Author Topic: Nokia Siemens Flexi 3x70W FXEA 1800MHz Base Station Teardown  (Read 342 times)
Teardown of a Nokia Siemens Networks Flexi Multiradio base station. This have been in service as a 3 antenna system for mobile telecommunications. GSM/EDGE, WCDMA/HSPA and LTE capable. 3x70 Watt output power.
All high resolution pictures will be published with part 2
Re: Nokia Siemens Flexi 3x70W FXEA 1800MHz Base Station Teardown
« Reply #1 on: August 27, 2020, 08:55:21 PM »
Circuit analysis of a Nokia Siemens Networks Flexi Multiradio base station. This have been in service as a 3 antenna system for mobile telecommunications. GSM/EDGE, WCDMA/HSPA and LTE capable. 3×70 Watt output power.
The power supply is split into a input protection board and a main power supply board with three individual power supplies, one for each channel, controlled by a single Texas Instruments LM5035. Each power supply then has a Analog Devices AD5241 256-step digital potentiometer to drive the gate driver ICs, through the GDTs to the IR5110 100V/61A MOSFET full-bridge. The output of the 48V to 48V center-tapped transformer is rectified with a B20200G 200V/10A Schottky diode and a large choke.
The main telecom protocol handling board with the 3 optical fiber in-/outputs has a NXP / Freescale MPC8377E 800 MHz PowerQUICC II CPU for the overall control and for the physical in-/outputs it has a Xilinx Spartan XC3S200A FPGA with a maximum of 248 user I/O. Single conditioning by Texas Instruments ACH973.
The three optical fiber interfaces is distributed to each their pair of a Texas Instruments TLK3131 1-channel 1Gbps transceiver and a Altera Hardcopy IV HC4E35LF1152NAH custom ASIC that handles the telecom protocol translations to single bit stream for the DAC and conversion to telecom protocol from the single bit stream from the ADC.
« Reply #2 on: August 27, 2020, 09:05:43 PM »
The connections from the diplexer passes through some 2-pole ceramic coaxial resonator blocks before entering a Macom MAATSS0015 15dB 4-bit digital attenuator. From here the receiving signal is going through down conversion in the Analog Devices AD5356 1200-2500 MHz Dual IF amplifier. Guessing from the Analog Devices AD8376 700 MHz +20dB Dual IF variable gain amplifier, the down conversion is from 1800 MHz to 700 MHz. There is two different ADC in place, perhabs for each their generation, like 3G and 4G. First to the right is a Analog Devices AD9255 14-bit 125 MSPS ADC and to the left is a Texas Instruments ADC16DV160 which is a dual 16-bit 160 MSPS ADC.
The transmitting signal only has a Analog Devices AD9122 dual 16-bit 1200 MSPS DAC that has its up conversion through a Analog Devices ADL5375 0.4-6 GHz Quadrature IF modulator, before going through a 8-pole ceramic coaxial resonator block and being fed into the power amplifier.
Associated functions for clock generation and power supply is handled by Analog Devices ADF4106 6 GHz PLL frequency synthesizer, Analog Devices ADM660 CMOS switched capacitor voltage converter and Texas Instruments PT77701 1.8V ultra fast regulator.
The tuner board has feedback from the amplifier and diplexer on reflected energy and received signals. The information is handled by a NXP / Freescale MCF5208 Coldfire RISC CPU with built-in SRAM, DDR SDRAM, DMA controller and 10/100 Mbps Ethernet interface. The tuning motors are controlled individually for each of the three sectors, by a Lattice LCMX0640 FPGA/CPLD hybrid. The motor drivers have a on-board separated power supply from the 48VDC used for radio circuits.
The power amplifier module sits on a aluminium silicon carbide base plate and has the power transistors mounted directly on this. The pre-amplifier IC is a NXP / Freescale MW7IC2040N with a 4 Watt output power at 1805-1880 MHz. Anaren Xinger 1P503S 3 dB hybrid couplers are used for the 90 degree phase split before going into the Doherty amplifiers built on two Ampleon BLF720LS-250P LDMOS which can put out 250 Watt at 1805-1880 MHz. The output combiner is a Anaren Xinger II XC1900E-03S 3dB hybrid coupler before going to off-board circulator that protects the amplifier module from the reflected energy from the antenna, which are measured through a direct coupler at the top of the board.
