Author Topic: Nice PC Board Tesla  (Read 362 times)
Offline alan sailer
Nice PC Board Tesla
« on: June 10, 2021, 07:46:12 PM »
I have run across several printed circuit secondary tesla coils on the web and this is the first that I found impressive.
https://circuitsalad.com/2021/05/30/high-output-pcb-spiral-tesla-coil/
And for all those builders bragging about their primary height to spark length ratios, this one has a ratio of about 6,000x :-)
Cheers.
Re: Nice PC Board Tesla
« Reply #1 on: June 11, 2021, 12:03:24 PM »
That's really impressive output :D
Got me interested in trying building it
Offline Da_Stier
« Reply #2 on: June 11, 2021, 12:33:55 PM »
Looks impressive indeed.
I find it interesting, how a standard PCB handles the isolation of the secondary voltage.
Would be interesting to see if this performance can be achieved for a long time or only for short pulses, before the PCB fails.
EDIT:
I saw the video and therefore also the Epoxy layer on top of the PCB.
However I still find it interesting how the 6 mil spacing between the windings is enough to prevent arcing on the copper layer.  :o
« Last Edit: June 11, 2021, 09:04:21 PM by Da_Stier »
« Reply #3 on: June 12, 2021, 04:20:53 AM »
He trusts his test equipment, using a stack of three instruments as the ground target for sparks.
With an ECB secondary, it would be possible to adjust winding spacing vs. radius.  Outer turns have higher volts/turn, so could be spaced a bit farther apart.
Offline Twospoons
« Reply #4 on: June 12, 2021, 08:47:08 AM »
Based on some work I did with pcb coils for Qi chargers, he could improve the primary by splitting it into many thin parallel tracks - but they would need to be "twisted" 180 degrees half way around the loop in order to balance the impedances of the individual tracks so they share current better. This would entail vias and short tracks on the secondary side in order to create the swap over, but a liberal epoxy coat should protect them.
With a single wide track the current tends to flow at the edges - and may even flow backwards along one edge under some conditions, which just wastes power. Based on my simulations in Ansys Maxwell.
Offline Da_Stier
« Reply #5 on: June 12, 2021, 10:06:18 AM »
I would have sweated blood if it was my equipment, I'm always totally paranoid about something being damaged from my coil.
Greetings,
Michael
Today at 10:13:23 PM
SalinsLV
Today at 03:04:47 PM
Today at 02:42:57 PM
Today at 12:37:52 PM
Today at 12:21:54 PM
SalinsLV
Today at 10:47:22 AM
Today at 10:15:43 AM
Today at 06:37:46 AM
Today at 04:25:03 AM
Power-Max
Today at 03:29:32 AM
Today at 02:18:39 AM
Today at 01:23:42 AM
Today at 12:58:41 AM
July 25, 2021, 10:15:30 PM
July 25, 2021, 06:16:53 PM
Chrisader
July 25, 2021, 04:16:11 PM
July 25, 2021, 05:38:42 AM
July 25, 2021, 02:15:25 AM
July 24, 2021, 11:38:33 PM
July 24, 2021, 11:29:15 PM
July 24, 2021, 10:41:38 PM
July 24, 2021, 09:18:42 PM
July 24, 2021, 08:08:36 PM
July 24, 2021, 11:13:18 AM
July 24, 2021, 10:08:34 AM
July 24, 2021, 03:20:42 AM
July 24, 2021, 03:16:27 AM
July 23, 2021, 09:23:11 PM
post Re: IGBT question
July 23, 2021, 08:05:58 PM
July 23, 2021, 07:02:18 PM
July 23, 2021, 05:33:57 PM
GKnapp
July 23, 2021, 04:51:37 PM
July 23, 2021, 03:52:46 AM
July 22, 2021, 10:59:32 PM
GKnapp
July 22, 2021, 08:50:34 PM
July 22, 2021, 08:47:23 PM
July 22, 2021, 07:01:24 PM
July 22, 2021, 06:50:07 AM
July 22, 2021, 06:39:37 AM
July 21, 2021, 07:55:03 PM
GKnapp
July 21, 2021, 06:34:13 PM
[DSLR]
July 21, 2021, 05:10:18 PM
July 21, 2021, 12:42:29 PM
Chrisader
July 21, 2021, 08:15:00 AM
July 21, 2021, 04:57:04 AM
July 21, 2021, 03:50:33 AM
July 21, 2021, 01:50:19 AM
Chrisader
July 20, 2021, 10:06:14 PM
July 20, 2021, 06:24:29 PM
July 20, 2021, 05:37:36 AM
