Author Topic: High Voltage from LG Microwave Inverter  (Read 207 times)
Offline GLaDOS
« on: April 28, 2024, 04:11:30 AM »
Hello everyone. I salvaged an LG inverter board and wanted to try powering it. Doing some research, I learned Panasonic inverters require a 220Hz square wave on the control pin, so I applied a square wave with 10% duty cycle and then slowly increased duty cycle without success. It seems like LG inverters use a different frequency or another control method? Could someone more knowledgeable provide some insight?
I have also attached annotated images of the PCB, focusing on the input section. There are 2 optocouplers, I assume one provides a feedback to the microwave control board and the other is what controls the power output of the magnetron. You can see how I connected an Arduino generating a 220Hz square wave at variable duty cycle to the anode of the input optocoupler, other end goes through a resistor to ground. Additionally, I tried 1kHz, 5kHz, 10kHz, but with no success. There's probably a specific frequency I need to use. Unfortunately, I am missing the front panel to the logic board, so I am unable to use my scope to figure out the exact control signal used. There's probably a bunch of safety measures, so the board likely won't even send the signal in the first place.
I'm doing all these tests hooked up to a variac providing 120V AC to input. I also noticed sense resistors connected to the output of the bridge rectifier, they go through resistor dividers to the microcontroller, likely used to detect when power is applied. Whats interesting is all the ICs except for the 2L05...(can't read the rest of the letters) are connected to either the 5V regulator or VCC(12V in my tests). The gate driver goes through a P channel MOSFET, which is driven by a BJT going to ground. Microcontroller should pull the base high, pulling the gate to 0V, turning on the MOSFET. This never happens in my tests.
I don't really know what else to do, other then spend an eternity trying different frequencies and duty cycles, which may not even work. I would really appreciate some guidance on how to proceed. Thanks!
Re: High Voltage from LG Microwave Inverter
« Reply #1 on: April 29, 2024, 03:33:58 AM »
  There's no reason to assume the LG control signals resemble the Panasonic ones, in fact you could pretty much guarantee they will be different.
Without a schematic you are flying blind.  Google search on the PCB number turned up nothing.  So unless you want to reverse engineer the thing yourself, you may be better off just using it for parts.
post Re: Help an EE student
Today at 05:59:21 AM
post Re: What capacitor configuration to explode foil?
Today at 05:44:41 AM
Today at 01:55:42 AM
May 17, 2024, 11:49:33 PM
post Re: Pulse Power High Current Discharges from 3 Phase PFC Capacitors
May 17, 2024, 10:18:46 PM
post Pulse Power High Current Discharges from 3 Phase PFC Capacitors
May 17, 2024, 07:24:22 PM
May 17, 2024, 07:14:35 PM
May 17, 2024, 08:35:38 AM
May 17, 2024, 05:34:10 AM
post Re: colored 50 Ohm coax
May 16, 2024, 10:53:53 PM
May 16, 2024, 10:37:50 PM
May 16, 2024, 10:29:30 PM
May 16, 2024, 08:26:41 PM
post Re: Aluminum electrolytic capacitor ripple current issue
May 16, 2024, 06:54:05 PM
May 16, 2024, 05:04:41 PM
post Re: Tesla Synth Player for Syntherrupter
AntoineRcbs
May 16, 2024, 12:13:47 PM
post Re: Help with primary voltages of unknown transformer
Domo
May 16, 2024, 06:58:12 AM
post Re: New EE student asks about Cutting-Edge fields
May 16, 2024, 06:47:09 AM
May 16, 2024, 06:00:49 AM
May 16, 2024, 05:45:08 AM
May 16, 2024, 05:03:41 AM
post Re: DRSSTC grounding issues
May 16, 2024, 04:58:40 AM
May 16, 2024, 04:36:40 AM
May 16, 2024, 12:28:27 AM
post Re: Watercooling
May 15, 2024, 11:13:48 PM
May 15, 2024, 10:58:05 PM
post colored 50 Ohm coax
May 15, 2024, 08:31:48 PM
May 15, 2024, 07:56:38 PM
May 15, 2024, 06:29:59 PM
Felix B.
May 15, 2024, 04:04:14 PM
post Re: Schmitt trigger schematic question
May 15, 2024, 03:32:57 PM
post DRSSTC grounding issues
Felix B.
May 15, 2024, 03:07:39 PM
post New EE student asks about Cutting-Edge fields
samsonwilliams
May 15, 2024, 05:50:59 AM
Domo
May 15, 2024, 05:38:14 AM
May 15, 2024, 04:58:02 AM
post Re: Big Coil Build Log
May 15, 2024, 04:34:49 AM
May 15, 2024, 04:30:18 AM
May 15, 2024, 04:00:55 AM
May 15, 2024, 03:21:51 AM
May 14, 2024, 11:12:22 PM
May 14, 2024, 11:00:00 PM
post Schmitt trigger schematic question
May 14, 2024, 09:45:38 PM
May 14, 2024, 09:02:28 PM
May 14, 2024, 05:55:24 AM
post Re: Weird AC/DC mini SSTC build review
May 14, 2024, 05:44:12 AM
May 14, 2024, 05:11:54 AM
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
post Help with primary voltages of unknown transformer
Domo
May 13, 2024, 08:43:49 PM
May 13, 2024, 07:25:29 PM
OmGigaTron
May 13, 2024, 06:50:59 PM
May 13, 2024, 03:47:08 PM
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
post Re: Quick question about steve ward mini SST5 resonant frequency
May 12, 2024, 05:10:40 PM
post Re: Help with LabCoatz's Staccato QCW DRSSTC Tesla Coil
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
May 12, 2024, 02:51:27 PM
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
post Help with LabCoatz's Staccato QCW DRSSTC Tesla Coil
hal7rr
May 11, 2024, 05:24:34 PM
post Re: Type 77 Metglas Laced Ferrite Core
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
post Type 77 Metglas Laced Ferrite Core
paulp1776
May 11, 2024, 06:23:59 AM
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
post Re: designing and building electron gun help!
May 11, 2024, 12:10:44 AM
post designing and building electron gun help!
Luca c.
May 10, 2024, 09:38:05 PM
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
post Quick question about steve ward mini SST5 resonant frequency
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
May 09, 2024, 03:42:49 PM
May 09, 2024, 03:06:19 PM
May 09, 2024, 01:05:26 PM
May 09, 2024, 09:15:24 AM