The diplexer has three identical sets of resonant cavities, it is designed with 5-pole filters for the receiving part and 6-pole filter for the transmitting part, with a lot of added couplings between the cavities.
At last, this is how you configure a super sophisticated 4G base station amplifier, a single resistor to select between 1800 or 1900 MHz carrier frequency. ;)
« Last Edit: August 27, 2020, 09:07:46 PM by Mads Barnkob »
Offline nielsquake
« Reply #3 on: August 28, 2020, 12:00:24 AM »
Woah that is awesome to see and funny with the way it switches with the single resistor. Always wondered what those base stations looked like inside o.o The resonant cavities are the best part. Cool to see how humans are able to bend particles to their will like that using such intricately designed holes in a box. Awesome teardown!
I love radio stuff ever since I got meteor m2 images and NOAA pics with my nooelec SDR so I do love seeing antenna designs
« Last Edit: August 28, 2020, 12:06:02 AM by nielsquake »
« Reply #4 on: September 15, 2020, 08:51:22 AM »
Da_Stier, a user here from www.highvoltageforum.net has reverse engineered the power amplifier module and this is the documentation and test results.
Today at 05:31:25 PM
GKnapp
Today at 05:20:51 PM
Today at 03:46:15 PM
post Re: How do you all pronounce kluge or kludge?
Today at 03:25:48 PM
Today at 02:12:35 PM
GKnapp
Today at 02:02:34 PM
Today at 01:27:52 PM
Today at 11:58:14 AM
friday
Today at 07:53:30 AM
Today at 06:09:20 AM
Today at 05:58:46 AM
Today at 04:40:21 AM
Today at 02:22:28 AM
post Re: Cheapest source so far for step adjustable DC power for ZVS induction heaters
Today at 02:06:56 AM
September 19, 2020, 11:34:01 PM
post How do you all pronounce kluge or kludge?
September 19, 2020, 11:21:11 PM
September 19, 2020, 10:13:44 PM
post Re: Fat wire for facility (a house)
September 19, 2020, 09:40:56 PM
post steam engine
September 19, 2020, 07:54:41 PM
post DRSSTC driver
September 19, 2020, 04:50:28 PM
post Re: Join Kaizer Power Electronics, Youtube channel now has memberships
[Crowdfunding]
September 19, 2020, 04:50:23 PM
September 19, 2020, 03:27:57 PM
post DRSSTC Tuning for Music vs Big Sparks?
GKnapp
September 19, 2020, 01:41:14 PM
September 19, 2020, 11:09:16 AM
post Am I Misunderstanding of DC Blocking Capacitors
werd
September 19, 2020, 08:13:55 AM
September 19, 2020, 01:31:34 AM
post Cheapest source so far for step adjustable DC power for ZVS induction heaters
September 18, 2020, 11:58:14 PM
post Fat wire for facility (a house)
September 18, 2020, 10:35:59 PM
September 18, 2020, 05:29:24 PM
September 18, 2020, 03:52:08 PM
September 18, 2020, 02:49:05 PM
post Re: IGBT Temperature
September 18, 2020, 11:56:58 AM
September 18, 2020, 10:31:58 AM
post Re: Eensy weensy switchmode power supplies
September 18, 2020, 08:19:19 AM
post Re: Upper audio frequency interruption of HFSSTC
September 17, 2020, 11:18:25 PM
September 17, 2020, 10:26:57 PM
September 17, 2020, 09:13:40 PM
uzzors2k
September 17, 2020, 09:02:42 PM
September 17, 2020, 07:46:08 PM
September 17, 2020, 07:43:00 PM
September 17, 2020, 10:23:29 AM
September 17, 2020, 06:56:59 AM
September 17, 2020, 12:22:32 AM
post SSTC or DRSSTC with GaN Transistors
September 16, 2020, 10:36:08 PM
September 16, 2020, 10:23:59 PM
September 16, 2020, 09:49:17 PM
September 16, 2020, 09:38:14 PM
September 16, 2020, 06:19:24 PM
post Re: Cheap drsstc driver board?
September 16, 2020, 05:12:03 PM
post Re: Picking Primary Coil Gauge and Winding Count
werd
September 16, 2020, 07:31:54 AM
