Author Topic: g10 disk  (Read 187 times)
Offline thedoc298
g10 disk
« on: March 27, 2020, 11:11:41 PM »
I have a srsg made with a g10 disk I got it aligned fairly good but how can you true one up without a lathe. Or does anybody provide that service or sell already made disk. I would love to buy one or have someone true up mine. This disk is the hardest part of the whole project. I Would pay any price.
« Last Edit: March 27, 2020, 11:16:42 PM by thedoc298 »
Offline ritaismyconscience
Re: g10 disk
« Reply #1 on: March 27, 2020, 11:24:19 PM »
I came up with this idea because I couldn't get a disk too.
Haven't tried it yet, so I don't know if it works or not
Offline thedoc298
Re: g10 disk
« Reply #2 on: March 28, 2020, 12:06:44 AM »
Mine works and is synchronous but I know its out of round, little vibration and I wan't perfection or close . That is what im looking at now the propeller style. Looks like would be easier to balance and much less load on the motor.   Wish I had a lathe, maybe I will find an old buddy with one. Im ready to fire, just have to set the firing to the mains.  Thanks for the picture.
« Last Edit: March 28, 2020, 12:45:02 AM by thedoc298 »
Re: g10 disk
« Reply #3 on: March 28, 2020, 04:50:34 AM »
When I made my G10 disk I didn't have a lathe but I figured out a way to make a very true disc. You need a rotary die grinder which is like a big Dremel tool. A Dremel tool is probably not powerful enough.
I assume that you have already roughed out the shape of the disc. Mount your disc to your motor exactly as you will be using it. Firmly attach the motor mount to a test stand. Make a holder for your die grinder so that it can be firmly attached to the same test stand that is holding your motor. Use the die grinder to slowly remove material from the disc circumference as you slowly rotate the disc by hand. As you remove material, move the die grinder closer to the disc. Eventually you will end up with a perfectly round disc if everything is mounted securely. I would do this outdoors as you will be creating a lot of harmful fiberglass dust. Also wear a mask.
Re: g10 disk
Today at 03:24:49 AM
post Re: SSTC Micro
Today at 03:24:20 AM
Rowdy
Today at 03:23:33 AM
Today at 03:06:20 AM
Today at 01:33:47 AM
post MMC for a 32kvac load
Rowdy
Today at 01:02:34 AM
Rowdy
May 24, 2020, 11:47:26 PM
post Re: GDT cable specs
May 24, 2020, 11:09:44 PM
Rowdy
May 24, 2020, 10:39:45 PM
station240
May 24, 2020, 09:55:49 PM
May 24, 2020, 09:55:48 PM
May 24, 2020, 08:16:40 PM
thecyberman
May 24, 2020, 05:38:27 PM
Rowdy
May 24, 2020, 02:33:55 PM
hip424
May 24, 2020, 02:31:39 PM
iraquois
May 24, 2020, 02:08:53 PM
May 24, 2020, 12:12:36 PM
May 24, 2020, 07:56:21 AM
May 24, 2020, 03:09:57 AM
May 23, 2020, 10:24:55 PM
May 23, 2020, 09:30:29 PM
post GDT cable specs
May 23, 2020, 09:06:39 PM
May 23, 2020, 08:22:59 PM
May 23, 2020, 07:47:49 PM
May 23, 2020, 07:41:41 PM
iraquois
May 23, 2020, 02:09:26 PM
May 23, 2020, 12:46:23 PM
May 23, 2020, 04:14:52 AM
post Re: New projet OmegaDR
May 22, 2020, 01:15:36 AM
Mugi30
May 21, 2020, 11:55:37 PM
May 21, 2020, 07:46:28 PM
Mugi30
May 21, 2020, 09:15:57 AM
May 21, 2020, 06:35:31 AM
May 21, 2020, 05:23:40 AM
May 21, 2020, 12:16:04 AM
May 20, 2020, 11:22:34 PM
May 20, 2020, 12:15:43 PM
May 19, 2020, 02:08:20 PM
Mugi30
May 19, 2020, 12:05:51 PM
May 19, 2020, 11:49:02 AM
May 19, 2020, 09:26:06 AM
May 19, 2020, 07:55:54 AM
May 19, 2020, 01:55:11 AM
May 18, 2020, 11:54:27 PM
Mugi30
May 18, 2020, 10:10:09 PM
Mugi30
May 18, 2020, 10:05:14 PM
May 18, 2020, 09:03:11 PM
May 18, 2020, 07:50:08 PM
May 18, 2020, 04:15:16 PM
hip424
May 18, 2020, 03:13:14 PM
