Author Topic: Strange GDT signals (need to help)  (Read 568 times)
Offline VNTC
« on: May 23, 2019, 02:19:24 AM »
My GDT signals look like Marty’s case (loss 1 signal of the pair UCC . .)
The images shows that matter. I cannot fix yet.
The output signals of them only in positive side because they run parallel in 1 bus 12v.(scope one by one to ground)
Combine signals at output A and output B (scope from A and B) will be double amplitude but still only in positive side. Only going through coupling capacitor and GDT it will be 2 sides positive and negative, but the ripples appear here ( image 1). My coil can run but 1 serious trouble comes when I try to run the coil in primary feedback mode.
Guys, please help!
Thank so much. good look!
Offline Phoenix
Re: Strange GDT signals (need to help)
« Reply #1 on: May 23, 2019, 11:55:27 AM »
Hello
Are you feeding a 0V/+V signal into your GDT? A GDT is a transformer and you can't run them with 0/12V. If you try to do that, the zero line shifts as we can see in the first scope shot. You need to supply a symmetrical waveform, for example -12V/+12V. If the area under the waveform isn't the same above and below the zero v line, it begins to shift due to core saturation.
Greetings
« Last Edit: May 23, 2019, 11:58:57 AM by Phoenix »
Offline VNTC
« Reply #2 on: May 24, 2019, 03:39:48 AM »
Hi Phoenix,
I apply Steve’s schematic for my circuit in image 5
C5 and reactance of GDT cause this ripples include input capacitance of IBGT but
I don’t know the gate signals that Marty reply me, why it is so beautiful like that?
quote (Marty)
Here is output signal (which is going into gate of 1 IGBT):
Thank you!
« Reply #3 on: May 24, 2019, 08:44:40 PM »
Again, you need a bigger transformer core, or more turns.
Offline VNTC
« Reply #4 on: May 25, 2019, 03:28:26 AM »
Hi  T3sl4co1l,
Thank you for your reply
I used 6.5mmx13.5mm cross section core and winding 26 turns of wire may be higher double of turns than before,the result of the test look like no change as these images
 May I ask you upload your GDT signals at output side? I don’t understand why the wave form of Marty has not any ripple at the front and the rear of the burst pulses length?
« Last Edit: May 25, 2019, 04:42:20 AM by VNTC »
Offline FilipŠebík
« Reply #5 on: May 25, 2019, 12:00:32 PM »
Wind your core like this
https://k2av.com/FCP_XFMR_RED_GREEN_WINDINGS.cred.gif
and redo the test
Online Fumeaux
« Reply #6 on: May 25, 2019, 03:54:13 PM »
I found a video that helped me when getting started with sstcs: https://www.youtube.com/watch?v=gZXYpAr_T0A
He explains a few things surrounding gdts and where to get cores. I have to add that for a drsstc you should have a better gdt than what he is aiming at.
Some thing you should think about:
  • good core (there have been some examples already, I used the B64290L0674X830, there are many more good ones)
  • wire (some people used ethernet cable, I don't like that, I used solid core PVC wire, the cheap one, and twisted 4-6 x2 lengths together before winding)
This is my latest gdt. It uses a core out of an old car amplifier, which seems to work fine.
The primary side is double wound, while the mosfet/igbt end is just single. Both white wires are primary and the red ones are the two igbt ends.
For finetuning you might want to check this page out http://www.richieburnett.co.uk/temp/gdt/gdt2.html
« Last Edit: May 25, 2019, 07:45:50 PM by Fumeaux »
« Reply #7 on: May 25, 2019, 07:28:38 PM »
Is that green core even ferrite?
Protip: don't take pictures so close your camera can't focus on them!
Offline VNTC
« Reply #8 on: May 26, 2019, 01:23:29 AM »
Hi Tim,
Yes, it is  ferrit core!
« Reply #9 on: May 26, 2019, 08:29:35 PM »
Hi Tim,
There are many types of ferrite! Do you know what material type it is? If you are not sure of this, you have to buy one with a permeability around 5000, +/- 2000 range if you can not find one exactly near 5k, just to rule out you are not trying to do something impossible with a wrong ferrite material type.
Today at 07:27:46 PM
Today at 06:56:20 PM
Today at 05:08:06 PM
Today at 01:35:58 PM
Today at 05:54:23 AM
post Re: Blast from the past!
Today at 05:05:55 AM
post Re: UD2.7 Gate Signals
coilinator
post Blast from the past!
September 17, 2019, 05:00:47 PM
September 17, 2019, 06:48:38 AM
post Re: My second DRSSTC
erdal
September 16, 2019, 11:07:27 PM
post Re: 750W solar offgrid 24V/150Ah battery setup with Victron charger
September 16, 2019, 09:48:37 PM
AlexanderHun
September 16, 2019, 10:42:44 AM
September 16, 2019, 09:40:27 AM
September 16, 2019, 09:28:43 AM
September 16, 2019, 09:24:17 AM
September 16, 2019, 06:59:12 AM
September 16, 2019, 04:18:26 AM
September 16, 2019, 02:49:28 AM
September 16, 2019, 02:43:18 AM
September 16, 2019, 02:36:17 AM
September 16, 2019, 02:26:40 AM
September 16, 2019, 01:50:19 AM
coilinator
September 15, 2019, 08:22:47 PM
erdal
September 15, 2019, 02:09:17 PM
AlexanderHun
September 15, 2019, 10:39:29 AM
September 14, 2019, 07:01:28 PM
AlexanderHun
September 14, 2019, 06:59:13 PM
AlexanderHun
September 14, 2019, 06:43:15 PM
September 14, 2019, 06:35:32 PM
post Homemade HV transformer
AlexanderHun
September 14, 2019, 05:05:00 PM
September 14, 2019, 04:50:10 PM
coilinator
September 14, 2019, 08:42:55 AM
post Re: Transistors good for DRSSTC?
September 13, 2019, 05:50:53 AM
September 12, 2019, 12:47:03 PM
September 12, 2019, 11:07:39 AM
post Re: "karma", "applause/smite" button meaning and use
September 12, 2019, 11:01:05 AM
September 12, 2019, 08:44:48 AM
post Transistors good for DRSSTC?
September 12, 2019, 05:53:51 AM
September 12, 2019, 05:37:11 AM
post "karma", "applause/smite" button meaning and use
September 12, 2019, 05:07:24 AM
post Re: Why did 4HV die??
September 12, 2019, 04:50:24 AM
post Drsstc 4, I'm never stopping
September 12, 2019, 02:36:00 AM
September 12, 2019, 12:34:10 AM
September 11, 2019, 09:29:40 PM
September 11, 2019, 09:00:31 PM
coilinator
September 11, 2019, 07:54:30 PM
freq_out
September 11, 2019, 05:40:14 PM
