Author Topic: Primary Frequency too High  (Read 218 times)
Offline alan sailer
« on: April 22, 2021, 06:52:48 PM »
I am trying to troubleshoot a DRSSTC. It's a small coil using SKM100, full bridge and it designed
to run at about 120KHz. I'm using the UD2.7C thru-hole board.
The problem I am trying to figure out is that the coil is oscillating at about twice the
expected frequency. The SKM100s are not happy and the drain current (such as it is) looks like
a triangle wave. I am running the coil at a buss voltage of about 60 volts to troubleshoot the thing.
The buss voltage is generated through a Variac driving a doubler.
I've built a fair number of coils and they have all started at near the design frequency. I have
measured the tank cap and the primary inductance using a DE-5000 LCR meter and they are all within
5% of the expected value. Even a basic LC resonance calculation says that I should be getting 120KHz.
EDIT:
I decided to disconnect the FB transformer and drive the UD2.7C directly with a signal generator. Set it at 120KHZ and 500mVpk-pk.
The bridge drives the primary just dandy with a textbook current and voltage waveform. I'm even getting
little bitty sparks from the secondary/toroid. So the bridge works, the UD2.7C works. And since I got oscillations when I attch the FB transformer
I think the transformer is functioning.
Cheers.
« Last Edit: April 23, 2021, 12:08:06 AM by alan sailer »
Re: Primary Frequency too High
« Reply #1 on: April 23, 2021, 01:19:19 AM »
Have you tried reversing CT phase?  That would be my guess.
Offline alan sailer
« Reply #2 on: April 23, 2021, 01:27:18 AM »
Dave,
Crapping crud. It works.
I know my knowledge of coils is shallow but I though it was binary. Get the phase wrong, nothing. Get the phase right, bingo.
So can you, for a me being a dunderhead, explain why?
If not, much thanks anyhow. You made my afternoon. I was ready to go to an astrologer.
Cheers.
« Reply #3 on: April 23, 2021, 05:55:46 AM »
With reversed CT connection you are starting with 180 degrees phase shift, exactly out of phase.  At 240kHz your driver and IGBTs have enough delay (additional phase lag) to total close enough to 360 degrees to oscillate.
One possible contributing factor is if you don't have phase-lead enabled on your UD2.7 driver.  Adjusting phase lead for ideal switching at 120kHz (H-Bridge outputs switching just before current zero-crossing) would likely preclude enough lag at 240kHz for reverse-CT oscillation.
Offline alan sailer
« Reply #4 on: April 23, 2021, 03:51:31 PM »
Dave,
Thanks for the explanation. It makes sense to me and is something a lot more subtle than my basic SSTC
knowledge covers. It also explains why I have not seen this problem in any of my previous SSTC builds
(two QCW and one conventional, all full bridge). I was just lucky.
The phase shift inductor was in place but at this point I have no idea if it is the right value.
Once again thanks. I am not sure that I would have ever figured it out given my basic understanding
of FB.
Cheers.
« Reply #5 on: April 24, 2021, 08:04:58 PM »
Alan,
You are certainly welcome.  Great to hear that it made sense.
May 05, 2021, 10:30:49 PM
May 05, 2021, 10:13:16 PM
May 05, 2021, 08:29:59 PM
May 05, 2021, 07:03:25 PM
May 05, 2021, 06:57:17 PM
May 05, 2021, 06:38:06 PM
JCF
May 05, 2021, 06:02:21 PM
May 05, 2021, 04:51:47 PM
Rapy2
May 05, 2021, 01:03:30 PM
May 05, 2021, 12:21:48 PM
Rapy2
May 05, 2021, 11:17:11 AM
May 05, 2021, 11:04:35 AM
Miki_407
May 05, 2021, 09:47:58 AM
JCF
May 05, 2021, 09:40:40 AM
May 05, 2021, 12:01:57 AM
Miki_407
May 04, 2021, 09:48:43 PM
May 04, 2021, 09:02:34 PM
JCF
May 04, 2021, 07:17:08 PM
Rapy2
May 04, 2021, 11:19:14 AM
post Re: Flashover
May 04, 2021, 09:56:30 AM
May 04, 2021, 01:50:12 AM
post Flashover
May 04, 2021, 01:24:10 AM
Rapy2
May 04, 2021, 12:57:12 AM
Rapy2
May 04, 2021, 12:34:29 AM
kilovolt
May 03, 2021, 10:08:05 PM
SimonNwardUK
May 03, 2021, 10:07:26 PM
May 03, 2021, 09:38:30 PM
May 03, 2021, 07:29:14 PM
May 03, 2021, 06:20:47 PM
Rapy2
May 03, 2021, 04:02:39 PM
Rapy2
May 03, 2021, 01:19:51 PM
May 03, 2021, 12:43:48 PM
May 03, 2021, 08:16:19 AM
May 03, 2021, 08:14:37 AM
May 03, 2021, 04:18:29 AM
May 03, 2021, 04:16:35 AM
Rapy2
May 02, 2021, 11:55:57 PM
May 02, 2021, 11:32:39 PM
post Re: Prototype boards
May 02, 2021, 09:20:23 PM
May 02, 2021, 09:15:02 PM
May 02, 2021, 08:36:18 PM
Lilsara21
May 02, 2021, 08:03:03 PM
May 02, 2021, 07:48:15 PM
May 02, 2021, 07:45:41 PM
May 02, 2021, 07:37:08 PM
May 02, 2021, 07:35:46 PM
May 02, 2021, 04:52:01 PM
post Prototype boards
May 02, 2021, 04:27:33 PM
May 02, 2021, 03:46:12 PM
May 02, 2021, 03:39:45 PM
