Author Topic: My 160 (?)mm sstc  (Read 12897 times)
Re: My 160 (?)mm sstc
« Reply #80 on: November 14, 2017, 09:26:27 AM »
Did you build it yourself or from a oneTesla kit? I don't notice any pops or anything like that, but then again I've never been listening for one.
Does it look like a kit? lol
Friend of mine bodged battery, some LEDs, switches and arduino nano in battery pack case
Today I tried figuring out what is wrong with it, and it turns out it's much worse than I thought, check out for example:
It's just one note playing, yellow signal is note-on midi message, and resulting pulses should all be evenly spaced. This happens to almost every note
How are you playing the midi file?  And what version of the Arduino ide did you use?
« Last Edit: November 18, 2017, 12:22:39 PM by futurist »
« Reply #81 on: November 15, 2017, 08:03:21 PM »
uzzors2k published a MIDI modulator back in 2013 ( http://uzzors2k.4hv.org/index.php?page=midiinterrupter ), there is a good chance that oneTesla used all kinds of public available code for their own.
I just happened to stumble upon his site and saw that a error was found in the code August 2017
Polyphonic Tesla Coil MIDI Interrupter
Update 25.08.2017
It was recently brought to my attention by Kilian Brixel that there is a bug in this code, where a note off status byte would be ignored if the velocity was not also set to zero.
Futurist, does this sound like a possible source of the pop's?
« Reply #82 on: November 18, 2017, 12:21:34 PM »
Midi is played from PC, arduino version is 1.8.5
Update 25.08.2017
No unfortunately. Also it seems they didn't use any part of uzzors2k code
« Reply #83 on: January 10, 2018, 01:25:58 AM »
So I've been thinking..... while I wait for parts for my drsstc project I might change the inverter section to a twin half bridge and have a low primary turn count.
 I think what I'm trying to achieve would be comparable spark length to a full bridge design..... Stay tuned!
« Reply #84 on: January 10, 2018, 08:24:46 AM »
Just remember that twice the silicon does not give twice the performance :)
If you want to play it safe you should not push it more than 30-50% higher than a single bridge, if you go much higher the failure rate due to imbalanced inductance, switching times, die temperature etc, will increase dramatically.
Looking forward to see it :)
« Reply #85 on: January 10, 2018, 08:32:14 AM »
Hahaha. I was hoping with a dual half bridge I could push more primary current?  My idea was that the parallel half bridge would share the load.. if that makes sense?
« Reply #86 on: January 10, 2018, 03:23:02 PM »
Steve Ward makes his QCW and Titan coil inverters like that:
i've always used individual half-bridge sections that get tied in parallel with "long" output leads to act in a similar manner to "balancing chokes" found on variac stacks, for example. There's also options for splitting up the MMC so that each output can drive its own section of the total capacitance, enforcing current sharing.
« Reply #87 on: January 11, 2018, 12:29:19 AM »
Is there a build thread somewhere for Steve's (unless it's a joint venture build) titan drsstc?
On a side note I found this:
Build thread:
http://4hv.org/e107_files/public/1233997813_347_FT0_ctl_and_inverter.jpg
« Reply #88 on: January 12, 2018, 01:17:52 PM »
So I got the driver board made and the dual half bridge fired up! Because of my not so great construction I have to completely shield the driver. Interrupted it simply doesn't work well,almost like a fade in and out of power. But it definitely works CW! With the worst voltage divider capacitors and the crappiest wiring of all time it puts out about 270mm in length of "FULL BRIDGE RECTIFIED" goodness. Once I get the correct voltage divider capacitors and the main wiring from the variac to the bridge complete I think this will be an awesome CW coil..... And hopefully an impressive isstc.       It has just occurred to me that this project will never end!
« Last Edit: January 12, 2018, 01:23:53 PM by oneKone »
post Re: SGTC MK1 - An Accomplishment in Progress
[Spark gap Tesla coils]
jturnerkc
Today at 01:11:49 AM
[Solid state Tesla coils]
babass
November 20, 2019, 10:05:50 PM
post Re: Disc launcher attachment
[Induction launchers, coil guns and rails guns]
November 20, 2019, 09:42:20 PM
post Re: my first DRSSTC is not working properly
November 20, 2019, 09:06:08 PM
November 20, 2019, 08:18:32 PM
post Re: IR wavelength in photoelectric smoke detectors?
[Light, lasers and optics]
November 20, 2019, 07:27:42 PM
November 20, 2019, 07:16:24 PM
zanikk
November 20, 2019, 06:07:23 PM
November 20, 2019, 10:25:09 AM
November 20, 2019, 05:30:25 AM
November 19, 2019, 11:15:31 PM
post Re: coil Tesla in the space
November 19, 2019, 11:28:10 AM
post Re: RF Amplifier for Cubesat plasma thruster
[Electronic circuits]
November 19, 2019, 08:56:49 AM
jturnerkc
November 19, 2019, 06:25:49 AM
November 19, 2019, 06:17:03 AM
November 19, 2019, 06:03:37 AM
post Disc launcher attachment
November 19, 2019, 05:51:39 AM
November 19, 2019, 05:47:34 AM
jturnerkc
November 19, 2019, 12:49:52 AM
babass
November 18, 2019, 09:19:26 PM
post my first DRSSTC is not working properly
zanikk
November 18, 2019, 06:56:18 PM
November 18, 2019, 02:38:14 PM
November 18, 2019, 01:46:06 PM
November 18, 2019, 12:21:53 PM
November 18, 2019, 09:01:41 AM
November 18, 2019, 08:57:05 AM
November 18, 2019, 04:48:39 AM
jturnerkc
November 18, 2019, 03:30:02 AM
November 18, 2019, 02:53:29 AM
November 18, 2019, 01:59:24 AM
jturnerkc
November 18, 2019, 12:07:38 AM
November 17, 2019, 07:15:01 PM
babass
November 17, 2019, 04:06:01 PM
November 17, 2019, 06:26:58 AM
post Re: Measuring permanent magnets
November 17, 2019, 03:02:45 AM
babass
November 16, 2019, 09:20:41 PM
November 16, 2019, 08:03:58 PM
babass
November 16, 2019, 07:27:30 PM
November 16, 2019, 06:55:16 PM
November 16, 2019, 05:19:05 PM
babass
November 16, 2019, 01:33:17 PM
November 16, 2019, 04:56:44 AM
November 16, 2019, 04:13:35 AM
babass
November 16, 2019, 01:21:10 AM
Alexis
November 15, 2019, 08:14:00 PM
November 15, 2019, 05:40:33 PM
jturnerkc
November 15, 2019, 03:59:48 PM
post coil Tesla in the space
Alexis
November 15, 2019, 03:35:38 PM
November 15, 2019, 05:18:19 AM
post SSTC low voltage at gate transformer and heating drivers
babass
November 14, 2019, 05:40:58 PM
