Author Topic: Polyphonic Interrupter with STM32F103C8T6 (Bluepill)  (Read 450 times)
Offline Zipdox
    • Zipdox
« on: September 27, 2020, 11:43:14 PM »
I wrote a polyphonic interrupter for the Bluepill.
It uses the STM32duino core for programming.
Here's the code:
Code: (c) [Select]
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#define sampling_rate 96000
#define max_playing_notes 8
float note_numerator = sampling_rate/440.0;
int notePeriod(float pitch){
    return note_numerator/pow(2, (pitch-69)/12.0);
typedef struct {
    byte pitch;
    int on_time;
    int off_time;
    int been_on;
} Note;
Note playing_notes[max_playing_notes];
void handleNoteOn(byte channel, byte pitch, byte velocity){
    for(int i = 0; i < max_playing_notes; i++){
        if(playing_notes[i].on_time == 0){
            int period = notePeriod(pitch);
            playing_notes[i] = {pitch, 10, period-10, 0};
            break;
    digitalWrite(LED_BUILTIN, LOW);
void handleNoteOff(byte channel, byte pitch, byte velocity){
        if(playing_notes[i].pitch == pitch) playing_notes[i].on_time = 0;
    digitalWrite(LED_BUILTIN, HIGH);
void sample(void){
        if(playing_notes[i].on_time != 0) playing_notes[i].been_on++;
void setup()
    pinMode(PB9, OUTPUT);
    digitalWrite(PB9, LOW);
    pinMode(LED_BUILTIN, OUTPUT);
    for(int i = 0; i<(sizeof(playing_notes)/sizeof(playing_notes[0])); i++){
        playing_notes[i] = {0,0,0,0};
    MIDI.setHandleNoteOn(handleNoteOn);
    MIDI.setHandleNoteOff(handleNoteOff);
    MIDI.begin(MIDI_CHANNEL_OMNI);
    HardwareTimer *MyTim = new HardwareTimer(TIM2);
    MyTim->setOverflow(sampling_rate, HERTZ_FORMAT);
    MyTim->attachInterrupt(sample);
    MyTim->resume();
void loop()
    MIDI.read();
    bool play = false;
        if(playing_notes[i].on_time == 0) continue;
        if(playing_notes[i].been_on > playing_notes[i].on_time) playing_notes[i].been_on = -playing_notes[i].off_time;
        if(playing_notes[i].been_on >= 0) play = true;
    if(play){
        digitalWrite(PB9, HIGH);
    }else{
License: GPL-3
Offline TMaxElectronics
Re: Polyphonic Interrupter with STM32F103C8T6 (Bluepill)
« Reply #1 on: September 28, 2020, 01:14:46 AM »
Cool project :D quite a bit simpler that either my MidiStick or max's synthterrupter
a few things I noticed though:
It seems to me like you don't take velocity or volume into account, since that should be a simple addition I highly recommend it, especially if you have many voices. Sometimes a song gets unexpectedly intense with the amount of notes playing at a given time, and with your code you can't really do much about it once the code is uploaded. Since you don't have adsr all you need to add is maybe a macro for the maximum ontime and then use the MIDI_VOLUME command to scale a variable from 0 to the max from the macro, which is then used as the on-time setting for the notes.
It also doesn't seem like you have any duty limiting, which is a very risky thing with a 8-voice polyphonic interrupter. If you play many high notes (or even many low ones) the duty cycle could get very high, putting a lot of thermal stress onto your IGBTs. The way I'd recommend to do this is to just add all the on-times of active notes together whenever a note event (either on or off) occurs, and if that total on-time is too much you scale back all notes by the amount by which the total value is too large. My interrupter uses a different approach that is quite complex and not really needed here. Here is how the synthterrupter does it (older code, but the idea is still the same): https://github.com/MMMZZZZ/Syntherrupter/blob/80f99ee601b220f3aca8894f0c15684e727fd0e8/Syntherrupter_Tiva/MIDI.cpp#L920
And finally the last thing that I didn't find was a note holdoff,  which isn't really that important for a SSTC but very much so if you maybe want to upgrade to drsstc at some point. With a DRSSTC the current in the primary circuit continues to oscillate a bit after the interrupter pulse goes low as the energy is slowly put back into the bus caps. If however the interrupter is triggered again during this ring down (f.E. a note pulse occurs almost immediately after the end of another), the start "kick" or start oscillator (depending on the driver) would cause hard switching of the IGBTs, which if it occurs once might be fine, but if it happens too often it will probably kill the IGBTs. I believe that SSTCs don't have that problem, but I'm not 100% sure. If you want to implement this you could just add a variable that stores the system time of the last "output off", and whenever you switch it on again you check if the time is larger than a preset value.
