Author Topic: capacitor and diodes. Voltage values for a CW  (Read 1495 times)
Offline Alberto
« on: March 22, 2024, 11:45:03 PM »
Hello. I´m making a CW multiplier. I want it to last, so I´m carefull with the values.
I´m using 40Kv 1nF capacitors and 2 20kv diodes in series. It will have 9 stages and I´n going to put in in a pipe filled with paraffin oil.
I don´t wat to put in more than 10kV AC 20 kHz, so what do you think of the voltage of the capacitos and the diodes?
Thank you
Re: capacitor and diodes. Voltage values for a CW
« Reply #1 on: March 23, 2024, 04:20:03 AM »
Those look like very workable values. You may want to go higher in frequency. Use this calculator to try out some designs.
https://www.extremeelectronics.co.uk/calculators/cw-voltage-calculator/
Offline Alberto
« Reply #2 on: March 23, 2024, 01:38:34 PM »
Thank you for your answer and the link, it is very useful.
My idea it is to put 10 stages to keep at minimum the voltage input.
I'm going to run a high frequency 300watts transformer with a ZVS. The gates are powered by an independent power supply and the rest of the circuit with a variable power supply, so I can vary the output. Is that a good idea? I mean in terms of voltage and current output and safety of the components.
I need to check the voltages at the secondary of the HF transformer, but I think with just 1 or 2 volts at the primary I can get around 1 or 2 kV at the secondary, so starting with around 40kV at the CW and more
Thank you
« Reply #3 on: March 23, 2024, 03:04:25 PM »
My CW multiplier sounds very similar in concept to yours. You may want to take a look at my posting detailing my device here.
https://highvoltageforum.net/index.php?topic=1524.0
One problem with using a ZVS driver is that the input voltage output has to be at least around 10 volts before you apply power otherwise the transistors may latch-up and burn out. Once you have it oscillating you can then vary the input voltage to change the output voltage. Just be certain that you don't let the input voltage fall below about 10 volts.
Offline Alberto
« Reply #4 on: March 23, 2024, 04:34:31 PM »
Yours look amazing!! And a very good finishng.
I'm not sure about what you say of the 10 volts input..I'm using this circuit
First I put 12volts in point A. And them y put between 1 or 12 volts in the red square. Is that what you mean
« Reply #5 on: March 23, 2024, 09:30:21 PM »
Yes. You want at least 10 volts at point "A" from the DC power supply before you switch the power to the ZVS driver. I use a minimum of 12 volts just to be safe.
Offline Alberto
« Reply #6 on: March 23, 2024, 10:47:35 PM »
Thanks for your answer.
Yess I learnt that in this forum some time ago asking about a ZVS for an induction heater.
And another question. About measuring the output of the HF transformer. Could I do it using a bridge rectifier (HV diodes), capacitor to filter and a voltage divider using HV resistors? Let's say 260Megaohms. What should be the value of tha capacitor?
I use a basic needle voltmeter because my DMMs are cheap and got crazy measuring these things so I think it is a good idea to use a capacitor to know the peak value of the output. And should I use in the output of the transformer (I have some HV caps if around 10nf) or I can do it in the output of the voltage divider which would allow me to use a regular capacitor ?
« Last Edit: March 23, 2024, 11:34:32 PM by Alberto »
« Reply #7 on: March 24, 2024, 04:25:23 AM »
Look further down in the comments of the link to my CW multiplier that I supplied. I describe the method that I used to measure the HV output of the flyback transformer using a full-wave bridge rectifier, smoothing capacitor, and a COTS HV DC voltmeter.
« Last Edit: March 24, 2024, 03:24:40 PM by MRMILSTAR »
Offline Alberto
« Reply #8 on: March 24, 2024, 07:36:32 PM »
Even to just measure the transformer output you make a neat and clean set up!!
Thanks for your answer. My concern is about the reduction of the voltage. I see you are using a HV probe right? I made a DIY probe with 10x 26Mohm resistor for a 1000:1 ratio. So can I use it with a 2nF capacitor to obtain the measurement of the peak voltage?
