Author Topic: Help needed - which IGBT module to buy  (Read 373 times)
Offline thedoc298
« on: July 22, 2021, 07:01:24 PM »
I am ready to buy some IGBT's. I have seen the cm300 and cm600 and only need the cm300 for now. Is their something newer I should get instead of 2 cm300.
Or any advice, just want something that will have a little kick.  Also on ebay, found the price of 40 bucks to 100 bucks for the cm300's     What is a good price or should I spend the money on something better. Thanks
edit: thread title should describe what is offered for discussion
« Last Edit: July 23, 2021, 07:03:37 PM by futurist »
Re: IGBT question
« Reply #1 on: July 22, 2021, 08:47:23 PM »
You could look at the list of used IGBT bricks at the bottom of this article: https://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/igbts/
Generally I have said that 300A bricks should be around 20-30$ a piece for a half-bridge module and double the price for a 600A. Times are changing, either its harder to find the good old CM300/600, so it might get more expensive, but on the other hand, as you ask, is there a better alternative?
I would look for "300A IGBT half-bridge module" on ebay and look at results matching fewer words: https://www.ebay.co.uk/sch/i.html?_from=R40&_nkw=300a+igbt+half-bridge+module&LH_PrefLoc=2
A problem with more modern modules is that they get more integrated with protective circuits, active gate drive, built in chopper circuits and is generally 3-phased modules. Maybe it even comes in stupid pressure fit packages like "Skiip" or with multiply pin header connectors with 20A going through each and the use 10 per power leg.
The good old CM300, we know what we get :)
Offline thedoc298
Re: IGBT question
« Reply #2 on: July 22, 2021, 10:59:32 PM »
Thanks for the feedback, I have your list printed out. Just did not want to make any purchasing mistake, like, " oh you should have bought these."  Thanks, still learning
Anyone know of a safe place to buy the cm300, plenty from china. I want accouple of em, just to play with.
« Last Edit: July 23, 2021, 11:12:58 AM by Mads Barnkob »
Offline thedoc298
Re: IGBT question
« Reply #3 on: July 23, 2021, 05:33:57 PM »
I have been looking at IGBT's and I think I have settled on these skm400GB128D at the link below.
They have a lot of numbers with them, and Im not sure if they will work or maybe not even at all, seen skm's on Madd's list, but different numbers. Just don't want to waist money.
If these don't have any gotchas, let me know. Going little dizzy looking for something.
Thanks for your time.
Just seen the skm400gb125d about 50 bucks a piece, going to pull the trigger and get a pair, they look ok with my limited igbt knowledge. If you see any problems with this choice please let me know.
https://www.aliexpress.com/item/32860625233.html?spm=a2g0o.detail.1000060.3.aed52aaeWHcgaG&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=032e7738-2bab-4c6f-a065-546ee8b7fc8c&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:032e7738-2bab-4c6f-a065-546ee8b7fc8c,tpp_buckets:668%230%23131923%2361_668%230%23131923%2361_668%23888%233325%2316_668%23888%233325%2316_668%232846%238109%231935_668%235811%2327190%2395_668%236421%2330830%23801_668%232717%237567%23906_668%231000022185%231000066059%230_668%233468%2315616%23756_668%232846%238109%231935_668%235811%2327190%2395_668%236421%2330830%23801_668%232717%237567%23906_668%233164%239976%23870_668%233468%2315616%23756&&pdp_ext_f=%257B%2522scene%2522%253A%25223339%2522%257D
« Last Edit: July 23, 2021, 06:28:50 PM by thedoc298 »
Re: IGBT question
« Reply #4 on: July 23, 2021, 07:02:18 PM »
Please don't start multiple threads for the same question
Before starting a thread use the search option on the forum to find out if it has been discussed before
You could find your answer if you for example read Mads DRSSTC guide on his website
You didn't even write for what you would use IGBT modules, CM300 and CM600 are suited for different applications
Offline thedoc298
Re: IGBT question
« Reply #5 on: July 23, 2021, 08:05:58 PM »
I have read mads guide several times, and did search this and many other sites. I did not start something new, because I thought I would get yelled at, did anyway.
I have read the site rules and ask for clarification like what was said above. I know you can't babysit, I guess im just not smart enough for you folks. Won't screw up your site anymore.
Re: IGBT question
Today at 09:51:49 PM
post Re: Tesla plate
Today at 09:18:43 PM
Today at 09:16:36 PM
post Re: Idea for QCW DRSSTC
Today at 08:53:36 PM
Today at 06:49:45 PM
Today at 05:34:54 AM
post Tesla plate
post Re: Large Rectifier Tube
Chrisader
post Idea for QCW DRSSTC
