Author Topic: Voltage tripler for my medium DRSSTC  (Read 642 times)
  • Guest
« on: September 29, 2020, 02:40:28 PM »
So i ordered three large 400v electrolytic caps (6000uf 400v) in the hope to make a voltage tripler. In my current situation i realized that the only have access to 110v 20a service. So my plan is to use a voltage tripler to get 300v on my bridge. My question is if 4 10A10 diodes in parallel for each stage would be sufficient.
Re: Voltage tripler for my medium DRSSTC
« Reply #1 on: September 29, 2020, 05:23:17 PM »
I would think hard about the maths and the operation of the circuit before trying to build a tripler - for starters you'd get ~300VDC just from a doubler running on 110VAC due to the rectifier effectively peak-detecting the AC waveform.
« Reply #2 on: September 29, 2020, 07:23:27 PM »
Yes, what Hydron said.  Could use the doubler topology with no series capacitors.  One bulk capacitor for +150 V rail and another for the -150 V rail.  Then figure the RMS current at AC input and in the rectifier diodes, for a given DC output current.
Last time I did that personally was for a stroboscope using a xenon flashlamp.
  • Guest
« Reply #3 on: September 29, 2020, 08:52:12 PM »
okay thanks, this really helps. so your saying a doubler would be sufficient, but would the diodes work?
« Reply #4 on: September 30, 2020, 05:32:12 AM »
Yes, four parallel 10A10 diodes should be plenty.  Two should be enough if you have short leads to reasonable-sized copper shapes on your ECB or other connection method.  (Most of the diode's heat is dissipated through its leads.)  And, I agree that a doubler is likely what you want, as that gives twice the peak voltage (at no load), or 2 * sqrt(2) * 110V = 311V.  You could add the third capacitor across the doubler output to handle higher peak currents from the bridge.
« Reply #5 on: September 30, 2020, 06:25:16 PM »
If I were you I would find a 600v to 1000v 35A bridge rectifier on ebay or a online surplus electoninics store for 3$ each. it is a lot more simpler and reliable
Today at 05:16:39 AM
Today at 03:38:23 AM
post Re: Grounding VTTC
July 28, 2021, 08:31:50 PM
July 28, 2021, 08:07:10 PM
post Re: Tesla Coil Music
July 28, 2021, 05:17:06 PM
July 28, 2021, 05:15:48 PM
post Tesla Coil Music
Transgarp
July 28, 2021, 02:12:35 PM
July 28, 2021, 01:39:46 AM
ResonantEMF
July 28, 2021, 01:02:30 AM
July 27, 2021, 11:26:15 PM
July 27, 2021, 11:10:19 PM
ResonantEMF
July 27, 2021, 09:12:05 PM
July 27, 2021, 08:47:49 PM
July 27, 2021, 08:45:26 PM
ResonantEMF
July 27, 2021, 07:38:47 PM
July 27, 2021, 07:12:06 PM
July 27, 2021, 06:48:04 PM
July 27, 2021, 05:27:50 PM
post Grounding VTTC
July 27, 2021, 05:14:34 PM
Felix B.
July 27, 2021, 04:58:46 PM
July 27, 2021, 04:36:37 PM
ResonantEMF
July 27, 2021, 09:14:01 AM
July 27, 2021, 06:19:19 AM
July 27, 2021, 02:50:30 AM
July 26, 2021, 10:13:23 PM
July 26, 2021, 03:04:47 PM
July 26, 2021, 02:42:57 PM
July 26, 2021, 12:37:52 PM
July 26, 2021, 12:21:54 PM
July 26, 2021, 10:47:22 AM
July 26, 2021, 10:15:43 AM
July 26, 2021, 06:37:46 AM
July 26, 2021, 04:25:03 AM
Power-Max
July 26, 2021, 03:29:32 AM
July 26, 2021, 02:18:39 AM
July 26, 2021, 01:23:42 AM
July 26, 2021, 12:58:41 AM
July 25, 2021, 10:15:30 PM
July 25, 2021, 06:16:53 PM
Chrisader
July 25, 2021, 04:16:11 PM
July 25, 2021, 05:38:42 AM
July 25, 2021, 02:15:25 AM
July 24, 2021, 11:38:33 PM
July 24, 2021, 11:29:15 PM
July 24, 2021, 10:41:38 PM
July 24, 2021, 09:18:42 PM
July 24, 2021, 08:08:36 PM
July 24, 2021, 11:13:18 AM
July 24, 2021, 10:08:34 AM
July 24, 2021, 03:20:42 AM
