Author Topic: Slayer exciter circuit troubleshoot.  (Read 321 times)
Offline shifatsrm09
« on: November 03, 2020, 07:28:35 AM »
I just follow the circuit diagram as shown in the attached image.I use 5 TIP31C transistor in parallel and 20v 10A power supply to power up the circuit but it isnt working i connect the 47k 3watt resistor to my circuit. i change the polarity of primary coil tried everything. after that i check my transistor all are working condition. so i measure the current flow of this circuit as my surprise the current is 0.01. What should i do now? should i change the resistor to low value wat resistor ar the resistance?
Re: Slayer exciter circuit troubleshoot.
« Reply #1 on: November 03, 2020, 09:11:49 AM »
You see other people's successful circuits, but don't really copy them.
You start with substitutions like different wattage ballast, or power supply instead of 9V battery,
or put 5 bipolar transistors in parallel, or use wires of different thickness or length or insulation color than original circuit.
You need to develop better judgement about which changes matter and which ones don't.
The path to success is to learn more about how the circuits work, instead of making pictorial schematics.  It is not a good sign when you identify transistor pins by physical order (left, middle, right) instead of their internal functions.  Some people here got past that stage before they were 12 years old, even with no Internet as a tool for learning.
Offline shifatsrm09
« Reply #2 on: November 04, 2020, 07:31:23 AM »
i dont really understand u.I am not good at english cz im bangladeshi
Offline Zipdox
    • Zipdox
« Reply #3 on: November 04, 2020, 02:10:58 PM »
I'm afraid  the language barrier will be a problem if you want to achieve success.
Offline shifatsrm09
« Reply #4 on: November 05, 2020, 07:19:43 AM »
now this circuit start working i just follow the syscamatic of electro boom slayer exciter circuit . but i use tip31c instead of 2n222 cz its high voltage rated and fast switching speed.and also i use 1n4142 zener diode.the circuit work nicely! can u guys tell me can i use irfp 460 instead of tip31c and powerup the circuit with higher voltage like 100v,220v,350v
zytra
Today at 05:00:50 AM
Today at 04:03:12 AM
Today at 03:07:11 AM
zytra
Today at 02:57:27 AM
Today at 12:06:44 AM
January 18, 2021, 11:56:31 PM
Alberto
January 18, 2021, 11:50:22 PM
January 18, 2021, 10:30:15 PM
zytra
January 18, 2021, 10:03:46 PM
January 18, 2021, 09:58:44 PM
zytra
January 18, 2021, 08:52:29 PM
January 18, 2021, 07:08:09 PM
January 18, 2021, 06:49:28 PM
January 18, 2021, 06:12:44 PM
January 18, 2021, 04:53:23 PM
arto
January 18, 2021, 11:54:54 AM
zytra
January 18, 2021, 08:27:18 AM
Acid Byte
January 18, 2021, 06:57:06 AM
January 18, 2021, 06:43:19 AM
zytra
January 18, 2021, 05:48:27 AM
January 18, 2021, 01:03:48 AM
Alberto
January 18, 2021, 12:26:26 AM
January 17, 2021, 11:29:04 PM
Alberto
January 17, 2021, 09:55:24 PM
zytra
January 17, 2021, 09:34:21 PM
January 17, 2021, 08:51:50 PM
January 17, 2021, 08:04:54 PM
tophat
January 17, 2021, 05:40:59 PM
January 17, 2021, 05:12:45 PM
January 17, 2021, 02:20:09 PM
zytra
January 17, 2021, 05:56:05 AM
zytra
January 17, 2021, 05:55:11 AM
January 17, 2021, 03:50:27 AM
January 17, 2021, 03:37:28 AM
zytra
January 17, 2021, 01:48:10 AM
Alberto
January 16, 2021, 11:21:13 PM
January 16, 2021, 10:09:21 PM
January 16, 2021, 09:38:08 PM
January 16, 2021, 09:27:25 PM
January 16, 2021, 09:05:23 PM
January 16, 2021, 07:44:41 PM
January 16, 2021, 07:06:13 PM
January 16, 2021, 06:48:05 PM
January 16, 2021, 06:38:11 PM
January 16, 2021, 06:23:53 PM
January 16, 2021, 06:23:10 PM
January 16, 2021, 03:28:14 PM
January 16, 2021, 05:09:53 AM
January 16, 2021, 05:00:46 AM
January 16, 2021, 04:56:31 AM
