Author Topic: Secondary parameters  (Read 674 times)
Offline Alberto
« on: May 16, 2020, 11:08:54 PM »
Hello. I know that I am new and this is the 3th post that I have opened but I think it doesn´t fix in the others. I have also searched but I didn´t find anything in the forum.
I am going to build a new secondary coil to use with a simple slayer exciter because with only 19 volts I have fried a router and in the kitchen, the induction stove started doing strange thinks. Maybe, in the future, I will use with a half bridge, but now I am alittle scared and I preffer low power...
I have read this article http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/secondary-coil/ and I think I have to use 40mm PVC pipe and 0,1mm cooper wire. The number of turns must be between 1460-1830, but the article is focused in DRSSTC and I am not sure if that parameters are OK for a single transistor SSTC.
I said that because in some places I read that above 1.200 turns the coil loss efficiency. What do you think?
Thank you
Kind regards
Re: Secondary parameters
« Reply #1 on: May 17, 2020, 07:55:34 PM »
You are correct that SSTCs generally have lower ratio between width:height of the secondary coil.
You can use the guide lines for sizes, but keep to a ratio of 1:3 instead and you will have a lower impedance coil that still needs a high coupling to the primary coil.
I think your noise issues has much more to do with lack of grounding your secondary coil to a separate RF ground.
Offline Alberto
« Reply #2 on: May 17, 2020, 10:18:22 PM »
Thank you for your answer.
Yes, I know I need to ground the coil, but with the quarantine it is difficult. Next week I´m going to buy a big metal tray to connect to ground and put the coil over it.
I am not sure about understanding your answer. Are you recomending me to keep a lower ratio like 1:3? For example 1.200 turns? I´m sorry, I´m learning English and sometimes is difficult to me.
« Last Edit: May 17, 2020, 11:10:42 PM by Alberto »
Offline Alberto
« Reply #3 on: June 21, 2020, 07:34:38 PM »
I have been busy with my student´s exams.
I read the article again and I understood the meaning of the ratio, so the secondary has 1.058 turns of 0,1 mm wire. 4 cm diameter 12 cm hihg. I have enjoyed a lot winding that thin wire! But it was easier than I thought
I tried running it with this slayer exciter circuit
  from this video https://www.youtube.com/watch?v=Ca2e3evwVK0
Running with 12V give 1 or 2 cm arcs
I have tried different slayer exciter circuits and this one have gave me the best results, but Do you know a better option for a Slayer exciter circuit?
I made this small topload with beer cans and bass bolts.
The question is: Is important that the top load is very close of the top of the coil or it doesn´t matter if is 3 or 4 cm from the last turns?
EDITED: I have been reading and I have realised that a lsayer exciter won't be enough. But before star building more complex circuits I would like to understand the physics and theory of the tesla coils, resonant frequency, tunning, etc...
Can anybody recommend me a good source. I have a  little knowledge about electricity and electronics. For example I know how works resonance with coils and capacitors.
Meanwhile I will keep experimenting with the slayer exciter
Tank you
« Last Edit: June 22, 2020, 01:20:47 AM by Alberto »
« Reply #4 on: June 22, 2020, 05:20:07 AM »
There are several excellent web sites that explain the theory of Tesla coils. This is one my favorites.
http://www.richieburnett.co.uk/tesla.shtml
Offline Alberto
« Reply #5 on: June 22, 2020, 10:41:21 AM »
Thank you!
And my experience tells me that the vintage appearance means good material
« Reply #6 on: June 22, 2020, 12:20:21 PM »
I think Gao from loneoceans.com wrote one of the most thorough guides to building a SSTC, which I would say is the natural step up from a slayer exciter. http://loneoceans.com/labs/sstc2/
The topload has two main jobs, capacitance for storing charge buildup and field shaping around the secondary coil to prevent corona/breakout in others places than you want, I described this is more details here: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/topload/
Offline Alberto
« Reply #7 on: June 23, 2020, 10:08:28 PM »
Yes, I have read the article of toploads. This is why I have used brass bolts. I think I have to read it again slowly.
Thank you for the SSCT link from loneoceans, but I preffer start with low voltages like 20 or 30 DCV instead conect to the AC outlet.
« Last Edit: June 23, 2020, 11:58:27 PM by Alberto »
[Digital Compact Camera]
Today at 05:14:51 PM
Today at 04:44:56 PM
Today at 10:50:31 AM
Today at 09:15:09 AM
Today at 09:09:45 AM
post Re: type of driver
Today at 08:39:30 AM
Today at 08:16:46 AM
Today at 01:27:07 AM
Today at 01:14:46 AM
Today at 12:30:58 AM
post type of driver
GKnapp
extremeodd
post FPGA speeds these days?
v.coelho
