Author Topic: ZVS long cable freq stabilization  (Read 159 times)
Offline kreasteve
« on: June 20, 2021, 02:56:13 AM »
Hi all, I'm new here and to high voltage.
I wanted to build a weed killer. By the way it already exists: https://zasso.com/
Take a look on my picture. (Test with external 24V/400W supply)
I bought a ZVS from Austria with a flyback transformer, improved the heat stability and built some parts around it, included two 1.5m long 40kV unshielded cables. The building process isn't finished: Safety circuits, frontpanel and a few other things are in development.
The problem is, that the generated frequency (normally 15kHz as you might expect) turns to 75kHz if both long cables are connected. I think there is some capacitive coupling over the ground. Can I somehow stabilize the freqency?
Other things I want to say:
-The three parallel SMPS are not the best way to produce ripple free voltage. But they are laying around.
-I should have started with highvoltage earlier. Its very interesting as I notices during the tests. A tesla coil is on my ToDo list.
Tanks in advance!
Best
Steven
Re: ZVS long cable freq stabilization
« Reply #1 on: June 24, 2021, 04:22:34 PM »
Try more capacitance across the primary?  Idunno, it's a dumb oscillator (if it's the usual simple circuit), it can do whatever it wants, and transformers are complex networks with many characteristic frequencies.
Offline kreasteve
« Reply #2 on: June 24, 2021, 05:02:17 PM »
Hi Tim,
thanks for your reply!
Yes the frequency of the ZVS depends on the load.
I had allready tried double the capacity.
I'm going to build an H-Bridge on my own to enforce the frequency I want.
Steven
Today at 11:13:18 AM
Today at 10:08:34 AM
Today at 03:20:42 AM
Today at 03:16:27 AM
July 23, 2021, 09:23:11 PM
post Re: IGBT question
July 23, 2021, 08:05:58 PM
July 23, 2021, 07:02:18 PM
July 23, 2021, 05:33:57 PM
GKnapp
July 23, 2021, 04:51:37 PM
July 23, 2021, 03:52:46 AM
July 22, 2021, 10:59:32 PM
GKnapp
July 22, 2021, 08:50:34 PM
July 22, 2021, 08:47:23 PM
July 22, 2021, 07:01:24 PM
July 22, 2021, 06:50:07 AM
July 22, 2021, 06:39:37 AM
July 21, 2021, 07:55:03 PM
GKnapp
July 21, 2021, 06:34:13 PM
[DSLR]
July 21, 2021, 05:10:18 PM
July 21, 2021, 12:42:29 PM
Chrisader
July 21, 2021, 08:15:00 AM
July 21, 2021, 04:57:04 AM
July 21, 2021, 03:50:33 AM
July 21, 2021, 01:50:19 AM
Chrisader
July 20, 2021, 10:06:14 PM
July 20, 2021, 06:24:29 PM
July 20, 2021, 05:37:36 AM
July 20, 2021, 05:08:24 AM
[DSLR]
July 20, 2021, 04:43:05 AM
[DSLR]
July 20, 2021, 12:09:36 AM
July 19, 2021, 11:13:13 PM
Maverikie
July 19, 2021, 08:56:04 PM
newage
July 19, 2021, 07:09:56 PM
[DSLR]
July 19, 2021, 06:49:08 PM
July 19, 2021, 04:39:05 PM
[DSLR]
July 19, 2021, 06:32:35 AM
July 19, 2021, 05:22:51 AM
newage
July 19, 2021, 04:24:38 AM
eli
July 19, 2021, 12:35:18 AM
July 19, 2021, 12:15:43 AM
post a typical sstc half bridge design, any considerations or tips?
eli
July 18, 2021, 11:44:03 PM
eli
July 18, 2021, 09:33:40 PM
July 18, 2021, 09:07:15 PM
July 18, 2021, 03:38:01 PM
post Best and stable version of video
Transgarp
July 18, 2021, 03:33:31 PM
post Sync RSG motor problems - help and thoughts needed
newage
July 18, 2021, 01:30:46 PM
post Re: DRSSTC design advise / Primary peak current calculation
July 17, 2021, 10:05:39 AM
July 16, 2021, 11:01:43 PM
Martin
July 16, 2021, 09:55:50 AM
July 16, 2021, 09:54:50 AM
