Author Topic: Hacking the IKEA 2000 Watt induction stove (5 parts)  (Read 11741 times)
Offline aq62386238
Re: Hacking the IKEA 2000 Watt induction stove (5 parts)
« Reply #40 on: September 04, 2018, 04:47:33 PM »
thank help me alot
Offline aq62386238
« Reply #41 on: September 05, 2018, 11:59:20 AM »
did you plug to the ac power  supply or direct plug in to home's supply
« Reply #42 on: September 05, 2018, 01:43:24 PM »
It is just plugged into a wall socket in my house.
Offline aq62386238
« Reply #43 on: September 16, 2018, 03:31:06 PM »
How to measure the watt of the inductor is that Vout(rms)*Iout(rms)?
How to get the every set’s power
« Reply #44 on: September 17, 2018, 11:20:53 AM »
I think you can find some help in this presentation: "Analysis and Design of Quasi Square Wave Resonant Converters" https://www.onsemi.com/pub/Collateral/TND348-D.PDF
Offline chjarup
« Reply #45 on: December 02, 2018, 12:12:57 PM »
Hi All,
I have managed to modify this cooker to external control, I have made this document to explain how.
I hope you can use it , and give inspiration to other projects. My purpose was to make a temperature controlled cooker for beer brewing.
* Patching IKEA TILREDA for auto control_ver1.pdf
Regards Carsten Dahl Hjarup
« Reply #46 on: December 02, 2018, 04:23:16 PM »
Hi All,
Good to hear from you Carsten and thanks for sharing your results. Which power level does it run at when fed with 20 kHz and which duty cycle did you use in your own oscillator?
I will soon get my unit back on the bench and dig a little deeper on the control IC, hopefully I can find a way to interface it by looking at the communication between HMI and control IC. It would be fun to get bumpless control over it instead of on/off control.
What is your conclusion on the pan detection function? is it really something it measures on some kind of back-emf on the driver output? Or it is just not a problem for you size you always have a pan on it?
Offline chjarup
« Reply #47 on: December 02, 2018, 11:44:14 PM »
The original cooker on level nine (max) is continus 46% ON. So I made the oscillator 50% , so this means as long as the control PIO is active, the cooker is giving out max power.
>of on/off control.
That would be cool , and give better control.
I measured that the pulse it give out for "pot detection" will give a "ringing" if no pot present, this is fed to AIO (or may be PIO level only)
If pot is present there will be almost none ringing after the detection pulse.
In software this could be detected via either peak detection, RMS detection , or sampling ... I tried to mess with it with a DC voltage , but it cost me a new set of output Transistors  :)
I added my measurements on "pot detection", however it could probably be disabled by setting the pin permanent LOW, to fool system to believe that the pot is always present. However I have not tested this.
* Images pulse check.zip
Br Carsten
post A quick way can checking f1=1/2π√L1C1 in 30 second
VNTC
Today at 04:05:38 AM
post Unknown part of original Tesla coil
VNTC
Today at 02:44:17 AM
Today at 12:00:18 AM
July 21, 2019, 11:18:06 PM
post Re: Drsstc 3
July 21, 2019, 03:25:02 PM
post CM300 coil build questions
July 21, 2019, 05:32:28 AM
post Re: Welcome new members, come say hello and tell a little about yourself :
July 20, 2019, 09:45:42 PM
Bert911
July 19, 2019, 11:19:45 AM
July 19, 2019, 03:36:44 AM
DICKEYBIRD
July 19, 2019, 03:24:38 AM
July 19, 2019, 02:23:29 AM
DICKEYBIRD
July 19, 2019, 01:06:44 AM
Justin
July 18, 2019, 10:29:32 PM
July 18, 2019, 08:52:35 AM
July 18, 2019, 05:49:27 AM
VNTC
July 18, 2019, 03:13:27 AM
July 18, 2019, 12:06:53 AM
July 17, 2019, 07:56:41 PM
July 17, 2019, 11:25:22 AM
July 16, 2019, 07:39:33 AM
VNTC
July 16, 2019, 05:11:21 AM
July 16, 2019, 04:05:07 AM
post Re: DRSSTC in brust mode
SAMGO
July 16, 2019, 02:25:27 AM
July 16, 2019, 01:54:30 AM
July 15, 2019, 02:51:26 PM
July 15, 2019, 02:48:02 PM
July 15, 2019, 01:48:08 PM
July 15, 2019, 01:45:00 PM
July 15, 2019, 11:21:29 AM
VNTC
July 15, 2019, 10:01:21 AM
July 15, 2019, 07:52:41 AM
July 15, 2019, 07:33:30 AM
July 14, 2019, 10:49:03 PM
July 14, 2019, 09:59:40 PM
July 14, 2019, 08:20:52 PM
July 14, 2019, 06:06:30 PM
July 14, 2019, 05:29:10 PM
[Smart phones]
July 14, 2019, 03:00:09 PM
post Re: Drsstc 3
July 14, 2019, 02:06:26 PM
July 14, 2019, 02:04:22 PM
post Re: Twin System Build
July 14, 2019, 01:27:18 AM
July 14, 2019, 01:22:15 AM
post Re: Drsstc 3
July 13, 2019, 03:48:54 PM
post DRSSTC in brust mode
SAMGO
July 13, 2019, 04:17:55 AM
donnersm
July 12, 2019, 08:54:54 PM
July 12, 2019, 07:16:40 PM
July 12, 2019, 06:33:00 PM
VNTC
July 12, 2019, 11:09:28 AM
post Re: Drsstc 3
July 12, 2019, 09:56:38 AM
post Re: Drsstc 3
July 12, 2019, 01:23:58 AM
