Author Topic: QCWDRSSTC - Project Build  (Read 412 times)
Online ZakW
  • YouTube @QZW_Labs
« on: July 06, 2024, 01:55:14 AM »
Hello,
Creating this thread to chronicle my QCWDRSSTC project!
Currently, I am working on copying and recreating a lot of loneoceans' designs (credit goes to him!). Also, shout out to @Magneticitist on YouTube for documenting his builds so far; they have all been really helpful.
BrickDriver v1.1 schematic https://www.loneoceans.com/labs/sales/brickdriver/SchematicBrickDriver11.png
Loneoceans write up on the BrickDriver https://www.loneoceans.com/labs/sales/brickdriver/index.htm
HCPL-316J (2.5 Amp Gate Drive Optocoupler) Datasheet https://www.mouser.com/datasheet/2/678/av02-0717en_ds_hcpl-316j_2015-03-09-1827931.pdf
Like I said, I am creating my own schematics and PCBs. It would be great to get some feedback to ensure I understand everything correctly.
First up is the buck modulator schematic. I have opted to simplify the original design (BrickDriver v1.1) a bit and decided not to use the DESAT and FAULT capabilities of the HCPL-316J for this first build. I know they are valuable, but I am just trying to wrap my head around all of this at first. Referencing the datasheet, I think I have wired the HCPL-316J correctly to disable those two functions:
Schematic concerns:
If I understood the datasheet correctly, that should be all that is need to allow the IC to function without shutting down due to DESAT or FAULT conditions.
The initial PCB layout is almost finalized, just waiting to receive more parts to make sure everything fits nicely.
In the meantime I have also been working on a new secondary, topload, and MMC. I still need to coat the secondary and 3D print the primary coil form. I will likely copy a similar design to loneoceans 1.5 build since the coil is 2.5inches tall and needs some clearance from the topload.
-Zak
Offline Simranjit
Re: QCWDRSSTC - Project Build
« Reply #1 on: July 06, 2024, 02:20:14 AM »
May I ask what is material for toroid core you used in buck modulator?
Online ZakW
  • YouTube @QZW_Labs
« Reply #2 on: July 06, 2024, 02:37:16 AM »
I had my eye on the same one you mentioned in your post https://www.digikey.com/en/products/detail/magnetics-a-division-of-spang-co/0079908A7/18626744. I was hoping to see a reply to your post to help me figure out if it would work or not.
« Reply #3 on: July 06, 2024, 04:09:50 AM »
There's no way to know if this is a "good" core or not without knowing the rest of your buck design.  The most important factors are maximum ramp current (peak buck output current), buck switching frequency, and buck input voltage.  Inductor needs to handle maximum ramp current plus peak buck ripple current.  Ripple current depends on inductance, frequency, and voltage.
Offline Simranjit
« Reply #4 on: July 06, 2024, 04:53:56 AM »
Thank you for clarification. It will get back to you in few weeks hopefully ☺️. Still trying to learn.
Online ZakW
  • YouTube @QZW_Labs
« Reply #5 on: July 07, 2024, 12:44:53 AM »
Dave,
I am planning to copy Loneoceans QCW 1 pretty closely. For the buck modulator I am going to use two FGA40N65SMD in parallel https://www.mouser.com/datasheet/2/308/1/FGA40N65SMD_D-2313142.pdf. 650v 120A peak.
Parameters:
Buck smoothing capacitor: 500V, 25µF
Frequency: 30 kHz
Peak Current: 150 A (100A normal)
Peak Voltage: 340 V (300V normal)
Pulse Duration: 20ms MAX
Target Inductance: 112.4uH
Saturation Flux Density: 1 T (using 2 stacked Magnetics 0079908A7 cores)
https://www.mag-inc.com/Media/Magnetics/Datasheets/0079908A7.pdf
For these calculations I used online calculators as well as ChatGPT... Not trusting ChatGPT I checked its math with calculators and it seemed to be accurate. However, there was a large discrepancy with max flux density calculation. I included what ChatGPT said and how its calculation varied from what the calculator was doing.
Given that either calculation is below 1T, that means that I should be fine to use two stacked 0079908A7 cores, right?
Picture looks blurry, just have to right-click and open in a new tab.
« Last Edit: July 07, 2024, 12:46:26 AM by ZakW »
Offline Anders Mikkelsen
« Reply #6 on: July 07, 2024, 02:52:19 PM »
Try to figure out how to do the calculations yourself, this will give you a useful skill and is more likely to give a correct result.
For powder cores, talking about saturation flux density is a bit vague, since these materials saturate very gradually, over a range of currents. So the flux density you design with depends on how much inductance you can afford to lose at the operating current. This involves some design tradeoffs, since the ripple current and buck transistor turn-off losses will increase as the inductance drops, but there's otherwise nothing wrong with running the inductors well into the saturation region. I've done designs where there's less than 20 % of initial inductance at some operating points.
My recommended method is to look at the curves in the core datasheet, permeability vs ampere turns. Simply multiply your turns count by your operating current, and you can read out how much inductance you have left. For the core you proposed, 39 turns and 150 A  would give you around 14 nH/n^2 per core, giving a total inductance of 42 µH remaining at this current.
I'd recommend going with a material with better bias characteristics and higher initial permeability, maybe XFlux 40 or 60, but your proposed solution should work as it is. I would for example consider 25 turns on a 00X6527E040 core pair. This would give you 143 µH at zero bias down to 47 µH at 150 A. Overall cost would be lower, and you would also likely get a lower overall DC resistance.
