Author Topic: 6" Coil Update now 72" and better lighting  (Read 371 times)
Offline Bradselph
« on: September 23, 2020, 09:03:56 AM »
6.6 Secondary Coil 24AWG Wire 28" with a 7"x23" Topload
58nf beer bottle capacitors with a 11 turn 1/4" copper tubing primary coil. the spark gap is a harbor freight special grinder with a 8" disc cutout with 8 1/4" brass bolts speed varied by variac 110v input seems to be the sweet spot
Power supply is made of 4 1kw 120v Microwave Transformers in banks of 2 for 240v input with 4800v out and mid point grounded then parrelled each to double the current to about 1.8amps at 4800v
then half wave multiplied to 9,600v. and a 5th 1kw microwave core with primary removed only secondary remains to be used as a charging choke to save the diode bank from kickback and also give the capacitor a flyback charging effect to 19kv there is no smoothing capacitor so its 120hz pulsed DC
so far longest measured strike has been 72"
Hopefully this is a better amount of lighting for you guys.
I updated my grinder spark gap and have yet to enclose it for safety but I took that risk as I have with running this thing period.
« Last Edit: September 23, 2020, 09:12:59 AM by Bradselph »
Re: 6" Coil Update now 72" and better lighting
« Reply #1 on: September 23, 2020, 03:06:28 PM »
Looking good, Brad.  It's a little hard to confidently get the power supply details from your words; have you got time to show us a diagram?
Offline Bradselph
« Reply #2 on: October 15, 2020, 09:47:27 PM »
Sorry i havnt fotten a chance to make a diagram explaining the transformer setup but i have got a few more pictures and a small video uploaded recently on Instagram
https://www.instagram.com/bselph512/
https://www.instagram.com/p/CGYCi_ehkMRocAjGaenNsGjrfi2GF1I_xc8l2A0/?igshid=1nkuumzp36qzr
But ill attach some here i stacked my other 6" toroid from my 4" coil and confirmed the need for a bigger toroid the output became alot larger and longer
« Last Edit: October 15, 2020, 09:52:58 PM by Bradselph »
Offline Zipdox
    • Zipdox
« Reply #3 on: October 17, 2020, 11:16:24 PM »
Your Instagram is private.
« Reply #4 on: October 18, 2020, 07:00:13 AM »
I would love to see detailed pictures of your power supply, spark gap and beer bottle capacitors. For a bottle capacitor MMC coil you are getting some real good spark length and stable performance that has small hickups properly more likely to be rotating spark gap mis-firing.
As Zipdox notes, we can not see your instagram account content. It is also better for historic reasons to upload directly to the forum, that way nothing is lost for the future as all the content is hosted together and not on external hosts away from the forum.
Offline Bradselph
« Reply #5 on: October 19, 2020, 01:53:01 AM »
The hiccups are definitely the spark gap i got a good look at what was happening a few nights ago
I have the spark gap setup with another gap in series to help quenching as without it the arcs would trail half way around the disc and i remade the gap and placed the gaps next to each other and using a squirrel cage fan to blow on both the gaps at once to help quenching it work better but now that im adding more power i started to get what i thought was more trailing arcs but thats not what was happing the spark gap is actually using the hot air the fan is blowing to power arc about 4" between each gap.
I'll get a few pictures of most of my setup before i fix the spark gap. Its a low budget build so its kinda embarrassing compared to most but the spark length im getting and the good words of encouragement leads me to believe you guys wont pick on me too much
I will also say the power supply is definitely on edge of destruction as evident in alot of my videos you can see the transformers arcing to there core when the coil strikes the bottle caps and thats mostly the reason for locating the capacitor under the coil itself instead of beside it like used before in crates making the capacitor on a rolling platform was the best way to move the mass weight of them without killing my back
Another note worth mentioning is the beers caps are almost a year old now and ive broken maybe 6-8 for various reasons none of them have lost any capacitance all still hover about 0.9 to 1.2nf each
I will say ive learned what works and doesnt work by trying and failing alot so the things ive found to work are what you see
I fixed the Instagram and definitely agree to upload onsite as well for archive reasons I'll try to get picture's and a diagram for you guys soon
Today at 08:14:37 PM
Today at 08:04:33 PM
Today at 08:04:01 PM
Today at 03:04:07 PM
Today at 11:51:37 AM
Today at 07:30:41 AM
November 28, 2020, 06:32:22 PM
post Re: Ericsson RRUS 11 B4 teardown
November 28, 2020, 06:29:37 PM
November 28, 2020, 06:22:11 PM
November 28, 2020, 03:10:04 PM
November 28, 2020, 12:36:05 PM
November 28, 2020, 08:16:41 AM
November 28, 2020, 06:35:48 AM
November 28, 2020, 06:22:44 AM
November 28, 2020, 06:04:33 AM
November 28, 2020, 04:36:08 AM
post Setting over current protection for my drsstc
November 28, 2020, 12:37:32 AM
post Re: Single mosfet driving with GDT
November 27, 2020, 10:57:31 PM
November 27, 2020, 10:33:30 PM
November 27, 2020, 08:42:35 PM
November 27, 2020, 07:45:58 PM
November 27, 2020, 07:35:55 PM
November 27, 2020, 05:09:54 PM
November 27, 2020, 01:45:04 PM
November 27, 2020, 02:18:49 AM
November 27, 2020, 01:17:40 AM
post HF Litz wire as a primary coil
November 27, 2020, 12:33:29 AM
November 26, 2020, 07:28:57 PM
November 26, 2020, 07:20:41 PM
November 26, 2020, 06:48:34 PM
November 26, 2020, 02:42:34 PM
November 26, 2020, 01:22:02 PM
post Question about arduino polyphonic MIDI interrupter
November 26, 2020, 01:09:32 PM
post Re: AGFA ADC 5155 X-ray Scanner Teardown (4 part series)
November 26, 2020, 12:27:05 PM
November 26, 2020, 12:07:11 PM
post Current transformer for measuring primary current
November 26, 2020, 01:32:17 AM
post Re: SSTC issues (gate signal, interrupter-mode, grounding)
November 25, 2020, 09:57:26 PM
November 25, 2020, 09:13:24 PM
Max Seiringer
November 25, 2020, 09:01:22 PM
post Re: Slayer Exciter Mosfet Gate drive alternative?
November 25, 2020, 07:13:17 PM
November 25, 2020, 05:21:28 PM
post Ericsson RRUS 11 B4 teardown
November 25, 2020, 11:26:39 AM
post Re: Peak Primary current in small DRSSTC
Jesperb123
November 25, 2020, 10:45:43 AM
November 25, 2020, 01:56:06 AM
Max Seiringer
November 24, 2020, 11:12:02 PM
November 24, 2020, 10:44:00 PM
