Author Topic: What is the guidence on SpaceX rockets based on ? PID's?  (Read 429 times)
Offline Patrick
  • Mechatronics Technician, A.S.
« on: June 05, 2021, 03:52:13 AM »
Are the vertical recoveries were seeing based on PID loops?
My Professor insists so.
If its too bright just squint more.
Re: What is the guidence on SpaceX rockets based on ? PID's?
« Reply #1 on: June 05, 2021, 05:56:54 AM »
I think you can get the "best" idea from BPS.SPace on youtube or this paper I just found on google: https://project-archive.inf.ed.ac.uk/msc/20172139/msc_proj.pdf
The conclusion on the paper is that the basic PID presents the best landing performance, but highest fuel consumption. It was also my own idea that they were using some kind of model prediction or gain scheduling. I doubt a PID with 3 static settings could do the job :)
There is also a lot of speculation and interesting links to papers in this thread: https://www.reddit.com/r/spacex/comments/4ewrpq/why_classical_control_for_the_rockets_control/ f.ex. to JPL G-FOLD system descriptions: https://www.lpi.usra.edu/meetings/marsconcepts2012/pdf/4193.pdf
« Last Edit: June 05, 2021, 06:02:54 AM by Mads Barnkob »
Offline Patrick
« Reply #2 on: June 12, 2021, 07:03:10 AM »
Ok done more research and desperately want to understand this stuff:
Also, is it possible to have two PID's in series ?
« Reply #3 on: June 12, 2021, 07:28:03 PM »
Yes that is called cascaded. But that is even harder to control, due dead time from the first is likely a 2.order system and adding that to another PID will result in a 3 or 4.order system. Tuning gets harder as change on any of the PID affect the process, but its hard to evaluate on which PID parameters is optimal.
Offline Patrick
« Reply #4 on: June 16, 2021, 07:33:15 AM »
Ok thats what I thought, ganging things up often makes them goofy.
But with a common quad copter do you think its possible to have a separate PID for roll pitch and yaw ? or would they continuously interfere with each other ?
Offline Twospoons
« Reply #5 on: June 16, 2021, 10:20:30 AM »
Since roll, pitch and yaw are, in theory, orthogonal, then yes you can have independent PIDs for each. In practice you would have to ensure your gyros are aligned correctly, or there will be some cross-coupling that will have the PID's fighting each other.
Offline Patrick
« Reply #6 on: June 18, 2021, 02:48:57 AM »
Is it possible to, based on real time flight data, change the P, I, and D values of a loop to predetermined values know to be more ideal at a particular region?
For instance,
At Angle 42 degrees, speed equal or less than 11m/s P 4.2, I 0.0, D 1.1
At angle 11  degrees, speed greater that 11m/s P 3.7, I 0.1, D 0.7
And so on....
I would plot a g(x) nonlinear function for a micro-controller to execute. like a lookup table.
 or parallel P(x), I(x), D(x) curves all plotted for the micro-controller to pull from using real time air data from Pitot probe/ gps/ interial data streams.
« Reply #7 on: June 18, 2021, 07:48:01 PM »
In regular automation PID we call that "gain scheduling" and is often used in process startup scenarios or to run with different settings in winter/summer.
You could also look into feed-forward PID if you want a short of "prediction" to not solely rely the process value changing, but you take into account the change of the input variable that will affect the process value.
Today at 10:13:23 PM
SalinsLV
Today at 03:04:47 PM
Today at 02:42:57 PM
Today at 12:37:52 PM
Today at 12:21:54 PM
SalinsLV
Today at 10:47:22 AM
Today at 10:15:43 AM
Today at 06:37:46 AM
Today at 04:25:03 AM
Power-Max
Today at 03:29:32 AM
Today at 02:18:39 AM
Today at 01:23:42 AM
Today at 12:58:41 AM
July 25, 2021, 10:15:30 PM
July 25, 2021, 06:16:53 PM
Chrisader
July 25, 2021, 04:16:11 PM
July 25, 2021, 05:38:42 AM
July 25, 2021, 02:15:25 AM
July 24, 2021, 11:38:33 PM
July 24, 2021, 11:29:15 PM
July 24, 2021, 10:41:38 PM
July 24, 2021, 09:18:42 PM
July 24, 2021, 08:08:36 PM
July 24, 2021, 11:13:18 AM
July 24, 2021, 10:08:34 AM
July 24, 2021, 03:20:42 AM
July 24, 2021, 03:16:27 AM
July 23, 2021, 09:23:11 PM
post Re: IGBT question
July 23, 2021, 08:05:58 PM
July 23, 2021, 07:02:18 PM
July 23, 2021, 05:33:57 PM
GKnapp
July 23, 2021, 04:51:37 PM
July 23, 2021, 03:52:46 AM
July 22, 2021, 10:59:32 PM
GKnapp
July 22, 2021, 08:50:34 PM
July 22, 2021, 08:47:23 PM
July 22, 2021, 07:01:24 PM
July 22, 2021, 06:50:07 AM
July 22, 2021, 06:39:37 AM
July 21, 2021, 07:55:03 PM
GKnapp
July 21, 2021, 06:34:13 PM
[DSLR]
July 21, 2021, 05:10:18 PM
July 21, 2021, 12:42:29 PM
Chrisader
July 21, 2021, 08:15:00 AM
July 21, 2021, 04:57:04 AM
July 21, 2021, 03:50:33 AM
July 21, 2021, 01:50:19 AM
Chrisader
July 20, 2021, 10:06:14 PM
July 20, 2021, 06:24:29 PM
July 20, 2021, 05:37:36 AM
