Author Topic: Voltage tripler for my medium DRSSTC  (Read 235 times)
Offline octopus1
« on: September 29, 2020, 02:40:28 PM »
So i ordered three large 400v electrolytic caps (6000uf 400v) in the hope to make a voltage tripler. In my current situation i realized that the only have access to 110v 20a service. So my plan is to use a voltage tripler to get 300v on my bridge. My question is if 4 10A10 diodes in parallel for each stage would be sufficient.
Re: Voltage tripler for my medium DRSSTC
« Reply #1 on: September 29, 2020, 05:23:17 PM »
I would think hard about the maths and the operation of the circuit before trying to build a tripler - for starters you'd get ~300VDC just from a doubler running on 110VAC due to the rectifier effectively peak-detecting the AC waveform.
« Reply #2 on: September 29, 2020, 07:23:27 PM »
Yes, what Hydron said.  Could use the doubler topology with no series capacitors.  One bulk capacitor for +150 V rail and another for the -150 V rail.  Then figure the RMS current at AC input and in the rectifier diodes, for a given DC output current.
Last time I did that personally was for a stroboscope using a xenon flashlamp.
Offline octopus1
« Reply #3 on: September 29, 2020, 08:52:12 PM »
okay thanks, this really helps. so your saying a doubler would be sufficient, but would the diodes work?
« Reply #4 on: September 30, 2020, 05:32:12 AM »
Yes, four parallel 10A10 diodes should be plenty.  Two should be enough if you have short leads to reasonable-sized copper shapes on your ECB or other connection method.  (Most of the diode's heat is dissipated through its leads.)  And, I agree that a doubler is likely what you want, as that gives twice the peak voltage (at no load), or 2 * sqrt(2) * 110V = 311V.  You could add the third capacitor across the doubler output to handle higher peak currents from the bridge.
Offline Teravolt
« Reply #5 on: September 30, 2020, 06:25:16 PM »
If I were you I would find a 600v to 1000v 35A bridge rectifier on ebay or a online surplus electoninics store for 3$ each. it is a lot more simpler and reliable
Daniel Uhrenholt
Today at 09:41:48 AM
Today at 01:46:20 AM
October 24, 2020, 11:12:37 PM
Daniel Uhrenholt
October 24, 2020, 11:07:33 PM
Daniel Uhrenholt
October 24, 2020, 10:45:41 PM
Daniel Uhrenholt
October 24, 2020, 10:12:37 PM
October 24, 2020, 09:29:06 PM
October 24, 2020, 09:20:37 PM
October 24, 2020, 09:07:24 PM
post Re: Software for playing MIDIs
October 24, 2020, 07:29:57 PM
October 24, 2020, 07:02:13 PM
Daniel Uhrenholt
October 24, 2020, 06:38:42 PM
October 24, 2020, 05:42:49 PM
post Software for playing MIDIs
October 24, 2020, 04:37:26 PM
Daniel Uhrenholt
October 24, 2020, 03:51:52 PM
October 24, 2020, 02:25:00 PM
Daniel Uhrenholt
October 24, 2020, 12:12:41 PM
post MOVED: DIY current transformer for scoping primary current?
Kizmo
October 24, 2020, 11:45:58 AM
post DIY current transformer for measuring primary current?
Daniel Uhrenholt
October 24, 2020, 11:22:24 AM
October 24, 2020, 04:16:06 AM
October 24, 2020, 04:07:24 AM
October 23, 2020, 11:39:35 PM
October 23, 2020, 07:10:22 PM
October 23, 2020, 05:36:02 PM
October 23, 2020, 05:34:39 PM
post MOVED: Ping pong (and pumpkin?) cannons - split from ferrite-core QCW topic
October 23, 2020, 05:27:45 PM
October 23, 2020, 03:03:28 PM
post Re: RC snubbers
October 23, 2020, 12:27:42 AM
October 22, 2020, 10:06:59 PM
October 22, 2020, 09:05:22 PM
October 22, 2020, 07:17:16 PM
October 22, 2020, 05:33:39 PM
October 22, 2020, 02:07:27 PM
post RC snubbers
October 22, 2020, 11:42:26 AM
SAMGO
October 22, 2020, 11:21:19 AM
October 22, 2020, 09:14:24 AM
October 22, 2020, 06:19:28 AM
October 22, 2020, 04:21:50 AM
October 22, 2020, 01:23:15 AM
October 21, 2020, 08:31:51 PM
October 21, 2020, 08:21:55 PM
October 21, 2020, 07:17:07 PM
SalinsLV
October 21, 2020, 01:30:19 PM
October 21, 2020, 05:00:34 AM
October 21, 2020, 04:46:55 AM
October 21, 2020, 04:42:19 AM
October 21, 2020, 02:29:54 AM
October 20, 2020, 11:50:25 PM
SAMGO
October 20, 2020, 10:50:25 PM
October 20, 2020, 09:38:42 PM