Not so say of course that the interrupter is no good or anything like that, everybody starts somewhere and my intention is to tell you what I would have liked to read when starting work on my first one :D
Offline Zipdox
    • Zipdox
« Reply #2 on: September 28, 2020, 01:27:07 AM »
This is still the first version. I just coded this quickly to see if the Bluepill is powerful enough for the job and I can say it very much is.
I still have to add pitchbend and velocity. I'll also try to figure something out to make lower notes louder because the low duty cycle makes them almost inaudible when higher notes play. Perhaps some kind of duty cycle sharing.
As for the note holdoff, I think that's a little too complicated for me. I'm still new to C.
    • My Youtube Channel
« Reply #3 on: September 28, 2020, 04:44:56 PM »
Less than 80 lines of code - okay that's minimalistic! Now no one can say anymore that polyphony would be hard to do.  ;D Anyways, sounds already pretty good!
Note holdoff is really not that difficult at all. Add one more variable that you increment in your ISR just like the notes. It will be the holdoff. Then, in the if (been_on > ontime) section, you reset the holdoff to 0. Why? Well, if you enter that if, an ontime has ended and thus we want to wait for the holdoff time before the next ontime plays. Third change: replace the "if (play)" by "if (play && holdoff >= minHoldoff)". And you're done :)
This is a very simple approach but it has one disadvantage: the holdoff does not increase the time "between" ontimes but effectively omits a part of the next ontime. If two ontimes follow each other closely, the second one will be shortened by the holdoff time. This will probably be quite audible since 10-50us less ontime do make a big difference. On the other side, since there was an ontime just before this one it might not matter that much.
How to fix this? You could try the following. Only increment the been_on counters if the holdoff is above its threshold (and increment the holdoff otherwise). This does cause some jitter in the frequency of the notes but I'd guess this is less audible than the changing ontime. I'd definitely try both! ;)
Considering your issue with lower notes. In your video the very lowest note - even when playing alone is almost not audible at all (at 0:08 f.ex.). Are you 100% sure that it did really play at the same, constant ontime as the other notes? Your code looks like it should but the way it sounds would make me check it with a scope.
That aside, I thought about something similar for my Syntherrupter and came up with this: low notes play at constant duty, high notes at constant ontime, both values can be specified by the user. Crossover between modes happens at the frequency where both result in the same ontime. I explained it in details here: https://highvoltageforum.net/index.php?topic=1020.msg8564#msg8564
The code for this is not hard at all. You calculate the crossover frequency (or the MIDI pitch value corresponding to that frequency) once when the duty and/or ontime settings change. Then, in your handleNoteOn: if the note's frequency is above the crossover frequency, set ontime to the given value, otherwhise set the ontime to the given percentage of the notes period.
Here's the source code for the crossover frequency (line 433-445): https://github.com/MMMZZZZ/Syntherrupter/blob/d52c01bdb566ff2c13969cbc9f7b3510c9f22e47/Syntherrupter_Tiva/MIDI.cpp#L433
And here's the calculation of the ontime (line 691-699): https://github.com/MMMZZZZ/Syntherrupter/blob/d52c01bdb566ff2c13969cbc9f7b3510c9f22e47/Syntherrupter_Tiva/MIDI.cpp#L691
Offline Zipdox
    • Zipdox
« Reply #4 on: September 28, 2020, 06:28:50 PM »
I cooked up some new code. It uses duty cycle per note instead of a fixed pulse width. It ranges from 0.5% to 2.5% duty cycle per note depending on velocity. This increases the quality of low notes drastically.