The HCPL-316J is not ideal for the buck gate drive, since it has mediocre common-mode transient immunity (15 V/ns can be problematic with modern IGBTs) and is pretty expensive to boot.  If you don't need the desaturation detection, I would look at parts like UCC5390 or UCC25313.
Online ZakW
  • YouTube @QZW_Labs
« Reply #7 on: July 07, 2024, 09:39:07 PM »
Hello Anders,
Thanks for the feedback and input!
That's the goal :)
Thank you for detailed explanation. There is a lot I still don't understand and inductors are top on that list. This helped a lot though. I like the idea of using the core you suggested since it is not only cheaper but will be easier to wind. Here is what I gather from looking at the datasheet:
Walking through what you said to make sure I understand and so that I have it for reference: Please correct me if I'm wrong.
Zero bias meaning no DC current is flowing, so if I measured it with an LCR meter at 25 turns it would read ~143uH.
When a DC current is applied (bias), the core's magnetic flux increases, which causes its permeability to decrease, leading to lower overall inductance. Hence the graph, which can tell you approximately how much more inductance the core has before saturating.
Given the core high permeability I can afford to wind fewer turns using thicker wire to achieve less resistance losses that I would otherwise have due to increase turns.
Thanks for sharing these! Not sure how I missed the UCC5390, cheaper and provides 10A gate drive.
This is new to me as well. "15 V/ns means the driver can handle voltage changes of 15 volts per nanosecond without malfunctioning.. it can lead to erroneous switching or damage.".
Looking at the datasheet for the UCC5390ECDR https://www.mouser.com/ProductDetail/Texas-Instruments/UCC5390ECDR?qs=BZBei1rCqCCYvNb%2F7TMRZA%3D%3D it looks like it has transient immunity of 100-120 V/ns.
Since it can source 10A, I don't think I will be needing the buffer stage, and I don't plan on driving huge bricks. This is also just the first version and I can always add it later if I need more drive current.
Here is my updated schematic:
-Zak
« Reply #8 on: July 08, 2024, 12:49:48 AM »
Hello Anders,
That's the goal :)
It might have come across as a bit hars from my side, but seeing chatbots get things wrong and people trusting them just rubs me the wrong way. Glad to hear that you have the right motivations.
Spot on.
These chips are a game changer for gate drive. Full galvanic isolation, and better output drive capability and transient immunity than most gate drive transformer based options. I use them for both hard-switched converters, tesla coils and induction heater, without issues. There are also half bridge versions with overlap protection, automatic dead-time insertion and other fancy features.
Transient immunity is the rate of change of voltage across the device that it can tolerate without giving invalid output. For a high side driver, the gate driver sees large common mode transients during switching as the output is connected to the switching node while the driver input is referenced to power or signal ground. To a first approximation, the common mode dV/dt is simply the bus voltage divided by the turn-off and turn-off time. The IGBTs you mentioned switch in around 15 ns, so with a bus voltage of 400 V you get close to 30 V/ns. With superjunction MOSFETs and wide bandgap transistors like SiC, it's easy to exceed 50 V/ns.
In an asynchronous buck converter, unintended turn-on is not necessarily a disaster, but it can lead to some ugly glitches and additional losses. It's a lot worse if it happens in a half bridge where the opposite transistor might be on. I now always try to use parts with a minimum of 100 V/ns CMTI, and never had any problems since doing that, even with fast wide bandgap transistors.
[attachment=2,msg21708]
-Zak
It should be good enough here without an additional driver stage :)
Online ZakW
  • YouTube @QZW_Labs
« Reply #9 on: July 08, 2024, 01:37:55 AM »
No offense taken, you're correct though. I use ChatGPT as an enhanced search engine, never taking what it says as correct. It has been really helpful in providing more context into certain topics and has help me to understand a lot more. I was trying to do use its calculations and fact check them with online tools to see if the answers were close, as well as check with knowledgeable people here.
Awesome! That is good to know, I think I will start using these more often. That makes sense then why I see some coils that have unstable ramps, I wonder if it could be due to transient noise causing unintended turn-ons and glitches in the ramp output.
Excellent!
I ordered some fiber transmitters/recievers, fiber, and that core. Will have more updates to come.
post Re: Problem with SSTC
Nunu00
July 12, 2024, 10:17:36 PM
post Making a HV prove
July 12, 2024, 09:01:08 PM
July 12, 2024, 01:33:37 AM
Nunu00
July 12, 2024, 12:17:32 AM
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
ColinHeath
July 11, 2024, 06:08:30 PM
July 11, 2024, 12:24:56 PM
July 11, 2024, 06:42:23 AM
Cameron Prince
July 11, 2024, 05:46:07 AM
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
July 09, 2024, 07:37:22 PM
MechatEng2023
July 09, 2024, 07:30:05 PM
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
July 08, 2024, 03:46:49 AM
July 08, 2024, 02:42:00 AM
Sebigamer
July 08, 2024, 12:53:08 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
MechatEng2023
July 07, 2024, 11:04:43 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
July 07, 2024, 10:02:22 AM
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 05, 2024, 11:50:37 PM
July 05, 2024, 10:07:04 PM
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
July 04, 2024, 11:02:32 PM
post Phase lead inductors
July 04, 2024, 06:28:08 PM
July 04, 2024, 12:31:40 AM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
July 03, 2024, 08:48:13 PM
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
Alex_1996
July 03, 2024, 02:47:18 PM
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
July 02, 2024, 11:29:18 PM
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
July 02, 2024, 05:22:10 AM
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
