Author Topic: Easy access to optimal resonance frequency but the benefit is quite small  (Read 273 times)
Offline VNTC
After finished winding the secondary coil we can immediate determine the optimal resonance frequency of a tesla coil.
Used this formula:
Fo=3000000/(L*4)  Fo= optimize resonance frequency
L= length of wire in m
For example :
A coil 1050turns; 9cm diameter
L=1050*9*π=296.8m
L*4=1187.2m
Fo=300000/1187.2=252.7kHz
I have done the test with this coil ruing at a deviation 28% of this frequency and this is the result:
Toroi d   Frequency       Input power   Burst duration   Spark length
20cm   Fr=250kHz   240V/2A        100us               100%
40cm   Fr=180kHz   240V/1.6A         100us                 90%
Fr =RF radiation frequency measure by 5cm antenna with a distance from discharge wire.
Although the difference is not large, but it is a reality exists it reflects exactly the 1/4λ principal in the illustrated picture: with the difference of 180/250 = 72 %( compared to the original reference)
1/4λ=90 degree
¼λ*.72=64.8 degree
Sin 90=1 amplitude =1
Sin 64.8=.9 amplitude =.9
Power is proportional with V*V
Spark length proportional with square root of power output so it is proportional with amplitude V. (last column)
With deviation 28% of frequency will drop 10% of spark length, which is a weak affect so we can say: λ/4 rule is not important role in Tesla coil, hhowever  it is still better to apply it because it is not harmful
« Last Edit: May 21, 2019, 11:38:18 PM by VNTC »
Offline dexter
I've seen a paper about calculating the self capacitance of a solenoid and in one of the methods they used the self resonance frequency, measured inductance and the length of wire to calculate the self capacitance.
but in their calculation they used l=λ/2 (l= length of wire)
i'm confused... which formula λ/2 or λ/4 describe the self resonance of a solenoid?
Offline VNTC
Hi Dexter,
Thank you for your reply please read the qote following you will see something.
  Quote:
   Tesla was not the first to invent this circuit.[21][15] Henry Rowland built a spark-excited resonant transformer circuit (above) in 1889[2] and Elihu Thomson had experimented with similar circuits in 1890, including one which could produce 64 inch (1.6 m) sparks,[9][22][23] [1] and other sources confirm     Tesla was not the first.[14][24][15] However he was the first to see practical applications for it and patent it. He even realized that the secondary coil functioned as a quarter-wave resonator; he specified the length of the wire in the secondary coil must be a quarter wavelength at the resonant frequency.[25][8]
A coil with the balance shape will working ok on a wide range of frequency my testing coil can run with toroid 40cm to 15cm with the different 10% only at power out.(180kHz-275kHz)
Today at 07:27:46 PM
Today at 06:56:20 PM
Today at 05:08:06 PM
Today at 01:35:58 PM
Today at 05:54:23 AM
post Re: Blast from the past!
Today at 05:05:55 AM
post Re: UD2.7 Gate Signals
coilinator
post Blast from the past!
September 17, 2019, 05:00:47 PM
September 17, 2019, 06:48:38 AM
post Re: My second DRSSTC
erdal
September 16, 2019, 11:07:27 PM
post Re: 750W solar offgrid 24V/150Ah battery setup with Victron charger
September 16, 2019, 09:48:37 PM
AlexanderHun
September 16, 2019, 10:42:44 AM
September 16, 2019, 09:40:27 AM
September 16, 2019, 09:28:43 AM
September 16, 2019, 09:24:17 AM
September 16, 2019, 06:59:12 AM
September 16, 2019, 04:18:26 AM
September 16, 2019, 02:49:28 AM
September 16, 2019, 02:43:18 AM
September 16, 2019, 02:36:17 AM
September 16, 2019, 02:26:40 AM
September 16, 2019, 01:50:19 AM
coilinator
September 15, 2019, 08:22:47 PM
erdal
September 15, 2019, 02:09:17 PM
AlexanderHun
September 15, 2019, 10:39:29 AM
September 14, 2019, 07:01:28 PM
AlexanderHun
September 14, 2019, 06:59:13 PM
AlexanderHun
September 14, 2019, 06:43:15 PM
September 14, 2019, 06:35:32 PM
post Homemade HV transformer
AlexanderHun
September 14, 2019, 05:05:00 PM
September 14, 2019, 04:50:10 PM
coilinator
September 14, 2019, 08:42:55 AM
post Re: Transistors good for DRSSTC?
September 13, 2019, 05:50:53 AM
September 12, 2019, 12:47:03 PM
September 12, 2019, 11:07:39 AM
post Re: "karma", "applause/smite" button meaning and use
September 12, 2019, 11:01:05 AM
September 12, 2019, 08:44:48 AM
post Transistors good for DRSSTC?
September 12, 2019, 05:53:51 AM
September 12, 2019, 05:37:11 AM
post "karma", "applause/smite" button meaning and use
September 12, 2019, 05:07:24 AM
post Re: Why did 4HV die??
September 12, 2019, 04:50:24 AM
post Drsstc 4, I'm never stopping
September 12, 2019, 02:36:00 AM
September 12, 2019, 12:34:10 AM
September 11, 2019, 09:29:40 PM
September 11, 2019, 09:00:31 PM
coilinator
September 11, 2019, 07:54:30 PM
freq_out
September 11, 2019, 05:40:14 PM