Code: (c) [Select]
// GPL-3.0
#include <MIDI.h>
#define max_playing_notes 5
#define max_pitch 104
    while(pitch > max_pitch){
        pitch -= 12;
typedef struct {
    byte channel;
    byte pitch;
    int on_time;
    int off_time;
    int been_on;
} Note;
const float min_duty_cycle = 127/4.0;
const float duty_cycle_multiplier = 1/(min_duty_cycle+127)*0.025;
            float duty_cycle = (min_duty_cycle+velocity)*duty_cycle_multiplier;
            int on_time = duty_cycle*period;
            playing_notes[i] = {channel, pitch, on_time, period-on_time, 0};
            break;
void handlePitchBend(byte channel, int bend){
        if(playing_notes[i].channel != channel) continue;
        int period = notePeriod(playing_notes[i].pitch + bend/4096.0);
        playing_notes[i].off_time = period-10;
void sample(void){
void handleStop(){
void setup(){
        playing_notes[i] = {0, 0, 0, 0, 0};
    MIDI.setHandlePitchBend(handlePitchBend);
    MIDI.setHandleStop(handleStop);
    MyTim->resume();
void loop(){
    MIDI.read();
    bool play = false;
    if(play){
    }else{
I'm thinking about using some sort of lookup table for the pulse width depending on pitch. I'll have to figure out how to take velocity into account.
Only a slight problem; higher notes fail to make the SSTC pulse properly, because the pulses are too short, and so they are very hard to hear.
« Last Edit: September 28, 2020, 06:33:49 PM by Zipdox »
« Reply #5 on: September 28, 2020, 11:48:25 PM »
Uhm... don't think this would be necessary...? LUTs are useful if the calculation of the right value would take too much time but currently you don't face such a lag of processing time I think?
As a factor. You have the nominal ontime, f.ex. based on the period of the note, and then multiply it with velocity/128. So your velocity scales the ontime between 0 and the nominal value. Note: Your microcontroller doesn't have an FPU, meaning you should avoid floating point calculations whereever possible.
Of course they are! That's exactly what I described and linked from my previous post, including a quite simple solution.
Offline Zipdox
    • Zipdox
« Reply #6 on: October 02, 2020, 10:56:24 PM »
Code: (c) [Select]
#include <MIDI.h>
float note_periods[128] = {11741.9717620882, 11082.9455264689, 10460.9075912845, 9873.78196275034, 9319.60916365988, 8796.53969381148, 8302.82785747354, 7836.82593728726, 7396.97869516308, 6981.81818181818, 6589.95883763219, 6220.09286847073, 5870.98588104412, 5541.47276323444, 5230.45379564223, 4936.89098137517, 4659.80458182994, 4398.26984690574, 4151.41392873677, 3918.41296864363, 3698.48934758154, 3490.90909090909, 3294.97941881609, 3110.04643423537, 2935.49294052206, 2770.73638161722, 2615.22689782112, 2468.44549068758, 2329.90229091497, 2199.13492345287, 2075.70696436839, 1959.20648432181, 1849.24467379077, 1745.45454545455, 1647.48970940805, 1555.02321711768, 1467.74647026103, 1385.36819080861, 1307.61344891056, 1234.22274534379, 1164.95114545748, 1099.56746172643, 1037.85348218419, 979.603242160907, 924.622336895385, 872.727272727273, 823.744854704023, 777.511608558842, 733.873235130515, 692.684095404305, 653.806724455279, 617.111372671896, 582.475572728742, 549.783730863217, 518.926741092097, 489.801621080454, 462.311168447692, 436.363636363636, 411.872427352012, 388.755804279421, 366.936617565257, 346.342047702153, 326.90336222764, 308.555686335948, 291.237786364371, 274.891865431609, 259.463370546048, 244.900810540227, 231.155584223846, 218.181818181818, 205.936213676006, 194.37790213971, 183.468308782629, 173.171023851076, 163.45168111382, 154.277843167974, 145.618893182186, 137.445932715804, 129.731685273024, 122.450405270113, 115.577792111923, 109.090909090909, 102.968106838003, 97.1889510698552, 91.7341543913143, 86.5855119255382, 81.7258405569099, 77.138921583987, 72.8094465910928, 68.7229663579022, 64.8658426365121, 61.2252026350567, 57.7888960559616, 54.5454545454546, 51.4840534190015, 48.5944755349276, 45.8670771956572, 43.2927559627691, 40.862920278455, 38.5694607919935, 36.4047232955464, 34.3614831789511, 32.432921318256, 30.6126013175284, 28.8944480279808, 27.2727272727273, 25.7420267095007, 24.2972377674638, 22.9335385978286, 21.6463779813845, 20.4314601392275, 19.2847303959968, 18.2023616477732, 17.1807415894755, 16.216460659128, 15.3063006587642, 14.4472240139904, 13.6363636363636, 12.8710133547504, 12.1486188837319, 11.4667692989143, 10.8231889906923, 10.2157300696137, 9.64236519799838, 9.1011808238866, 8.59037079473777, 8.10823032956401, 7.65315032938209};
