Author Topic: Drsstc Driver Board for Tesla Coil Driver Optic Fiber Splice  (Read 641 times)
Offline JCF
« on: January 15, 2021, 04:41:47 PM »
Hi, does anyone know the driver below
is this valid for have good performance ? how to use the optical connector HFBR 2521
where I can buy a driver fully equiped with phase correction, OCD, Feed back ?
Thank you
Offline iw1esu
Re: Drsstc Driver Board for Tesla Coil Driver Optic Fiber Splice
« Reply #1 on: January 20, 2021, 01:56:54 PM »
Hi, the same question I have.
I'm asking to all the vendors for schematic and (maybe fantastic) FPGA design to develop on it, I use Altera on high power induction heating frequency converters and this can be a good Hw to avoid shematic design, Pcb and so on
The debug connector seems the standard Altera ByteBlaster Jtag port.
If soneone has any imformation plese post here
There are some version of this board, uses Max II FPGA and one version is in BGA package.
Seems that no vendor knows nothing!
Offline JCF
« Reply #2 on: January 20, 2021, 05:33:54 PM »
hi, about programmation :
"The HighSpeed DRSSTC driver board uses ALTERA MAX II EPM240T100C5N as the main
control chip. Users with certain capabilities can write their own programs and program
the HighSpeed DRSSTC driver board. "
Offline iw1esu
« Reply #3 on: April 13, 2021, 01:44:23 PM »
Seems impossible to find any information or mini user guide to use this board, this brand "cirquiter hardware" produce some boards but seems doesn't exist on the web.
I have received the board, I will test with oscilloscope and signal generator how it drives the inverter gates, manage overcurrent and I will check with Altera Quartus/usb Blaster if Max V  FPGA can be read or is security protected.
If does not work properly or anyway I want to implement a different logic I will start a new design from zero.
If someone has some information about this board (all based on MAX V I suppose similar) is welcome
Offline iw1esu
« Reply #5 on: April 14, 2021, 01:07:11 AM »
Yes I know this post and also another of a guy who has developed on Altera, I have yet written to MrBlack but without succes, and this is a post of 3 years ago.
I think I have to restart from zero, even if readable the fpga is only to backup the code to restore after if necessary
Offline GrantV
« Reply #6 on: April 14, 2021, 11:40:45 AM »
Hi JCF,
The driver I have seen advertised that has good documentation and seems to have a LOT of features is the one from SimpleTesla:
https://simpletesla.ru/en/shop/simpledriver2en/
I have not tested this driver myself but would be very interested in hearing back from anyone who has :-)
The developer also seems to be actively answering questions, unlike every Chinese model, so there is that as a bonus LOL
Offline TMaxElectronics
« Reply #7 on: April 15, 2021, 01:57:49 PM »
Just so you know: the UD3 is using fully programmable and also fully open source hardware and software. And we are always looking for contributors to the project ;)
It uses a psoc5 so even the analog stuff is programmable and the programmer costs like 20$
« Last Edit: April 15, 2021, 02:01:12 PM by TMaxElectronics »
Offline iw1esu
« Reply #8 on: April 18, 2021, 12:26:48 PM »
I have buyed the Cypress eval board CY8CKIT-059 and also some altera EPM240 based board. The initial idea was to start with cypress but I have no experience with this, instead I use Altera Cycolone V Quartus and Nios soft core cpu so more simple for me.
Also I have no clear idea about digital limits of the FPGA inside psoc, I have a lot of ideas to implement and FPGA can be a limit, but the idea to became a developer on Psoc platform intrigues me
About this chinese driver I have obtained a minimal manual, that says... nothing in practice :) but a pinout connection of the Fpga exist.
Download quickly because is a wetransfer link
https://we.tl/t-M72ZlewnfL
First test to connect via Jtag to USB blaster and Quartus programmer failed, device not recognised.. I have to investigate about connector... FPGA connections and so on  :(
May 05, 2021, 10:30:49 PM
May 05, 2021, 10:13:16 PM
May 05, 2021, 08:29:59 PM
May 05, 2021, 07:03:25 PM
May 05, 2021, 06:57:17 PM
May 05, 2021, 06:38:06 PM
JCF
May 05, 2021, 06:02:21 PM
May 05, 2021, 04:51:47 PM
Rapy2
May 05, 2021, 01:03:30 PM
May 05, 2021, 12:21:48 PM
Rapy2
May 05, 2021, 11:17:11 AM
May 05, 2021, 11:04:35 AM
Miki_407
May 05, 2021, 09:47:58 AM
JCF
May 05, 2021, 09:40:40 AM
May 05, 2021, 12:01:57 AM
Miki_407
May 04, 2021, 09:48:43 PM
May 04, 2021, 09:02:34 PM
JCF
May 04, 2021, 07:17:08 PM
Rapy2
May 04, 2021, 11:19:14 AM
post Re: Flashover
May 04, 2021, 09:56:30 AM
May 04, 2021, 01:50:12 AM
post Flashover
May 04, 2021, 01:24:10 AM
Rapy2
May 04, 2021, 12:57:12 AM
Rapy2
May 04, 2021, 12:34:29 AM
kilovolt
May 03, 2021, 10:08:05 PM
SimonNwardUK
May 03, 2021, 10:07:26 PM
May 03, 2021, 09:38:30 PM
May 03, 2021, 07:29:14 PM
May 03, 2021, 06:20:47 PM
Rapy2
May 03, 2021, 04:02:39 PM
Rapy2
May 03, 2021, 01:19:51 PM
May 03, 2021, 12:43:48 PM
May 03, 2021, 08:16:19 AM
May 03, 2021, 08:14:37 AM
May 03, 2021, 04:18:29 AM
May 03, 2021, 04:16:35 AM
Rapy2
May 02, 2021, 11:55:57 PM
May 02, 2021, 11:32:39 PM
post Re: Prototype boards
May 02, 2021, 09:20:23 PM
May 02, 2021, 09:15:02 PM
May 02, 2021, 08:36:18 PM
Lilsara21
May 02, 2021, 08:03:03 PM
May 02, 2021, 07:48:15 PM
May 02, 2021, 07:45:41 PM
May 02, 2021, 07:37:08 PM
May 02, 2021, 07:35:46 PM
May 02, 2021, 04:52:01 PM
post Prototype boards
May 02, 2021, 04:27:33 PM
May 02, 2021, 03:46:12 PM
May 02, 2021, 03:39:45 PM
