Author Topic: Upper audio frequency interruption of HFSSTC  (Read 446 times)
Offline uzzors2k
    • uzzors2k.com
« on: September 12, 2020, 06:19:32 PM »
Hi all, I was working on a new class E HFSSTC PCB with an interrupter input some months back, but was stumped by a problem. Perhaps some of the clever minds here have an idea!
The fundamental issue is that when I interrupt my class E Tesla coil at a high frequency (1-2kHz or so), the main MOSFET explodes. I encountered this while running through all the notes on my keyboard with a MIDI interrupter. Schematic: * HfsstcDriver_rev3_uzzors2k.pdf
Now I ~think~ it occurs because of ringing in the GDT. From oscilloscope tracing, and verified through simulation, I see that the leakage inductance and
DC blocking capacitance resonate when the drive is interrupted. This resonance is a few volts, and maybe enough to turn the MOSFET partially on, causing heavy losses.
I have a solution for this which is to short the GDT during off time in order to quench the circulating energy. But there are two issues here.
1) Is the GDT ringing a likely culprit for the MOSFET deaths, or could it be something else? I've tried modelling more of the system, but without great success.
2) Is there any practical way to avoid the large circulating resonant current in the GDT? Some leakage inductance will always be present with a GDT.
I had previously attempted using a gate driver chip directly, but this failed catastrophically when the drain voltage was increased.
I have a suspicion this might be related to the problem with the MOSFET dying at higher interrupter frequencies.
Comparison of the observed waveform and the simulated waveform. * plot_gate_ringing.pdf
http://uzzors2k.com/ - Projects website
Re: Upper audio frequency interruption of HFSSTC
« Reply #1 on: September 12, 2020, 07:44:46 PM »
There appear to be several issues.  First, the scope capture doesn't appear to match your schematic.  Either that or the GDT leakage inductance is really high and making a series resonance with gate capacitance at your SSTC operating frequency.  Did you change to a 1:2 GDT ratio?  How is it wound?  0.94 coupling factor is extremely low for a GDT.
For interrupting, you need to drive both sides of the GDT with separate driver chips.  The disabled state needs to drive to the center voltage, not to one rail or the other.  With two drivers, both low (or both high) produces that center-voltage output between enable pulses.
The low-frequency parasitic resonance you see is not leakage inductance, but rather GDT parallel inductance resonating with the DC blocking capacitor.  Adding an R + C network across the existing C as in UD2.7 will damp that resonance.
One final possibility, though unlikely if schematic values are accurate.  At turn-off, the FET drain inductor L1 combined with output capacitor C12 will form a resonant circuit.  If average FET current is high enough, that resonant circuit could ring high enough at the end of enable pulses to hit 600V.  That would take ~20A average current with your values, so seems unlikely.
« Last Edit: September 13, 2020, 05:35:03 PM by davekni »
Offline uzzors2k
    • uzzors2k.com
« Reply #2 on: September 17, 2020, 09:02:42 PM »
The GDT is bifilar wound on a Toroid, eight turns. I guess the simulated coupling factor is unrealistically poor, I looked up a reference just now to see what normal ranges were again. Practical GDT designs the site seems to be down, but I found it on the WaybackMachine. I simply tuned the coupling factor to get the simulation to roughly match the scope shots. Thanks for the R + C damping network tip, that will certainly help.
« Last Edit: September 17, 2020, 09:04:32 PM by uzzors2k »
« Reply #3 on: September 17, 2020, 11:18:25 PM »
With your bifilar 1:1 GDT, there must be a large overshoot on the gate waveform to get from 15Vpp input to ~30Vpp output per your scope trace.  It would be worth zooming in to the gate waveform.  You will likely need a small series resistor between gate and GDT to damp that overshoot.
Once overshoot is removed, the gate waveform will be +-7.5V, a bit marginal for turning on the output FET (Q1) completely.  Most power FETs are specified for 10Vgs, and 12Vgs is often used to get maximum performance.  That's another reason for using two driver chips with GDT primary between two complimentary outputs.  With two driver chips running on 12V, Vgs becomes +-12V.  Even +-15V is fine for FETs as long as overshoot is minimized.  The two driver chips also allows for proper disable for interrupting.
October 20, 2020, 11:50:25 PM
SAMGO
October 20, 2020, 10:50:25 PM
October 20, 2020, 09:38:42 PM
October 20, 2020, 05:08:29 PM
RoadReaper
October 20, 2020, 03:17:48 AM
October 19, 2020, 11:02:11 PM
October 19, 2020, 10:53:26 PM
October 19, 2020, 10:50:35 PM
October 19, 2020, 09:51:57 PM
October 19, 2020, 09:48:07 PM
SalinsLV
October 19, 2020, 07:27:59 PM
October 19, 2020, 06:48:03 PM
October 19, 2020, 03:54:00 PM
Maju
October 19, 2020, 10:25:25 AM
October 19, 2020, 08:56:13 AM
October 19, 2020, 07:54:05 AM
October 19, 2020, 05:32:05 AM
October 19, 2020, 05:12:05 AM
RoadReaper
October 19, 2020, 04:13:30 AM
October 19, 2020, 03:39:49 AM
Bradselph
October 19, 2020, 01:53:01 AM
October 19, 2020, 12:36:38 AM
October 18, 2020, 11:57:02 PM
Maju
October 18, 2020, 11:14:53 PM
October 18, 2020, 10:42:01 PM
October 18, 2020, 09:54:48 PM
October 18, 2020, 08:25:41 PM
Maju
October 18, 2020, 03:28:04 PM
October 18, 2020, 12:08:36 PM
October 18, 2020, 07:31:58 AM
October 18, 2020, 07:18:08 AM
October 18, 2020, 07:00:13 AM
October 18, 2020, 06:50:25 AM
October 18, 2020, 06:39:34 AM
October 18, 2020, 05:15:50 AM
October 17, 2020, 11:26:45 PM
October 17, 2020, 11:16:24 PM
post Re: steam engine
October 17, 2020, 09:42:50 PM
October 17, 2020, 09:05:37 PM
October 17, 2020, 08:23:11 PM
October 17, 2020, 07:45:56 PM
October 17, 2020, 03:26:32 PM
October 17, 2020, 03:06:49 PM
October 17, 2020, 06:17:07 AM
October 17, 2020, 04:15:07 AM
October 16, 2020, 07:41:01 PM
October 16, 2020, 08:36:35 AM
Bradselph
October 15, 2020, 09:47:27 PM
October 15, 2020, 09:37:29 PM
October 15, 2020, 09:18:14 PM
