Author Topic: Super flat QCW simulation (does this look reasonable?)  (Read 682 times)
Offline toooldforthis
« on: February 29, 2024, 12:56:32 AM »
Hello, I want to build a super flat QCW coil to fit into a fake book. I'm wondering if my simulation and tunings look reasonable to folks here? The primary is Litz and the secondary will be a 200mm OD flat PCB coil with C0G ceramic caps soldered on the back side to make a secondary resonant tank. I simulated in both the time domain and the frequency domain. I'd like to get secondary impedance higher but I can't physically make the coil any finer on the PCB. I'm running at the lower pole in this simulation as you can see. Any obvious issues before I order boards?
Re: Super flat QCW simulation (does this look reasonable?)
« Reply #1 on: March 13, 2024, 07:04:35 PM »
Here's my continued work on this project (really just documenting it so I don't forget my thinking lol...)
I re-tuned the resonant tanks and decided to switch to the high pole and use a PLL to lock to the high pole. It seems like using a PSFB tends to force the higher pole anyway - I guess due to more energy being present at higher harmonics during low duty cycles. The secondary will now be a flat 250mm spiral using the top and bottom of a PCB to get the resistance lower. My secondary impedance will still be a good deal lower than it would be had I designed with a normal cylindrical winding as everyone else uses. We will see if this causes problems. I'm hopeful it just results in higher secondary losses due to the higher current as well as less streamer detuning.
I simulated this thing and seem to have soft switching on both legs of the bridge? I thought this was not possible? Spice file attached. Currently using CoolMOS C7 as Quorvo models don't want to converge.
I'm about to order the board I think.
« Last Edit: March 13, 2024, 07:10:52 PM by toooldforthis »
« Reply #2 on: March 14, 2024, 05:03:41 AM »
Yes, it is possible and desirable.  With correct dead time phasing, one FET turns off, remaining (small) primary current causes Vds to rise, then opposite FET turns on as its Vds approaches 0V.
Yes, some models have trouble converging, especially IGBT models.  Often the old LTSpice IV converges much better than any version since then.  I use LTSpice IV most of the time.  Haven't found any advantage to newer releases.
« Reply #3 on: March 26, 2024, 11:08:14 PM »
Well the driver board seems to work and the PFC has been designed but not yet ordered. I wrote code for a "WIO Terminal" to output 200kHz PWM that gets low pass filtered into the ramp. The board produces variable phase offsets between its two inputs as you can see in the scope shots below.
I'm using a signal generator to provide a 400kHz reference ATM.
Michelle_
Today at 05:55:24 AM
Michelle_
Today at 05:44:12 AM
Today at 05:11:54 AM
post Re: Help with primary voltages of unknown transformer
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
post Help with primary voltages of unknown transformer
Domo
May 13, 2024, 08:43:49 PM
May 13, 2024, 07:25:29 PM
OmGigaTron
May 13, 2024, 06:50:59 PM
Michelle_
May 13, 2024, 03:47:08 PM
Michelle_
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
Michelle_
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
Michelle_
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
Michelle_
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
Michelle_
May 12, 2024, 02:51:27 PM
Michelle_
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
Michelle_
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
Michelle_
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
Michelle_
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
May 10, 2024, 09:38:05 PM
Michelle_
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
Michelle_
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
Michelle_
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
Michelle_
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
Michelle_
May 09, 2024, 03:42:49 PM
Michelle_
May 09, 2024, 03:06:19 PM
May 09, 2024, 01:05:26 PM
May 09, 2024, 09:15:24 AM
Lasr8
May 09, 2024, 04:45:33 AM
May 09, 2024, 03:56:52 AM
Michelle_
May 09, 2024, 02:16:30 AM
Michelle_
May 09, 2024, 02:00:28 AM
unrealcrafter2
May 09, 2024, 12:48:57 AM
post Re: Capacitor Blowout
radioman
May 08, 2024, 09:04:54 PM
post Question about using mains power and variacs to power this circuit
Michelle_
May 08, 2024, 08:10:41 PM
Michelle_
May 08, 2024, 07:33:43 PM
unrealcrafter2
May 08, 2024, 07:33:31 PM
May 08, 2024, 01:31:28 PM
May 08, 2024, 06:41:48 AM
post Tesla coil amplitude dies after one corona discharge.
Simranjit
May 08, 2024, 05:42:07 AM
Michelle_
May 07, 2024, 06:46:16 PM
post What capacitor configuration to explode foil?
May 07, 2024, 03:51:32 PM
May 07, 2024, 03:20:23 PM
May 07, 2024, 11:00:00 AM
post Aluminum electrolytic capacitor ripple current issue
May 07, 2024, 06:07:48 AM
Michelle_
May 06, 2024, 04:43:19 PM
May 06, 2024, 04:26:44 PM
post Re: Feedback core for Tesla coil
May 06, 2024, 04:24:57 PM
May 06, 2024, 04:20:37 PM
post Feedback core for Tesla coil
Simranjit
May 06, 2024, 04:28:59 AM
May 06, 2024, 02:57:19 AM
May 06, 2024, 02:07:38 AM
Michelle_
May 05, 2024, 11:29:46 PM
May 05, 2024, 10:27:01 PM
May 05, 2024, 10:10:11 PM
Michelle_
May 05, 2024, 08:06:11 PM
post Re: Ferrite material for GDT SSTC/DRSSTC
May 05, 2024, 04:28:35 PM
Michelle_
May 05, 2024, 06:31:32 AM
post Re: Big Coil Build Log
May 05, 2024, 05:48:43 AM
thedark
May 05, 2024, 04:49:39 AM
thedark
May 05, 2024, 04:28:40 AM
May 05, 2024, 03:05:44 AM
May 05, 2024, 02:54:42 AM
post Ferrite material for GDT SSTC/DRSSTC
thedark
May 05, 2024, 02:21:54 AM
Michelle_
May 05, 2024, 01:46:25 AM
post Re: TVS diode vs RCD snubber for protect IGBT peak voltage
May 05, 2024, 12:26:38 AM
thedark
May 04, 2024, 10:48:10 PM
May 04, 2024, 10:40:15 PM
post TVS diode vs RCD snubber for protect IGBT peak voltage
thedark
May 04, 2024, 09:30:32 PM
May 04, 2024, 08:56:27 PM
May 04, 2024, 04:25:00 AM
