Author Topic: Diferents drivers for SSTC´s  (Read 749 times)
Offline Alberto
« on: May 14, 2020, 08:49:42 PM »
Hello. I have made a coil with 1.000 turns of 29AWG in a PVC pipe. I have try different slayer exciters circuits. The basic with TIP31C, and a diode. And this one a little bit more elborated. This give me 2 cm sparks at 19V. I leave below the link to the video where I saw it.
I also tried with the electroBOOM circuit
R1 = 2 ohm
R2 = 22Kohm
U1 = MIC4452
Q1 = IRF840
Diode = 1n4148
But it doesn´t work. I think the IC need more connections because I have only connect the pins IN and OUT. Do I also need to connect the pins VS and GND? Directly to the power supply?
And reading the forum, I see circuits much more elaborated. If I would make one of these, Will I see a great improvement?
Thank you so much
Kind regards
https://www.youtube.com/watch?v=Ca2e3evwVK0
Re: Diferents drivers for SSTC´s
« Reply #1 on: May 14, 2020, 09:26:34 PM »
yes  you have to connedct the ic power pins
In logic circuits the power pins are often omitted to make the logic clearer but they still have to be connected
« Reply #2 on: May 14, 2020, 09:57:27 PM »
Yes you need to connect power to the driver. Look up the datasheet before popping components into circuits at random, it might even work if you did that first :)
As seen here in the functional diagram, the VSS and GND is not just there to make the component look nice.
Offline Alberto
« Reply #3 on: May 14, 2020, 10:55:17 PM »
hahaha.
This is what happens when you don´t have idea. Thank you very much.
And what about the other drivers circuit. Am I going to see the difference?
EDIT: It has worked! But only les than one minute at 12 volts. The IC burns!
I'm thinking about to make a new coil with more turns. How many turns do you recomend me? Also because the size, does it matters if I use Awg 32 or 36? I read a lot of internet but I'm not sure and I see real professional people in this forum.
« Last Edit: May 14, 2020, 11:38:44 PM by Alberto »
Offline ritaismyconscience
« Reply #4 on: May 15, 2020, 08:17:13 AM »
This will fix your problem.
Offline Alberto
« Reply #5 on: May 15, 2020, 09:50:25 AM »
Very instructive, Thank you!
Today at 11:15:01 AM
post COHERENT transformerless 81mHz amplifier schematic ?
dreamth
Today at 10:42:41 AM
post Interrupter frequency?
Today at 10:08:39 AM
dreamth
Today at 09:34:59 AM
post Re: TIG welder teardown. ESAB TIG Caddy 1500i.
Bouaziz
Today at 09:34:05 AM
ChrisBlis
Today at 09:30:38 AM
dreamth
Today at 09:08:55 AM
Today at 07:16:23 AM
Today at 05:08:32 AM
Today at 04:47:32 AM
dreamth
March 03, 2021, 11:20:38 PM
AeraCura_
March 03, 2021, 11:15:32 PM
March 03, 2021, 10:30:40 PM
dreamth
March 03, 2021, 10:03:26 PM
post Re: Need Help w/Build - Lightning Pulse Generator
March 03, 2021, 09:45:28 PM
March 03, 2021, 09:44:17 PM
post First power on tests
March 03, 2021, 06:26:23 PM
March 03, 2021, 05:54:58 PM
dreamth
March 03, 2021, 03:13:30 PM
dreamth
March 03, 2021, 01:18:22 PM
dreamth
March 03, 2021, 12:25:52 PM
dreamth
March 03, 2021, 12:24:40 PM
ChrisBlis
March 03, 2021, 10:43:20 AM
March 03, 2021, 09:05:02 AM
March 03, 2021, 05:53:33 AM
March 03, 2021, 04:22:01 AM
March 03, 2021, 04:00:14 AM
March 03, 2021, 01:21:15 AM
post Re: Just a noob with some HV concerns...
March 03, 2021, 12:36:05 AM
dreamth
March 03, 2021, 12:35:57 AM
March 02, 2021, 11:40:16 PM
dreamth
March 02, 2021, 11:29:28 PM
March 02, 2021, 10:48:04 PM
March 02, 2021, 10:33:13 PM
dreamth
March 02, 2021, 10:20:22 PM
March 02, 2021, 10:18:05 PM
March 02, 2021, 09:38:45 PM
March 02, 2021, 08:54:33 PM
post Re: WTS [EU] Vici DM4070 LCR meter with SMD tweezers
March 02, 2021, 08:53:31 PM
March 02, 2021, 05:04:44 PM
March 02, 2021, 03:16:25 PM
March 02, 2021, 09:41:31 AM
ChrisBlis
March 02, 2021, 08:26:30 AM
hightemp1
March 02, 2021, 07:05:01 AM
March 02, 2021, 06:22:52 AM
post Re: Interesting RF air-core transformer construction
March 02, 2021, 05:24:46 AM
hightemp1
March 02, 2021, 05:21:16 AM
March 02, 2021, 04:37:50 AM
hightemp1
March 02, 2021, 01:26:36 AM
March 01, 2021, 11:07:01 PM