Offline Alberto
« Reply #9 on: March 27, 2024, 10:54:52 PM »
And another questión. I´m going to use one 24V power supply. I have put a 220ohm resistor in point A to use the 24Volts directly. And to power the ZVS driver, I put in the 24V power supply a DC-DC converter to vary the output. There is no problem taking the current for the gates and to power de ZVS from the same power supply right?
I have instaled a relay that allow to power the ZVS only when the gates are already with the 24volts to be safe.
Thabk you
« Reply #10 on: March 28, 2024, 04:18:27 AM »
I don't know what the purpose of the resistor is. You may have trouble with the DC-DC converter. You are cascading two SMPSs. At the minimum, the DC-DC converter must be capable of supplying sufficient current, probably at least 10 amps. I would try and find a single adjustable SMPS.
« Reply #11 on: March 28, 2024, 04:45:07 AM »
Yes, that should work well.  Presuming the existing 470ohm gate pull-up resistors are rated for 2 watts as listed in schematic, they will handle 24V directly.  No need for 220-ohm resistor to reduce power.  As a bonus, with 24V directly to gate resistors the FETs will switch faster so dissipate a bit less power.  Removing 220-ohm resistor also increases startup oscillation amplitude before relay closes, making startup even a bit more reliable.
Offline Alberto
« Reply #12 on: March 28, 2024, 01:01:12 PM »
Thank for your answer
I added the 220 ohm resistor because de 470 ohm resistor, despite being 2watts get too hot and they where close to the MOSFETs in the PCB.
Since I'm going to enclose everything, I'm going to remove the 470 ohm resistor from the PCB and put th near the fan what pull the air from.the enclosure and they will get cooler
Offline Alberto
« Reply #13 on: April 05, 2024, 09:59:30 PM »
Done! I had an accident with the cyanocrilate and the lid is a mess, but is sturdy
You can turn the pipe to obtain a positive or negative output
The worst part what making the lids of the pipe. Some acrylic sheets glued and later lathe and drill press. M3 screws in 5mm thick acrylic. A bit of silicone to seal it and paraffin oil.
I need to increase the output of the HF transformer. It is ran by a ZVS and 5+5 turns in the primary. Should I put 4+4 or 3+3? If I´m correct that should increase the output rigt? But does it affect to the current of the output?
Thank you
« Reply #14 on: April 06, 2024, 05:22:06 AM »
Looks great. You have to experiment with the number of turns and the capacitance. I would start with 5+5. What kind of output do you get?
Offline Alberto
« Reply #15 on: April 06, 2024, 10:02:04 AM »
I tried to measure the voltage like you but I don't know why it doesn't work. But with 5+5 turns and a 16volts input the arcs in the secondary of the HF transformer starts at let's say 5 or 6mm so I think it is 5 or 6kv peak
post Re: What's an alternative to those dubious high voltage generators from Amazon?
Today at 11:48:32 AM
post Re: CM300 Half bridge coil build log
Today at 07:48:18 AM
post Re: Watercooling
Today at 07:39:32 AM
Today at 07:37:00 AM
Today at 07:18:27 AM
post Watercooling
Today at 07:13:48 AM
post High Voltage from LG Microwave Inverter
GLaDOS
Today at 04:11:30 AM
Jj
Today at 12:01:04 AM
April 27, 2024, 09:51:08 PM
April 27, 2024, 04:20:46 PM
Jj
April 27, 2024, 01:39:29 PM
post What's an alternative to those dubious high voltage generators from Amazon?
Devil Master
April 27, 2024, 05:32:59 AM
post Re: Tesla coil UV eye protection?
