Author Topic: Platter resistance & inductance  (Read 818 times)
« on: December 08, 2019, 11:41:00 AM »
Here are some estimates of self-inductance and resistance of HDD platters, posted for review.
Based on Wheeler's formula, basic electrical conductance, and simple finite-element analysis using the FEMM program.
A similar investigation for crushable beverage cans, done more then 10 years ago, never got reported.
The test disk diameters are the same as in a recent post under Sense Coil Fabrication.
To play nicely with Wheeler's formula, inside and outside diameters are 1 and 3 inches, so the mean radius and "winding width" are both 1 inch.
As a 1-turn coil (N=1), the inductance by Wheeler's formula is 1/19 uH, or 52.6 nH.
The shorted-turn resistance is 201 micro-ohms
, if 0.05 inches thick and made of 6061-T6 alloy at 20 degrees C.
(conductor length =  2 pi inches, area 0.05 in^2, conductivity 24.59 MS/m.)
The L/R time constant is 262 us; that's how fast a circulating current would decay if there were nothing to keep it going.
Corresponding corner frequency is 608 Hz, so at frequencies far above that the disk behaves like an inductor.
Doubling the metal thickness, to 0.10 inches, would halve the resistance and not (per Wheeler) change the inductance.
So R = 101 u-ohm, L/R = 523 us, corner frequency 304 Hz.
The effective R values could be slightly larger because of skin effect in the aluminum alloy.
For 100, 1000, and 10000 Hz, I figure skin depth of 0.4", 0.13", 0.04" ( 10, 3.2, 1.0 mm).
Just starting to be significant for single HDD platters.
Here's a representative picture from a FEMM run with 0.04" thick disk, declared as 50 turns:
For other values of N, other than 1 which seems to be a problem case, the indicated L and R values are proportional to N^2.
In this case L = 126 uH (50.4 nH for single turn), which is 96% of that according to Wheeler.
R is 0.629 ohms (251 u-ohm for single turn), exactly matching the simple resistance computation above.
For what it's worth, the inductance (flux linkage per ampere) in FEMM simulation was closer to the Wheeler formula for thinner disks.
« Last Edit: December 08, 2019, 12:02:33 PM by klugesmith »
May 05, 2021, 10:30:49 PM
May 05, 2021, 10:13:16 PM
May 05, 2021, 08:29:59 PM
May 05, 2021, 07:03:25 PM
May 05, 2021, 06:57:17 PM
May 05, 2021, 06:38:06 PM
May 05, 2021, 06:02:21 PM
May 05, 2021, 04:51:47 PM
Rapy2
May 05, 2021, 01:03:30 PM
May 05, 2021, 12:21:48 PM
Rapy2
May 05, 2021, 11:17:11 AM
May 05, 2021, 11:04:35 AM
May 05, 2021, 09:47:58 AM
May 05, 2021, 09:40:40 AM
May 05, 2021, 12:01:57 AM
May 04, 2021, 09:48:43 PM
May 04, 2021, 09:02:34 PM
May 04, 2021, 07:17:08 PM
Rapy2
May 04, 2021, 11:19:14 AM
post Re: Flashover
May 04, 2021, 09:56:30 AM
May 04, 2021, 01:50:12 AM
post Flashover
May 04, 2021, 01:24:10 AM
Rapy2
May 04, 2021, 12:57:12 AM
Rapy2
May 04, 2021, 12:34:29 AM
May 03, 2021, 10:08:05 PM
SimonNwardUK
May 03, 2021, 10:07:26 PM
May 03, 2021, 09:38:30 PM
May 03, 2021, 07:29:14 PM
markus
May 03, 2021, 06:20:47 PM
Rapy2
May 03, 2021, 04:02:39 PM
Rapy2
May 03, 2021, 01:19:51 PM
May 03, 2021, 12:43:48 PM
May 03, 2021, 08:16:19 AM
May 03, 2021, 08:14:37 AM
May 03, 2021, 04:18:29 AM
May 03, 2021, 04:16:35 AM
Rapy2
May 02, 2021, 11:55:57 PM
May 02, 2021, 11:32:39 PM
post Re: Prototype boards
May 02, 2021, 09:20:23 PM
May 02, 2021, 09:15:02 PM
May 02, 2021, 08:36:18 PM
Lilsara21
May 02, 2021, 08:03:03 PM
May 02, 2021, 07:48:15 PM
May 02, 2021, 07:45:41 PM
May 02, 2021, 07:37:08 PM
May 02, 2021, 07:35:46 PM
May 02, 2021, 04:52:01 PM
post Prototype boards
May 02, 2021, 04:27:33 PM
May 02, 2021, 03:46:12 PM
May 02, 2021, 03:39:45 PM
