Author Topic: SSTC with ballast blew my IRFP460  (Read 347 times)
Offline shifatsrm09
« on: October 29, 2020, 05:18:27 PM »
IM trying to make tesla coil driver with irfp460. I make my circuit like shown in the syscamatic . first things is that for the first attempt I used 1mm thick wire for primary coil then i see that my both ballast get extreamly heated up and also the heatsink attached to the IRFP460 although it was working it throw very very tiny arc from the topload and can light up a normal cfl bulb.
than i go for 3.6mm wire for my primary winding and attached everything as same as before and syscamatic. This time the arc can jump upto 2 inch far away but whithing 20 second my mosfet shorted or blew up i didnt guess it but it dead for sure.
Can anyone help me with this issue or modify my syscamatic so it willme more efficient and work without blowing .
Online klugesmith
Re: SSTC with ballast blew my IRFP460
« Reply #1 on: October 30, 2020, 06:03:19 PM »
Why is there a diode in series with 230-volt inductive ballasts?
How will the ballasts limit current, even the AC component, when DC current saturates their cores?
When your next MOSFET is on the sacrificial altar,
can you measure the DC current in mains circuit?
« Last Edit: October 30, 2020, 06:05:01 PM by klugesmith »
Offline shifatsrm09
« Reply #2 on: October 31, 2020, 06:59:41 AM »
How can i rearrange the circuit or modify this i dont know how its working i just want to replicate someone else syscamatics . i measure 110v dc after the diode so maybe the mosfet resonate the certain frequancy so there are a high voltage on the secondary maybe im not sure.
can u pls modify the circuit or give me a good suggetion how can i make the tesla coil work
« Reply #3 on: November 01, 2020, 02:13:32 AM »
Most such simple circuits work only at low voltage and low power.  Occasionally someone gets luck enough to get somewhat higher power before parts fry.  The MOSFET has no protection from excess gate voltage nor from excess drain voltage.  It's likely seeing excess voltage on both pins.
Look through the SSTC thread on this forum for circuit ideas, and at some of the other web sites linked such as Mads' KaiserPowerElectronics etc.  Most circuits that function reliably have more parts.
post Re: Just a noob with some HV concerns...
Today at 07:04:16 AM
zytra
Today at 06:37:53 AM
Today at 06:16:41 AM
zytra
Today at 05:00:50 AM
Today at 04:03:12 AM
Today at 03:07:11 AM
zytra
Today at 02:57:27 AM
Today at 12:06:44 AM
January 18, 2021, 11:56:31 PM
Alberto
January 18, 2021, 11:50:22 PM
January 18, 2021, 10:30:15 PM
zytra
January 18, 2021, 10:03:46 PM
January 18, 2021, 09:58:44 PM
zytra
January 18, 2021, 08:52:29 PM
January 18, 2021, 07:08:09 PM
January 18, 2021, 06:49:28 PM
January 18, 2021, 06:12:44 PM
January 18, 2021, 04:53:23 PM
arto
January 18, 2021, 11:54:54 AM
zytra
January 18, 2021, 08:27:18 AM
Acid Byte
January 18, 2021, 06:57:06 AM
January 18, 2021, 06:43:19 AM
zytra
January 18, 2021, 05:48:27 AM
January 18, 2021, 01:03:48 AM
Alberto
January 18, 2021, 12:26:26 AM
January 17, 2021, 11:29:04 PM
Alberto
January 17, 2021, 09:55:24 PM
zytra
January 17, 2021, 09:34:21 PM
January 17, 2021, 08:51:50 PM
January 17, 2021, 08:04:54 PM
tophat
January 17, 2021, 05:40:59 PM
January 17, 2021, 05:12:45 PM
January 17, 2021, 02:20:09 PM
zytra
January 17, 2021, 05:56:05 AM
zytra
January 17, 2021, 05:55:11 AM
January 17, 2021, 03:50:27 AM
January 17, 2021, 03:37:28 AM
zytra
January 17, 2021, 01:48:10 AM
Alberto
January 16, 2021, 11:21:13 PM
January 16, 2021, 10:09:21 PM
January 16, 2021, 09:38:08 PM
January 16, 2021, 09:27:25 PM
January 16, 2021, 09:05:23 PM
January 16, 2021, 07:44:41 PM
January 16, 2021, 07:06:13 PM
January 16, 2021, 06:48:05 PM
January 16, 2021, 06:38:11 PM
January 16, 2021, 06:23:53 PM
January 16, 2021, 06:23:10 PM
January 16, 2021, 03:28:14 PM
