Author Topic: Freewheeling diodes are burning (Now other problems)  (Read 2658 times)
Re: Freewheeling diodes are burning (Now other problems)
« Reply #20 on: May 17, 2020, 02:16:37 AM »
Shorted-turn is another way to describe induction heating.  I hadn't heard of making a top-load that wasn't a shorted turn, but that should be possible by having an insulating connection between the start and end of the duct.  Do either that or add space between the top of the secondary and top load.
Have you double-checked conductivity just to rule out arcing?
Offline hip424
« Reply #21 on: May 18, 2020, 03:13:14 PM »
When I changed MOSFETs to IXFH20N50P3's two of them blew up at about 60VDC. I think it's because that I removed Zener diodes from gates. Now I will change MOSFETs to AOK60B65H2AL IGBTs and add 18V Zener to it. I want to know what you think about it and hear some other possible issues. I just want to finish this project (BTW it's for school teacher). I will leave it at Static medium BPS and run on 330VDC.
Best Regards
Daniel
P.S.
To avoid double posting, I'm editing my post. I've replaced my MOSFETs with IGBTs and I' curious if there is possibility to drive gates of MOSFETs directly from the driver (without GDT). I'v seen datasheet for UCC3732x and there is possibility to drive gates directly from the ICs. I know that the chip hasn't galvanic isolation between output and input but it has separate ground and I've ran ground traces correctly. I know that this chip has only one output so I can't drive fullbridge with it but maybe I will do the halfbridge. Please answer my question.
Answering to davekin question: conductivity is OK. If I will fix other problems then maybe I will take a look at this topload again. For now this is secondary case.
Best Regards
Daniel
« Last Edit: May 20, 2020, 07:45:11 PM by hip424 »
« Reply #22 on: May 23, 2020, 07:47:49 PM »
Read the UCC3732x specification, especially the pin functions table.  That will answer your question.
Offline ritaismyconscience
« Reply #23 on: May 24, 2020, 03:09:57 AM »
Don't skip the GDT.
You run into a lot of other problems (like voltage spikes and noise getting into your driver circuit and blowing things up since they aren't isolated anymore). Also, the upper IGBT might be at +330V and the lower one at 0V, and your UCC chip will blow up due to the voltage difference. There are specialized bootstrap driver ICs for this purpose but skipping the GDT is not worth it in the end.
I'm wondering if the MOSFETS survive because high avalanche energy, while IGBTs fail because they aren't very good at taking voltage spikes. If this is correct, adding a snubber cap or adding TVS diodes would fix this problem (try getting the 440V diodes, those should work)
Offline hip424
« Reply #24 on: May 24, 2020, 02:31:39 PM »
Thanks for answers. My Tesla Coil runs just fine with AOK60B65H2AL IGBTs at static medium BPS. Ritaismyconscience do you meant replacing freewheeling diodes by bipolar TVS? Maybe I know the reason why my MOSFETs were blowing at higher BPS: I current limited my power supply to about 450mA (driver board) and when testing it at low bus voltage I've noticed that power supply switches between CC/CV modes so it needed more current in pulse. But anyway I'm still afraid to run it at higher BPS so I will probably leave it just like it is. Also I have question: Can I safely run it on rectified 240VAC with softstart firstly turning on driver board? I mean I ran it with variac but I don't know if I stick it to mains the voltage rise would be too fast. So please help me with that.
Best Regards
Daniel
Update:
When i ran my coil at medium BPS and 330VDC the arcs got very small and I found the issue. I shielded feedback wire an connected shielding to mains earth. When I disconnected ground from shielding it was running OK but when I ran it one more time the arcs were as small as before and I found that the bottom-left IGBT got shorted but not completly (3.3ohms between Collector-Emitter) and I don't know what is causing this. In addition I have wire-wound gate resistors so maybe I should replace them with metalized ones.
Best Regards
Daniel
« Last Edit: May 30, 2020, 12:22:26 PM by hip424 »
Today at 12:57:53 PM
post Re: Enclosure design considerations for a DRSSTC?
Today at 10:26:15 AM
Today at 06:09:48 AM
post Blackbody Radiation and Thermal Control of Satelites.
Today at 03:57:45 AM
kyledellaquila
January 23, 2021, 07:22:57 PM
January 23, 2021, 07:15:46 PM
January 23, 2021, 06:54:18 PM
January 23, 2021, 06:39:16 PM
post Re: 833A Maximum Dissipation Ratings
kyledellaquila
January 23, 2021, 05:43:59 PM
Acid Byte
January 23, 2021, 03:40:18 PM
pc50kd
January 23, 2021, 02:35:18 PM
paulj
January 23, 2021, 11:27:50 AM
post 8 ft spark french tesla coil
paulj
January 23, 2021, 11:00:37 AM
post Re: High voltage transformer for neon bombarding.
January 22, 2021, 11:23:39 PM
post Re: Paralleling IGBT bricks for H-bridge
January 22, 2021, 08:09:18 PM
zytra
January 22, 2021, 06:49:26 PM
AndreasVE
January 22, 2021, 11:16:43 AM
post Enclosure design considerations for a DRSSTC?
January 22, 2021, 10:05:28 AM
Patrik
January 22, 2021, 08:47:11 AM
January 22, 2021, 06:19:21 AM
January 22, 2021, 06:03:43 AM
post Re: induction heater issues
January 22, 2021, 05:45:21 AM
post Re: Anybody got some tips for releasing a product?
AeraCura_
January 22, 2021, 05:22:44 AM
January 22, 2021, 04:58:04 AM
AeraCura_
January 22, 2021, 03:39:07 AM
January 22, 2021, 03:18:53 AM
January 22, 2021, 01:52:12 AM
kyledellaquila
January 22, 2021, 01:26:13 AM
aes92000
January 22, 2021, 01:19:24 AM
post Anybody got some tips for releasing a product?
January 22, 2021, 12:46:22 AM
January 22, 2021, 12:41:44 AM
post Paralleling IGBT bricks for H-bridge
Patrik
January 21, 2021, 02:10:48 PM
Patrik
January 21, 2021, 11:31:39 AM
post High voltage transformer for neon bombarding.
AndreasVE
January 21, 2021, 10:53:15 AM
zytra
January 21, 2021, 08:36:50 AM
January 21, 2021, 05:10:27 AM
post Re: 4HV gone?
January 21, 2021, 05:08:54 AM
post induction heater issues
aes92000
January 21, 2021, 04:19:43 AM
hightemp1
January 21, 2021, 03:00:50 AM
zytra
January 21, 2021, 02:21:32 AM
January 21, 2021, 01:23:12 AM
zytra
January 21, 2021, 01:12:01 AM
January 20, 2021, 11:51:48 PM
January 20, 2021, 11:47:09 PM
January 20, 2021, 11:19:41 PM
January 20, 2021, 08:43:54 PM
January 20, 2021, 08:40:45 PM
January 20, 2021, 08:25:37 PM
January 20, 2021, 08:24:54 PM
January 20, 2021, 07:02:04 PM
