Author Topic: Hacking the IKEA 2000 Watt induction stove (5 parts)  (Read 8873 times)
Offline aq62386238
Re: Hacking the IKEA 2000 Watt induction stove (5 parts)
« Reply #40 on: September 04, 2018, 04:47:33 PM »
thank help me alot
Offline aq62386238
« Reply #41 on: September 05, 2018, 11:59:20 AM »
did you plug to the ac power  supply or direct plug in to home's supply
« Reply #42 on: September 05, 2018, 01:43:24 PM »
It is just plugged into a wall socket in my house.
Offline aq62386238
« Reply #43 on: September 16, 2018, 03:31:06 PM »
How to measure the watt of the inductor is that Vout(rms)*Iout(rms)?
How to get the every set’s power
« Reply #44 on: September 17, 2018, 11:20:53 AM »
I think you can find some help in this presentation: "Analysis and Design of Quasi Square Wave Resonant Converters" https://www.onsemi.com/pub/Collateral/TND348-D.PDF
Offline chjarup
« Reply #45 on: December 02, 2018, 12:12:57 PM »
Hi All,
I have managed to modify this cooker to external control, I have made this document to explain how.
I hope you can use it , and give inspiration to other projects. My purpose was to make a temperature controlled cooker for beer brewing.
* Patching IKEA TILREDA for auto control_ver1.pdf
Regards Carsten Dahl Hjarup
« Reply #46 on: December 02, 2018, 04:23:16 PM »
Hi All,
Good to hear from you Carsten and thanks for sharing your results. Which power level does it run at when fed with 20 kHz and which duty cycle did you use in your own oscillator?
I will soon get my unit back on the bench and dig a little deeper on the control IC, hopefully I can find a way to interface it by looking at the communication between HMI and control IC. It would be fun to get bumpless control over it instead of on/off control.
What is your conclusion on the pan detection function? is it really something it measures on some kind of back-emf on the driver output? Or it is just not a problem for you size you always have a pan on it?
Offline chjarup
« Reply #47 on: December 02, 2018, 11:44:14 PM »
The original cooker on level nine (max) is continus 46% ON. So I made the oscillator 50% , so this means as long as the control PIO is active, the cooker is giving out max power.
>of on/off control.
That would be cool , and give better control.
I measured that the pulse it give out for "pot detection" will give a "ringing" if no pot present, this is fed to AIO (or may be PIO level only)
If pot is present there will be almost none ringing after the detection pulse.
In software this could be detected via either peak detection, RMS detection , or sampling ... I tried to mess with it with a DC voltage , but it cost me a new set of output Transistors  :)
I added my measurements on "pot detection", however it could probably be disabled by setting the pin permanent LOW, to fool system to believe that the pot is always present. However I have not tested this.
* Images pulse check.zip
Br Carsten
post Re: Bleed R's for MMC caps ?
pentode
Today at 08:36:58 AM
L_Mangold
Today at 02:40:13 AM
post Re: Kaizer DRSSTC1 bridge failure and repair, caught on video.
dexter
February 22, 2019, 07:47:34 PM
February 22, 2019, 06:10:35 PM
February 22, 2019, 04:34:54 PM
February 22, 2019, 04:34:14 PM
post Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 02:59:46 PM
pentode
February 22, 2019, 12:20:26 PM
February 22, 2019, 10:07:23 AM
pentode
February 22, 2019, 08:28:17 AM
post Re: TL494 Flyback driver oscillator section
setkiki
February 22, 2019, 04:28:24 AM
bogdan
February 21, 2019, 06:41:27 PM
February 21, 2019, 06:06:46 PM
February 21, 2019, 03:15:47 PM
post Bleed R's for MMC caps ?
pentode
February 21, 2019, 02:54:39 PM
February 21, 2019, 09:37:55 AM
post Re: 160mm PLL sstc
February 21, 2019, 04:44:03 AM
post Re: My X-Ray Machine
Agent Smith
February 20, 2019, 11:10:28 PM
February 20, 2019, 06:45:41 PM
bogdan
February 20, 2019, 03:20:24 PM
February 20, 2019, 10:02:24 AM
February 20, 2019, 08:42:24 AM
February 19, 2019, 08:48:51 AM
VNTC
February 19, 2019, 04:54:44 AM
nabzim
[Light, lasers and optics]
VNTC
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