float notePeriod(float pitch){
        pitch -= 12;
typedef struct {
    byte channel;
    byte pitch;
    int on_time;
    int off_time;
    int been_on;
    byte velocity;
} Note;
            float period = note_periods[pitch];
            if(on_time < 5 && pitch >= 80){
                on_time = 5;
            }else if(on_time < 6 && pitch < 80){
                on_time = 6;
            playing_notes[i] = {channel, pitch, on_time, period-on_time, 0, velocity};
            break;
        float period = notePeriod(playing_notes[i].pitch + bend/4096.0);
        float duty_cycle = (min_duty_cycle+playing_notes[i].velocity)*duty_cycle_multiplier;
        if(on_time < 5 && playing_notes[i].pitch >= 80){
            on_time = 5;
        }else if(on_time < 6 && playing_notes[i].pitch < 80){
            on_time = 6;
        playing_notes[i].on_time = on_time;
        playing_notes[i].off_time = period-on_time;
void sample(void){
void handleStop(){
void setup(){
    MyTim->resume();
void loop(){
    MIDI.read();
    bool play = false;
    if(play){
    }else{
« Reply #7 on: October 03, 2020, 01:36:46 AM »
Interesting idea with that LUT, but I'm not convinced to be honest (might be because I don't really understand it :P). My Midistick doesn't do any pulse stretching at lower frequencies and sounds fine (in my opinion). But I tend to use midi files that have backing and melody on separate tracks and then use the volume adjust for each to get the mixing right, at least something where my experience mixing bands comes in handy these days...
It also seems a little like the notes are being drowned out by another. Polyphony is great, but it puts a lot of responsibility on the user to select the right tracks to be played. If there are too many different notes playing it gets a little confusing ;) It also makes a difference whether the notes are harmonic to another (in a chord) or a completely different melody. I usually try to keep it to two tracks per synth/coil that play notes at any given moment in time (with a maximum of four simultaneous notes), everything else gets too messy in my opinion. Another thing that could help with that is sustain (where the note volume constantly drops off as it is played), but that would be a major addition to the code, so maybe a long term goal :D You can read up on the envelope of a note if you are interested: https://en.wikipedia.org/wiki/Envelope_(music)
I'm also curious which midi player you use. Everybody seems to have a different preference there :D
Offline Zipdox
    • Zipdox
« Reply #8 on: October 03, 2020, 02:36:03 AM »
I use my phone with an OTG dongle and one of those cheap USB MIDI cables and this app. The MIDI cable is suboptimal because it has a shitty connector loose that can cause messages dropping. Also I patched the app with lucky patcher to remove the ads  ;)
« Reply #9 on: October 03, 2020, 02:38:57 PM »
I guess you use the app because you don't have a laptop and don't want to carry your desktop around right? It might be worth looking into using the usb module of the STM32 to do direct USB-Midi conversion. That would circumvent any issues with midi cables and make it easier to use. I didn't read everything but this seems like a god place to start: https://stm32duinoforum.com/forum/viewtopic_f_28_t_4442.html
My MidiStick also communicates this way, and it is actually pretty simple, as long as you don't want to dynamically rename devices or use multiple of them. The dynamic device name stuff took me best part of a month to get working properly ::)
Offline Zipdox
    • Zipdox
« Reply #10 on: October 06, 2020, 12:41:33 AM »
I can use my laptop but I's slightly inconvenient.
Regarding using USB, I looked into it but I couldn't find any USB libraries that are compatible with the STM32Duino core. USBComposite requires a different core that I was unable to get working. I might try again when I have more time on my hands. I'm kinda busy this week.
