Author Topic: Motor-run capacitor RMS current  (Read 925 times)
« on: April 16, 2020, 06:03:22 PM »
I use several 100 uF, 400 volt motor-run capacitors for PFC on my SGTC. I have tried to find the RMS current capacity of these capacitors with no success. Does anyone know what the typical RMS current capacity of a typical 100 uF, 400 volt motor-run capacitor is?
  • All the gear, no idea. UK
Re: Motor-run capacitor RMS current
« Reply #1 on: April 16, 2020, 07:01:09 PM »
Any idea what the motor was rated for?
« Reply #2 on: April 16, 2020, 07:33:14 PM »
Steve,
I doubt you'll find a specific RMS current rating.  It's implied by the capacitor's other specifications, 400V, 100uF, and 60Hz, 15.1A in this case.  Since motor-run capacitors are typically polypropylene these days, there's a good chance it can handle more than 15A.  There's just no need for the vendor to test higher since it's intended for 60Hz use.
« Reply #3 on: April 16, 2020, 08:31:30 PM »
I am not using them for a motor. I am using them for PFC as part of my spark gap Tesla coil. I bought them new.
Offline k42
« Reply #4 on: April 28, 2020, 02:51:15 PM »
I believe these capacitors should work very well in 50/60 Hz PF correction... In motor applications, the voltage over the capacitor often rises much higher than the supply voltage, for example, I've measured around 500 V over a capacitor which was in a 230 V motor.
Just be sure that they are run capacitors, not start capacitors.
« Reply #5 on: April 30, 2020, 05:39:25 AM »
Yes, intended for mains operation, and that's about it.  The connections are typically foil ribbon, giving relatively high ESR and ESL, much lower current capacity than it could be.  The connections may also be fused, by themselves or by gas expansion inside the can forcing the connections apart.  (I have some cylindrical types with an embossed rim that, according to the patent, is supposed to expand like an accordion, pulling the connections apart, under these conditions.)
Today at 01:27:18 AM
Today at 01:19:19 AM
SimonNwardUK
April 22, 2021, 10:36:43 PM
April 22, 2021, 06:52:48 PM
April 22, 2021, 01:20:02 PM
post Re: Corona discharge
April 22, 2021, 12:57:35 PM
April 22, 2021, 10:59:28 AM
April 22, 2021, 05:56:48 AM
April 22, 2021, 05:38:10 AM
post Re: UD2.7 Thru Hole
April 22, 2021, 02:41:13 AM
April 22, 2021, 02:41:08 AM
April 21, 2021, 09:18:14 PM
April 21, 2021, 08:38:20 PM
April 21, 2021, 08:15:13 PM
April 21, 2021, 08:08:15 PM
April 21, 2021, 07:59:41 PM
April 21, 2021, 07:40:40 PM
April 21, 2021, 04:29:42 PM
April 21, 2021, 06:12:33 AM
post UD2.7 Thru Hole
April 21, 2021, 03:52:44 AM
post Corona discharge
April 21, 2021, 12:16:22 AM
Vdekje
April 20, 2021, 10:48:45 PM
Vdekje
April 20, 2021, 10:33:53 PM
April 20, 2021, 07:32:37 PM
April 20, 2021, 07:29:04 PM
April 20, 2021, 07:25:30 PM
April 20, 2021, 06:55:36 PM
April 20, 2021, 06:48:29 PM
April 20, 2021, 03:42:58 PM
mrsebe
April 20, 2021, 01:54:01 PM
April 20, 2021, 04:53:09 AM
April 20, 2021, 02:32:21 AM
April 20, 2021, 02:28:12 AM
April 20, 2021, 12:20:45 AM
April 19, 2021, 09:59:08 PM
April 19, 2021, 09:35:16 PM
April 19, 2021, 08:48:07 PM
April 19, 2021, 05:03:29 PM
post Intensifying screen
Merces
April 19, 2021, 04:45:03 PM
mrsebe
April 19, 2021, 04:36:43 PM
post Whoohoooooo
April 19, 2021, 12:29:03 PM
hashtala
April 19, 2021, 10:02:46 AM
April 19, 2021, 06:04:03 AM
April 19, 2021, 02:48:40 AM
April 18, 2021, 08:04:18 PM
April 18, 2021, 07:10:24 PM
April 18, 2021, 01:11:28 PM
iw1esu
April 18, 2021, 12:26:48 PM
April 18, 2021, 02:36:34 AM
April 18, 2021, 01:24:59 AM
