikey.com/short/zd5dmb
Offline acobaugh
« Reply #5 on: November 04, 2020, 12:39:18 AM »
Yessir! I use it because I often put in orders before I need the parts, then sometimes forget what I was going to use each part for when digging through parts weeks or months later.
Offline octopus1
« Reply #6 on: November 04, 2020, 12:44:19 AM »
thanks for the tip its gonna make soldering so much easier! i also may have caught a small error...
Offline octopus1
« Reply #7 on: November 09, 2020, 03:20:14 PM »
update: components all arrived, everything seems to be right!
Offline octopus1
« Reply #8 on: November 16, 2020, 08:54:21 PM »
update, 90% of the components are soldered, digikey messed up my order and rounded everything over 10 to 10 so they are resending the missing components. Should be done in the next week or so!
« Reply #9 on: November 18, 2020, 12:18:57 AM »
I have a BOM in my UD2.7 build
https://github.com/profdc9/DRSSTC-PCB-Pack/blob/master/ud27c%20thru%20hole/ud27c%20BOM.pdf
which is the overall project
which you can download a ZIP file of.
Offline octopus1
« Reply #10 on: November 18, 2020, 02:07:15 PM »
welp, i would have much rather done a thru hole version. Thanks if this one doesn't work i will just wait a bit till i can restock the hobby fund and try.
regards,
« Reply #11 on: November 18, 2020, 04:32:37 PM »
I have a version called ud29 which also provides pulse skip for basically nothing additional (one transistor)
https://github.com/profdc9/DRSSTC-PCB-Pack/tree/master/ud29
regards,
Offline octopus1
« Reply #12 on: November 19, 2020, 04:26:39 AM »
I am seriously regretting not asking around on here lol, thanks again!
panjaksli
panjaksli
panjaksli
panjaksli
buchtawill
panjaksli
panjaksli
Genterman
post Re: DRSSTC trouble
buchtawill
NOOBPASTE51
Genterman
buchtawill
post DRSSTC trouble
buchtawill