« Last Edit: October 06, 2020, 12:43:55 AM by Zipdox »
« Reply #11 on: October 07, 2020, 04:43:20 AM »
I used the USBComposite library for my vector network analyzer ( http://www.github.com/profdc9/VNA ) and Roger's stm32duino core.  You can use it in place of the built-in USB serial if you compile without it.    For example:
void usb_init_serial()
  if (usb_initialized)
    USBComposite.end();
  usb_initialized = 1;
  usb_reenumerate();
  USBComposite.clear();
  USBComposite.setProductId(VENDOR_ID);
  USBComposite.setProductId(SERIAL_CDC_PRODUCT_ID);
  CompositeSerial.registerComponent();
  console_setMainSerial(&CompositeSerial);
  USBComposite.begin();
  //while (!USBComposite.isReady());
bool usb_init_mass_storage()
  DWORD sectors;
  flash_mount_fs_card();
  if (!flash_fs_mounted) return false;
  if (disk_ioctl(0, GET_SECTOR_COUNT, &sectors) != RES_OK) return false;
    USBComposite.end();
  usb_reenumerate();
  USBComposite.setProductId(MASS_STORAGE_PRODUCT_ID);
  MassStorage.setDriveData(0, sectors, sd_read, sd_write);
  MassStorage.registerComponent();
  console_setMainSerial(NULL);
  return true;
I have not tried the MIDI support, however, but the USBSerial and USBMassStorage works for me.
« Last Edit: October 07, 2020, 04:45:34 AM by profdc9 »
« Reply #12 on: October 07, 2020, 02:35:18 PM »
The biggest trouble is setting the USB config descriptor for midi... that took me a few days to get right on the midiStick, the best info I found is the original spec (from 1999 :P). Just google "midi10.pdf".
Once you have that working and manage to receive packets, you deal with them just like normal midi packets, but keep in mind that the actual packet starts at data[1] as the data[0] is the virtual cable ID.
Offline Zipdox
    • Zipdox
« Reply #13 on: October 24, 2020, 07:02:13 PM »
I fixed pitch bend and made the program calculate the lookup tables at startup. I also uploaded the code to GitHub.
https://github.com/Zipdox/STM32_Interrupter
Pitch bend demo
Daniel Uhrenholt
Today at 09:41:48 AM
Today at 01:46:20 AM
October 24, 2020, 11:12:37 PM
Daniel Uhrenholt
October 24, 2020, 11:07:33 PM
Daniel Uhrenholt
October 24, 2020, 10:45:41 PM
Daniel Uhrenholt
October 24, 2020, 10:12:37 PM
October 24, 2020, 09:29:06 PM
October 24, 2020, 09:20:37 PM
October 24, 2020, 09:07:24 PM
post Re: Software for playing MIDIs
October 24, 2020, 07:29:57 PM
Daniel Uhrenholt
October 24, 2020, 06:38:42 PM
October 24, 2020, 05:42:49 PM
post Software for playing MIDIs
October 24, 2020, 04:37:26 PM
Daniel Uhrenholt
October 24, 2020, 03:51:52 PM
October 24, 2020, 02:25:00 PM
Daniel Uhrenholt
October 24, 2020, 12:12:41 PM
post MOVED: DIY current transformer for scoping primary current?
Kizmo
October 24, 2020, 11:45:58 AM
post DIY current transformer for measuring primary current?
Daniel Uhrenholt
October 24, 2020, 11:22:24 AM
post Re: Ping pong (and pumpkin?) cannons - split from ferrite-core QCW topic
October 24, 2020, 04:16:06 AM
October 24, 2020, 04:07:24 AM
October 23, 2020, 11:39:35 PM
October 23, 2020, 07:10:22 PM
October 23, 2020, 05:36:02 PM
October 23, 2020, 05:34:39 PM
post MOVED: Ping pong (and pumpkin?) cannons - split from ferrite-core QCW topic
October 23, 2020, 05:27:45 PM
October 23, 2020, 03:03:28 PM
post Re: RC snubbers
October 23, 2020, 12:27:42 AM
October 22, 2020, 10:06:59 PM
October 22, 2020, 09:05:22 PM
October 22, 2020, 07:17:16 PM
October 22, 2020, 05:33:39 PM
October 22, 2020, 02:07:27 PM
post RC snubbers
October 22, 2020, 11:42:26 AM
SAMGO
October 22, 2020, 11:21:19 AM
October 22, 2020, 09:14:24 AM
October 22, 2020, 06:19:28 AM
October 22, 2020, 04:21:50 AM
October 22, 2020, 01:23:15 AM
October 21, 2020, 08:31:51 PM
October 21, 2020, 08:21:55 PM
October 21, 2020, 07:17:07 PM
SalinsLV
October 21, 2020, 01:30:19 PM
October 21, 2020, 05:00:34 AM
October 21, 2020, 04:46:55 AM
October 21, 2020, 04:42:19 AM
October 21, 2020, 02:29:54 AM
October 20, 2020, 11:50:25 PM
SAMGO
October 20, 2020, 10:50:25 PM
October 20, 2020, 09:38:42 PM
