Author Topic: Primary-Strike Protection Grounding Scheme - Insanity?  (Read 3165 times)
Offline nabzim
  • My full name is Adam Baltazar Mizban. Hello there!
    • My YouTube Channel
« on: February 18, 2019, 05:06:18 AM »
OK. So we are all familiar with the standard method of primary-strike protection, that is, connecting the RF-ground to the negative DC Bus via capacitive-coupling...
I have come to the realization, that this does NOT make sense.
If a streamer strikes your primary coil, the streamer-current must travel through one/both of your low-side IGBT's (full bridge), or through your low-side IGBT and/or Bus Capacitor (half bridge) to get from the Primary coil to the -Vbus rail.
Why is it not instead the standard to capacitively-couple the RF-ground directly to the Primary Coil? (a.k.a. the center-point, between high-side and low-side IGBT's)
This would keep the high-energy current from traveling through the semiconductor.
Are my assumptions here correct? If there is any logical reasoning behind the standard grounding-scheme (other than copying Steve Ward), then can someone please educate me? ???
Re: Primary-Strike Protection Grounding Scheme - Insanity?
« Reply #1 on: February 18, 2019, 08:44:19 AM »
Coupling the non-MMC end of the primary would put a significant load on the bridge - take a look at the impedance of the typical coupling caps (e.g. 0.1uF) at the switching frequency. I suspect it would also cause EMI and safety issues, as any current through this capacitor would have to flow via the mains wiring to wherever the earth-neutral bond point is.
Given that the issue doesn't seem to be the strike current (on the order of a few amps only) flowing through the igbts (which have anti parallel diodes included to provide a path when off) but was more about voltage stress between the bridge and heatsink (ground) when hit, the standard method seems to do the trick.
« Reply #2 on: February 18, 2019, 09:25:24 PM »
adding beafy varistors from the primary to ground should increase robustness and a decent strike rail to ground is common practice hear
Offline nabzim
« Reply #3 on: March 06, 2019, 08:33:48 AM »
Thank you. I'm most likely going with the negative rail.
Offline nabzim
« Reply #4 on: March 06, 2019, 08:47:41 AM »
MOV's in addition to the capacitor? and in parallel, I'm assuming?
Grounded strike rail is a certainty! It sure comes in handy on my spark-gap coil: youtu.be/3d4ZDvA5Kcc
Today at 01:01:12 PM
post Re: Big Coil Build Log
Today at 05:47:34 AM
Today at 04:45:07 AM
Today at 04:18:27 AM
post Push Pull VTTC
janno288
Today at 01:10:08 AM
March 27, 2024, 10:54:52 PM
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
March 25, 2024, 02:06:41 PM
post Re: Odd MOSFET Driver Behavior
KrisPringle
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
KrisPringle
March 25, 2024, 12:47:09 AM
March 24, 2024, 07:36:32 PM
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
March 22, 2024, 11:45:03 PM
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
Luca c.
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
Keybored
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
March 17, 2024, 04:15:14 PM
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
post 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 17, 2024, 04:17:51 AM
post Where's all this voltage coming from?
Terry
March 17, 2024, 01:29:32 AM
March 17, 2024, 12:33:06 AM
Keybored
March 16, 2024, 08:46:20 PM
post Re: Bleeder resistor for MMC
March 16, 2024, 08:39:24 PM
March 16, 2024, 08:21:44 PM
