Author Topic: UD2.7 Thru Hole  (Read 235 times)
UD2.7 Thru Hole
« on: April 21, 2021, 03:52:44 AM »
I am working on a small DRSSTC (80mm) that is using the UD2.7C thru hole driver. I am having some strange problems that have me quite confused.
The driver tests very well with FB, OCD, LV cutout and gate wave forms all look textbook.
I have a basic question about the circuit. On the PC board the output drive for the GDTs is a single set of terminals.*
I have assumed that the circuit has enough current capability and is intended to drive the two GDTs (full bridge) in parallel.
The gate wave forms look reasonably good so I doubt that this is my problem.
But still it would be nice to know for sure.
* the only other UD2.7 that I have worked with is Loneoceans and it has two GDT outputs.
Re: UD2.7 Thru Hole
« Reply #1 on: April 21, 2021, 08:08:15 PM »
What IGBTs are you driving?
A single GDT with 4 outputs can be enough to drive a SKM200 bridge, that is what I do in my DRSSTC1 with a UD1.3b :)
Re: UD2.7 Thru Hole
« Reply #2 on: April 22, 2021, 02:41:13 AM »
Mads,
Thanks for the reply.
I'm driving a full bridge SKM100.
I have considered doing what you propose but the coils are wound and mounted. I'm pretty
sure my problems are in other areas but I wanted to understand what the intended set-up of the UD2.7C thru-hole was.
Re: UD2.7 Thru Hole
« Reply #3 on: April 24, 2021, 08:57:59 PM »
To finish off this post, it turns out that the problem I was having was not related to the gate drive. The coil is running
(with other problems!) and I can pretty much state that the UD2.7C thru-hole design does drive two GDTs with
inputs in parallel. The outputs are driving a pair of SKM100 in a full bridge connection.
Re: UD2.7 Thru Hole
May 05, 2021, 10:30:49 PM
May 05, 2021, 10:13:16 PM
May 05, 2021, 08:29:59 PM
May 05, 2021, 07:03:25 PM
May 05, 2021, 06:57:17 PM
May 05, 2021, 06:38:06 PM
JCF
May 05, 2021, 06:02:21 PM
May 05, 2021, 04:51:47 PM
Rapy2
May 05, 2021, 01:03:30 PM
May 05, 2021, 12:21:48 PM
Rapy2
May 05, 2021, 11:17:11 AM
May 05, 2021, 11:04:35 AM
Miki_407
May 05, 2021, 09:47:58 AM
JCF
May 05, 2021, 09:40:40 AM
May 05, 2021, 12:01:57 AM
Miki_407
May 04, 2021, 09:48:43 PM
May 04, 2021, 09:02:34 PM
JCF
May 04, 2021, 07:17:08 PM
Rapy2
May 04, 2021, 11:19:14 AM
post Re: Flashover
May 04, 2021, 09:56:30 AM
May 04, 2021, 01:50:12 AM
post Flashover
May 04, 2021, 01:24:10 AM
Rapy2
May 04, 2021, 12:57:12 AM
Rapy2
May 04, 2021, 12:34:29 AM
kilovolt
May 03, 2021, 10:08:05 PM
SimonNwardUK
May 03, 2021, 10:07:26 PM
May 03, 2021, 09:38:30 PM
May 03, 2021, 07:29:14 PM
May 03, 2021, 06:20:47 PM
Rapy2
May 03, 2021, 04:02:39 PM
Rapy2
May 03, 2021, 01:19:51 PM
May 03, 2021, 12:43:48 PM
May 03, 2021, 08:16:19 AM
May 03, 2021, 08:14:37 AM
May 03, 2021, 04:18:29 AM
May 03, 2021, 04:16:35 AM
Rapy2
May 02, 2021, 11:55:57 PM
May 02, 2021, 11:32:39 PM
post Re: Prototype boards
May 02, 2021, 09:20:23 PM
May 02, 2021, 09:15:02 PM
May 02, 2021, 08:36:18 PM
Lilsara21
May 02, 2021, 08:03:03 PM
May 02, 2021, 07:48:15 PM
May 02, 2021, 07:45:41 PM
May 02, 2021, 07:37:08 PM
May 02, 2021, 07:35:46 PM
May 02, 2021, 04:52:01 PM
post Prototype boards
May 02, 2021, 04:27:33 PM
May 02, 2021, 03:46:12 PM
May 02, 2021, 03:39:45 PM
