Author Topic: Insulate the secondary of the Tesla coil with a PET plastic bottle  (Read 313 times)
Offline thedark
It is possible to do it with a plastic bottle made of PET material such as a soda water bottle, etc., since the polyurethane paint is out of my budget, I have thought about using that bottle and after having the exact dimensions with a hot air gun, shrink the plastic in the secondary and if it does not reach the height, a joint would be made between the two layers with about 5 cm above the other, would it affect anything if I use this plastic?
Re: Insulate the secondary of the Tesla coil with a PET plastic bottle
« Reply #1 on: April 21, 2024, 05:19:55 AM »
The primary purpose of the varnish is to hold the windings together so that they will not fall apart during big temperature changes. The varnish does little to increase the insulation. The coating on the wire does that job. If the wire is double-build or heavy-build, the breakdown voltage can be up to about 10 KV. Since using plastic bottle material won't do anything to secure the windings against temperature changes, I don't see much point in using it. Brush-on varnish isn't expensive. A single small can will easily give you two coats on a secondary coil.
« Reply #2 on: April 21, 2024, 06:12:31 AM »
Interesting idea.  If it would shrink only radially as heat-shrink tubing does, might work well for both insulation and to hold windings in place.  My concern is that I think PET bottles will shrink axially too, which may or may not create a problem.  I could imagine axial shrinking pulling windings out of place and creating overlap.
Depends on thickness.  I'd probably agree for standard air-dry varnish.  Two-part epoxy coatings can be thicker and provide useful insulation.  My DRSSTC has 7 coats of epoxy about 1mm thick each.  Initially had only two coats.  Additional five was a big help in minimizing racing sparks along secondary.
Offline Michelle_
« Reply #3 on: April 21, 2024, 06:18:30 AM »
You can just wrap it with kapton tape, it’s cheap, insulates, and will hold it together. PET has a pretty high melting temperature, so depending on what the secondary is wound on (I’m guessing PVC since that’s what everyone is using) it might degrade that by the time anything happens to the PET.
Today at 07:25:29 PM
Today at 06:50:59 PM
Today at 03:47:08 PM
Today at 03:42:58 PM
Today at 07:09:16 AM
Today at 05:02:46 AM
Today at 02:25:25 AM
Today at 01:39:11 AM
post Re: Plasma Toroid
Today at 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
May 12, 2024, 02:51:27 PM
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
Luca c.
May 10, 2024, 09:38:05 PM
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
May 09, 2024, 03:42:49 PM
May 09, 2024, 03:06:19 PM
May 09, 2024, 01:05:26 PM
May 09, 2024, 09:15:24 AM
Lasr8
May 09, 2024, 04:45:33 AM
May 09, 2024, 03:56:52 AM
May 09, 2024, 02:16:30 AM
May 09, 2024, 02:00:28 AM
May 09, 2024, 12:48:57 AM
radioman
May 08, 2024, 09:04:54 PM
post Question about using mains power and variacs to power this circuit
May 08, 2024, 08:10:41 PM
May 08, 2024, 07:33:43 PM
May 08, 2024, 07:33:31 PM
May 08, 2024, 01:31:28 PM
May 08, 2024, 06:41:48 AM
post Tesla coil amplitude dies after one corona discharge.
May 08, 2024, 05:42:07 AM
May 07, 2024, 06:46:16 PM
post What capacitor configuration to explode foil?
May 07, 2024, 03:51:32 PM
May 07, 2024, 03:20:23 PM
May 07, 2024, 11:00:00 AM
post Aluminum electrolytic capacitor ripple current issue
May 07, 2024, 06:07:48 AM
May 06, 2024, 04:43:19 PM
May 06, 2024, 04:26:44 PM
post Re: Feedback core for Tesla coil
May 06, 2024, 04:24:57 PM
May 06, 2024, 04:20:37 PM
post Feedback core for Tesla coil
May 06, 2024, 04:28:59 AM
May 06, 2024, 02:57:19 AM
May 06, 2024, 02:07:38 AM
May 05, 2024, 11:29:46 PM
May 05, 2024, 10:27:01 PM
May 05, 2024, 10:10:11 PM
May 05, 2024, 08:06:11 PM
post Re: Ferrite material for GDT SSTC/DRSSTC
May 05, 2024, 04:28:35 PM
May 05, 2024, 06:31:32 AM
post Re: Big Coil Build Log
May 05, 2024, 05:48:43 AM
May 05, 2024, 04:49:39 AM
May 05, 2024, 04:28:40 AM
May 05, 2024, 03:05:44 AM
May 05, 2024, 02:54:42 AM
post Ferrite material for GDT SSTC/DRSSTC
May 05, 2024, 02:21:54 AM
May 05, 2024, 01:46:25 AM
post Re: TVS diode vs RCD snubber for protect IGBT peak voltage
May 05, 2024, 12:26:38 AM
May 04, 2024, 10:48:10 PM
May 04, 2024, 10:40:15 PM
post TVS diode vs RCD snubber for protect IGBT peak voltage
May 04, 2024, 09:30:32 PM
May 04, 2024, 08:56:27 PM
May 04, 2024, 04:25:00 AM
May 04, 2024, 04:21:02 AM
May 04, 2024, 01:33:40 AM
May 04, 2024, 01:02:48 AM
May 03, 2024, 11:39:10 PM
May 03, 2024, 10:59:34 PM
May 03, 2024, 09:59:22 AM
post What happened to ArcAttack?
rusirius
May 03, 2024, 02:34:36 AM
May 02, 2024, 05:18:56 AM
post Re: Adjustable High Voltage Electrostatic Precipitator Power Supply with 30KV 300W
dante
May 01, 2024, 10:06:40 PM