April 26, 2024, 08:46:40 PM
April 25, 2024, 06:30:43 PM
April 25, 2024, 06:14:35 PM
April 25, 2024, 05:13:46 PM
April 25, 2024, 11:40:08 AM
April 25, 2024, 06:01:50 AM
April 25, 2024, 05:55:45 AM
April 25, 2024, 05:47:36 AM
April 25, 2024, 05:45:36 AM
April 25, 2024, 05:41:05 AM
April 25, 2024, 04:33:57 AM
April 24, 2024, 08:02:47 PM
April 24, 2024, 06:51:17 PM
April 24, 2024, 06:45:00 PM
April 24, 2024, 05:18:27 PM
April 24, 2024, 05:14:27 PM
huntergroundmind
April 24, 2024, 02:51:23 PM
post Re: First DRSSTC SKM100
April 24, 2024, 05:58:27 AM
post Tesla coil UV eye protection?
April 24, 2024, 05:17:22 AM
post Re: Tenebrescent Potassium Iodide
April 24, 2024, 12:39:59 AM
April 23, 2024, 11:07:41 PM
April 23, 2024, 10:57:39 PM
OmGigaTron
April 23, 2024, 09:33:49 PM
April 23, 2024, 06:00:42 PM
April 23, 2024, 03:50:49 AM
April 23, 2024, 03:13:31 AM
April 23, 2024, 12:50:40 AM
April 22, 2024, 11:21:06 PM
April 22, 2024, 08:11:00 PM
April 22, 2024, 06:15:30 PM
April 22, 2024, 05:52:50 PM
post Tenebrescent Potassium Iodide
April 22, 2024, 05:52:13 PM
April 22, 2024, 04:31:52 PM
April 22, 2024, 04:05:34 PM
April 22, 2024, 01:02:30 PM
April 22, 2024, 06:32:35 AM
April 22, 2024, 06:24:10 AM
post M2000NM1 toroid for gdt tesla coil
April 22, 2024, 05:13:15 AM
April 22, 2024, 02:25:29 AM
April 22, 2024, 02:09:18 AM
April 22, 2024, 12:14:21 AM
April 21, 2024, 09:47:15 PM
April 21, 2024, 08:34:02 PM
April 21, 2024, 06:09:57 PM
April 21, 2024, 06:21:54 AM
post Re: Insulate the secondary of the Tesla coil with a PET plastic bottle
April 21, 2024, 06:18:30 AM
April 21, 2024, 06:12:31 AM
April 21, 2024, 05:19:55 AM
April 21, 2024, 02:29:17 AM
April 21, 2024, 01:28:59 AM
post Insulate the secondary of the Tesla coil with a PET plastic bottle
April 21, 2024, 01:19:44 AM
April 21, 2024, 12:55:25 AM
April 20, 2024, 11:25:32 PM
April 20, 2024, 10:28:26 PM
April 20, 2024, 10:23:28 PM
April 20, 2024, 10:06:44 PM
April 20, 2024, 09:21:55 PM
April 20, 2024, 09:16:14 PM
April 20, 2024, 08:58:40 PM
April 20, 2024, 06:18:26 PM
April 20, 2024, 06:15:26 PM
April 20, 2024, 03:45:43 PM
April 20, 2024, 06:33:37 AM
April 20, 2024, 05:45:04 AM
April 20, 2024, 05:34:16 AM
April 20, 2024, 04:50:57 AM
April 20, 2024, 04:03:55 AM
April 20, 2024, 02:35:56 AM
Bobakman
April 19, 2024, 09:37:52 PM
April 19, 2024, 09:20:10 PM
April 19, 2024, 07:22:26 PM
April 19, 2024, 04:46:36 PM
April 19, 2024, 03:49:28 PM
Bobakman
April 19, 2024, 01:53:57 PM
April 19, 2024, 05:24:19 AM
Tesla Junior
April 19, 2024, 04:24:09 AM
April 19, 2024, 04:20:35 AM
Bobakman
April 19, 2024, 04:05:28 AM
April 19, 2024, 04:03:54 AM
April 19, 2024, 03:19:19 AM
April 19, 2024, 03:09:29 AM
April 19, 2024, 01:47:37 AM
Bobakman
April 19, 2024, 12:19:21 AM
April 18, 2024, 11:33:01 PM
Bobakman
April 18, 2024, 11:15:15 PM
April 18, 2024, 10:59:36 PM
April 18, 2024, 10:03:48 PM
April 18, 2024, 09:53:25 PM
