Author Topic: Does not name a type even though I made a typedef  (Read 355 times)
Offline Zipdox
« on: March 27, 2020, 11:58:01 PM »
For some reason I can't compile this code for Arduino.
Code: [Select]
#include <MIDI.h>
#define samplingRate 62500
#define maxPlayingNotes 2
MIDI_CREATE_DEFAULT_INSTANCE();
float midiFrequency(float note){
  return 440*(pow(2, (note-69)/12));
typedef struct {
    byte pitch;
    int onTime;
    int offTime;
    int hasBeenOn;
} Note;
Note getNoteTimes(byte pitch, float dutyCycle){
  float period = samplingRate/midiFrequency(pitch);
  Note finalNote = {pitch, round(dutyCycle*period), round((1-dutyCycle)*period), 0};
  return finalNote;
volatile Note playingNotes[maxPlayingNotes];
void handleNoteOn(byte channel, byte pitch, byte velocity){
    for(int i = 0; i < maxPlayingNotes; i++){
        if(playingNotes[i].onTime == 0){ // 0 onTime means this note isn't in use
            playingNotes[i] = getNoteTimes(pitch, 0.1);
            break;
    digitalWrite(13, HIGH);
void handleNoteOff(byte channel, byte pitch, byte velocity){
        if(playingNotes[i].pitch == pitch){
            playingNotes[i] = {0,0,0,0}; // 0 onTime means it doesn't play
    digitalWrite(13, LOW);
//void handlePitchBend(byte channel, int bend){
//  float bendfactor = (1+ (float) bend/8190);
//  float dutyCycle = 0.1;
//  for(int i = 0; i < maxPlayingNotes; i++){
//      if(playingNotes[i].onTime == 0) continue;
//      float period = samplingRate/(bendfactor * midiNotes[playingNotes[i].pitch]);
//      playingNotes[i].onTime = round(dutyCycle*period);
//      playingNotes[i].offTime = round((1-dutyCycle)*period);
void setup(){
    for(int i = 0; i<(sizeof(playingNotes)/sizeof(playingNotes[0])); i++){
//  playingNotes[0] = getNoteTimes(261.6, 0.1);
//  playingNotes[1] = getNoteTimes(329.6, 0.1);
//  playingNotes[2] = getNoteTimes(392.0, 0.1);
    pinMode(9, OUTPUT);
    pinMode(13, OUTPUT);
  cli(); //stop interrupts
//  TCCR2A = 0; // set Timer/Counter Control Registers (TCCR2A/B) to 0
  TCCR2B = 0;
  OCR2A = 0; // = 16000000 / (freq*prescaler) - 1 (must be <256)
  // turn on CTC mode
  TCCR2A |= (1 << WGM21);
  // Set CS01 and CS00 bits for 64 prescaler
  TCCR2B |= (1 << CS20);
  // enable timer compare interrupt
  TIMSK2 |= (1 << OCIE2A);
  sei(); //allow interrupts
  MIDI.setHandleNoteOn(handleNoteOn);
  MIDI.setHandleNoteOff(handleNoteOff);
//  MIDI.setHandlePitchBend(handlePitchBend);
  MIDI.begin(MIDI_CHANNEL_OMNI);
void loop(){
    MIDI.read();
volatile bool shouldPlay;
ISR(TIMER2_COMPA_vect){
  shouldPlay = false;
    playingNotes[i].hasBeenOn++;
    if(playingNotes[i].hasBeenOn > playingNotes[i].onTime){
        playingNotes[i].hasBeenOn = -playingNotes[i].offTime;
    if(playingNotes[i].hasBeenOn >= 0){
        shouldPlay = true;
  if(shouldPlay){
    PORTB |= 1 << 1;
  }else{
    PORTB &= ~(1 << 1);
//  byte ^= 1 << bit_to_flip;
//  byte &= ~(1 << bit_to_clear);
//  byte |= 1 << bit_to_set;
polyphonic_midi_interrupter_pitchbend:19:1: error: 'Note' does not name a type; did you mean 'tone'?
 tone
exit status 1
Re: Does not name a type even though I made a typedef
« Reply #1 on: March 28, 2020, 04:14:17 AM »
A C instructor I am not.
Am kind of rusty with typedefs, but don't think you need one here.  What if you skip "typedef" ?
The way you said it,  Note seems to be an instance of a nameless kind of struct.
