Author Topic: Secondary parameters  (Read 160 times)
Offline Alberto
« on: May 16, 2020, 11:08:54 PM »
Hello. I know that I am new and this is the 3th post that I have opened but I think it doesn´t fix in the others. I have also searched but I didn´t find anything in the forum.
I am going to build a new secondary coil to use with a simple slayer exciter because with only 19 volts I have fried a router and in the kitchen, the induction stove started doing strange thinks. Maybe, in the future, I will use with a half bridge, but now I am alittle scared and I preffer low power...
I have read this article http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/secondary-coil/ and I think I have to use 40mm PVC pipe and 0,1mm cooper wire. The number of turns must be between 1460-1830, but the article is focused in DRSSTC and I am not sure if that parameters are OK for a single transistor SSTC.
I said that because in some places I read that above 1.200 turns the coil loss efficiency. What do you think?
Thank you
Kind regards
Re: Secondary parameters
« Reply #1 on: May 17, 2020, 07:55:34 PM »
You are correct that SSTCs generally have lower ratio between width:height of the secondary coil.
You can use the guide lines for sizes, but keep to a ratio of 1:3 instead and you will have a lower impedance coil that still needs a high coupling to the primary coil.
I think your noise issues has much more to do with lack of grounding your secondary coil to a separate RF ground.
Offline Alberto
« Reply #2 on: May 17, 2020, 10:18:22 PM »
Thank you for your answer.
Yes, I know I need to ground the coil, but with the quarantine it is difficult. Next week I´m going to buy a big metal tray to connect to ground and put the coil over it.
I am not sure about understanding your answer. Are you recomending me to keep a lower ratio like 1:3? For example 1.200 turns? I´m sorry, I´m learning English and sometimes is difficult to me.
« Last Edit: May 17, 2020, 11:10:42 PM by Alberto »
kilohercas
Today at 06:38:15 AM
Today at 03:24:49 AM
post Re: SSTC Micro
Today at 03:24:20 AM
Rowdy
Today at 03:23:33 AM
Today at 03:06:20 AM
Today at 01:33:47 AM
post MMC for a 32kvac load
Rowdy
Today at 01:02:34 AM
Rowdy
May 24, 2020, 11:47:26 PM
post Re: GDT cable specs
May 24, 2020, 11:09:44 PM
Rowdy
May 24, 2020, 10:39:45 PM
station240
May 24, 2020, 09:55:49 PM
May 24, 2020, 09:55:48 PM
May 24, 2020, 08:16:40 PM
thecyberman
May 24, 2020, 05:38:27 PM
Rowdy
May 24, 2020, 02:33:55 PM
hip424
May 24, 2020, 02:31:39 PM
iraquois
May 24, 2020, 02:08:53 PM
May 24, 2020, 12:12:36 PM
May 24, 2020, 07:56:21 AM
May 24, 2020, 03:09:57 AM
May 23, 2020, 10:24:55 PM
May 23, 2020, 09:30:29 PM
post GDT cable specs
May 23, 2020, 09:06:39 PM
May 23, 2020, 08:22:59 PM
May 23, 2020, 07:47:49 PM
May 23, 2020, 07:41:41 PM
iraquois
May 23, 2020, 02:09:26 PM
May 23, 2020, 12:46:23 PM
May 23, 2020, 04:14:52 AM
post Re: New projet OmegaDR
May 22, 2020, 01:15:36 AM
Mugi30
May 21, 2020, 11:55:37 PM
May 21, 2020, 07:46:28 PM
Mugi30
May 21, 2020, 09:15:57 AM
May 21, 2020, 06:35:31 AM
May 21, 2020, 05:23:40 AM
May 21, 2020, 12:16:04 AM
May 20, 2020, 11:22:34 PM
May 20, 2020, 12:15:43 PM
May 19, 2020, 02:08:20 PM
Mugi30
May 19, 2020, 12:05:51 PM
May 19, 2020, 11:49:02 AM
May 19, 2020, 09:26:06 AM
May 19, 2020, 07:55:54 AM
May 19, 2020, 01:55:11 AM
May 18, 2020, 11:54:27 PM
Mugi30
May 18, 2020, 10:10:09 PM
Mugi30
May 18, 2020, 10:05:14 PM
May 18, 2020, 09:03:11 PM
May 18, 2020, 07:50:08 PM
May 18, 2020, 04:15:16 PM
