Author Topic: SSTC with a ballast circuit not working  (Read 239 times)
Offline shifatsrm09
« on: October 29, 2020, 03:01:26 AM »
Im trying to make a tesla coil from 2016. After many failures i stopped trying stuffs.But now i discoverd that tesla coil can be made by many other ways.I follow the systematics i attached. I blew up almost 6 IRFP460 mosfet. but it didnt even work not a single spark.Plz guys i want your help
Component I use:
Diode UF5408
1 MKP 250v capacitor
12k 2watt Resistor
12v 1w zener diode
10k potentiometer
5 turn with 3.6mm thick copper wire insulated
1200 turn in secondary
and i use 2*40w ballast as parallel
everything attached together same as syscamatics
Can anyone help how it will work!
it will be great pleasure
« Last Edit: October 29, 2020, 06:52:11 AM by shifatsrm09 »
Offline Zipdox
    • Zipdox
Re: SSTC with a ballast circuit not working
« Reply #1 on: October 29, 2020, 01:40:07 PM »
A slayer exciter at mains voltage? Are you mad?
Offline shifatsrm09
« Reply #2 on: October 29, 2020, 03:41:26 PM »
but i use a ballast to limit the current
« Reply #3 on: October 29, 2020, 04:31:06 PM »
>>but i use a ballast to limit the current.
What is the current limit, in amperes?  Do you think it's enough to break something if it goes through a MOSFET the wrong way?
The silly pictorial schematic is inadequate in several ways.
First, it suggests that all you need is "everything attached together" to match the diagram.
This is not like wiring a lamp to your ballast.
At high frequency, the physical length of the wires matters, and the connection topology of nets with more than two nodes.
Can we see a picture of your actual IRFP-destroying circuit?  And a link to the working SSTC that the diagram came from?
Second, the images don't match the annotation, even if we ignore obvious differences in scale.
Should the capacitor and resistor values match the pictures or match the words?
The TO-220 device picture doesn't appear to say IRF, and we can barely tell whether the view is front side or back side.  How can readers interpret the circuit without seeing the pin names?  You could take a step forward by looking up the pin names (drain, gate, source?). Please add them to the diagram for us.
« Last Edit: October 29, 2020, 04:42:45 PM by klugesmith »
Offline shifatsrm09
« Reply #4 on: October 29, 2020, 04:48:49 PM »
I was trying to replicate the circuit from this guy . and I blew my another irfp460 but this time its work a little bit i tell it briefly on my another post which i will post in a while
Offline Zipdox
    • Zipdox
« Reply #5 on: November 02, 2020, 08:22:43 PM »
The level of jankyness in that video makes it look fake if I'm completely honest with you.
Offline shifatsrm09
« Reply #6 on: November 03, 2020, 02:52:45 AM »
I leave this circuit its shitty use 220vac.
Today at 07:13:17 PM
Today at 05:21:28 PM
Today at 11:26:39 AM
Jesperb123
Today at 10:45:43 AM
Today at 01:56:06 AM
Max Seiringer
Jesperb123
Jesperb123
Jesperb123
Jesperb123
post Quad NST Mushroom Tesla coil!
November 22, 2020, 04:28:06 PM
November 22, 2020, 01:59:27 PM
post Peak Primary current in small DRSSTC
Jesperb123
November 22, 2020, 12:10:39 PM
bogdan
November 22, 2020, 09:43:41 AM
post Re: steam engine
November 22, 2020, 05:00:19 AM
November 22, 2020, 03:34:36 AM
post Simple H-Bridge construction with low parasitic inductances (for SSTC or ...)
November 22, 2020, 02:47:03 AM
November 22, 2020, 12:02:41 AM
post Re: How to connect parallel AC flybacks
November 21, 2020, 11:45:11 PM
post How to connect parallel AC flybacks
November 21, 2020, 09:50:28 PM
post Re: Is this this mini circuit goin to work ? (small DRSSTC)
hashtala
November 21, 2020, 08:50:00 PM
November 21, 2020, 08:36:42 PM
November 21, 2020, 08:09:25 PM
post Analog HFBR amplifier
November 21, 2020, 08:08:47 PM
November 21, 2020, 08:04:06 PM
November 21, 2020, 07:53:00 PM
hashtala
November 21, 2020, 07:47:13 PM
hashtala
November 21, 2020, 07:11:09 PM
Intra
November 21, 2020, 06:48:00 PM