Don't we need to say something like:
struct Note {
 int x;
 int y;
struct Note Note1;
struct Note foo();
int bar( struct Note z );
Maybe the typedef lets you later say Note instead of struct Note, but I'm out of my element here.  STFI!
Here's one reference found immediately with DuckDuckGo:
https://stackoverflow.com/questions/9653072/return-a-struct-from-a-function-in-c
« Last Edit: March 28, 2020, 04:33:06 AM by klugesmith »
Offline Zipdox
« Reply #2 on: March 28, 2020, 01:29:53 PM »
struct Note {
 int x;
 int y;
struct Note Note1;
struct Note foo();
It's really weird because it used to work before, but somehow now that I changed some other code it no longer does.
Offline SteveN87
« Reply #3 on: March 28, 2020, 03:27:54 PM »
Does it work if you add a struct tag? e.g.:
Code: [Select]
typedef struct Note_t {
    byte pitch;
    int onTime;
    int offTime;
    int hasBeenOn;
} Note;
Offline Zipdox
« Reply #4 on: March 28, 2020, 04:47:45 PM »
Code: [Select]
    byte pitch;
    int onTime;
    int offTime;
    int hasBeenOn;
} Note;
No it doesn't. I also tried doing struct and typedef separately and it also doesn't work. I believe this might be a bug in the compiler because when I tried moving functions around it gave very weird output, there were words joined without spaces ans it was all very confusing. I may file a bug report later.
« Reply #5 on: March 28, 2020, 06:27:49 PM »
One rite of passage for coders is finding their first compiler bug,
where correct source code does not compile or behaves wrong.
Offline SteveN87
« Reply #6 on: March 28, 2020, 06:45:21 PM »
Have they changed the default C standard revision to C18? (Maybe knock it down to C11 if so.)
« Reply #7 on: March 28, 2020, 10:15:20 PM »
Probably a missing semicolon somewhere then.
Also FYI, declarations are usually placed in headers so they are declared at the top right away; doesn't matter if you're only using it in just one file but it is a more organized style.
Today at 03:24:49 AM
post Re: SSTC Micro
Today at 03:24:20 AM
Rowdy
Today at 03:23:33 AM
Today at 03:06:20 AM
Today at 01:33:47 AM
post MMC for a 32kvac load
Rowdy
Today at 01:02:34 AM
Rowdy
May 24, 2020, 11:47:26 PM
post Re: GDT cable specs
May 24, 2020, 11:09:44 PM
Rowdy
May 24, 2020, 10:39:45 PM
May 24, 2020, 09:55:49 PM
May 24, 2020, 09:55:48 PM
May 24, 2020, 08:16:40 PM
thecyberman
May 24, 2020, 05:38:27 PM
Rowdy
May 24, 2020, 02:33:55 PM
hip424
May 24, 2020, 02:31:39 PM
iraquois
May 24, 2020, 02:08:53 PM
May 24, 2020, 12:12:36 PM
May 24, 2020, 07:56:21 AM
May 24, 2020, 03:09:57 AM
May 23, 2020, 10:24:55 PM
May 23, 2020, 09:30:29 PM
post GDT cable specs
May 23, 2020, 09:06:39 PM
May 23, 2020, 08:22:59 PM
May 23, 2020, 07:47:49 PM
May 23, 2020, 07:41:41 PM
iraquois
May 23, 2020, 02:09:26 PM
May 23, 2020, 12:46:23 PM
May 23, 2020, 04:14:52 AM
May 22, 2020, 01:15:36 AM
May 21, 2020, 11:55:37 PM
May 21, 2020, 07:46:28 PM
May 21, 2020, 09:15:57 AM
May 21, 2020, 06:35:31 AM
May 21, 2020, 05:23:40 AM
May 21, 2020, 12:16:04 AM
May 20, 2020, 11:22:34 PM
May 20, 2020, 12:15:43 PM
May 19, 2020, 02:08:20 PM
May 19, 2020, 12:05:51 PM
May 19, 2020, 11:49:02 AM
May 19, 2020, 09:26:06 AM
May 19, 2020, 07:55:54 AM
May 19, 2020, 01:55:11 AM
May 18, 2020, 11:54:27 PM
May 18, 2020, 10:10:09 PM
May 18, 2020, 10:05:14 PM
May 18, 2020, 09:03:11 PM
May 18, 2020, 07:50:08 PM
May 18, 2020, 04:15:16 PM
hip424
May 18, 2020, 03:13:14 PM
