Author Topic: Benjamin's DRSSTC 2 in progress  (Read 3751 times)
Offline Benjamin Lockhart
Re: Benjamin's DRSSTC 2 in progress
« Reply #20 on: March 22, 2024, 03:57:54 AM »
Thanks Dave, I'll do that
Offline thedoc298
« Reply #21 on: March 26, 2024, 01:50:42 AM »
Very nice looking gear, I was wondering on your primary, it looks like your connected to the outer and the inner. How are you moving the tap, as I don't see any.
« Reply #22 on: March 26, 2024, 04:48:22 AM »
You can see the tap point here.
I've mostly finished rebuilding the coil now. Hopefully this aluminum block will be enough heatsinking for the rectifiers.
Making things fit.
I put a few extra CTs on the bridge outputs to check current sharing and it appears to be identical on 2 separate bridge outputs!
« Reply #23 on: May 03, 2024, 10:59:34 PM »
Hi all, Here's an update on this project.
First light was making 7 foot sparks at 100us and 240V in with minimal tuning, but a primary strike and flashover to the bottom secondary turn seems to have killed the FPGA in the UD+.
I suspect that equidrive was a bad idea and the high voltage on the inner primary turn could have caused a spike on the ground line during flashover, but I really don't know.
I've since replaced the driver with a spare for now, reconfigured the MMC for higher primary impedance (now 0.296uF instead of 0.67uF) and no equidrive.
I simply paralleled the bridge outputs.
I also raised the secondary an inch to lower coupling to about .142
Here's the new test run at only half input voltage 340V bus, and 500us on time. It has hit 7 feet now at only 120V in and trips the 20A breaker quickly. There is 240V 50A available  for full power.
I'd like to build a better toroid with less unwanted breakouts before trying 240V in.
« Last Edit: May 03, 2024, 11:04:50 PM by Benjamin Lockhart »
Offline flyingperson23
  • noob :)
« Reply #24 on: May 04, 2024, 01:33:40 AM »
.296uF seems small enough to really limit your current. That also probably makes it sound fuzzier at low bus voltages. I think it'll sound a lot better at full power, especially if you turn up the duty cycle.
« Reply #25 on: May 04, 2024, 04:21:02 AM »
Yes it is, I might change it to 0.44uF with a larger toroid. The initial current ramp up gets to 750A and the steady state current when I turn it up to 2ms is about 500A. This is just at 340V bus.
« Last Edit: May 06, 2024, 06:34:30 AM by Benjamin Lockhart »
« Reply #26 on: May 13, 2024, 07:25:29 PM »
I added 2 more primary turns so I can experiment with a high impedance primary and larger toroid.
I'm still building the toroid at the moment.
post Re: Help an EE student
Today at 05:59:21 AM
post Re: What capacitor configuration to explode foil?
Today at 05:44:41 AM
Today at 01:55:42 AM
May 17, 2024, 11:49:33 PM
post Re: Pulse Power High Current Discharges from 3 Phase PFC Capacitors
May 17, 2024, 10:18:46 PM
post Pulse Power High Current Discharges from 3 Phase PFC Capacitors
May 17, 2024, 07:24:22 PM
May 17, 2024, 07:14:35 PM
May 17, 2024, 08:35:38 AM
May 17, 2024, 05:34:10 AM
post Re: colored 50 Ohm coax
May 16, 2024, 10:53:53 PM
May 16, 2024, 10:37:50 PM
May 16, 2024, 10:29:30 PM
May 16, 2024, 08:26:41 PM
post Re: Aluminum electrolytic capacitor ripple current issue
May 16, 2024, 06:54:05 PM
May 16, 2024, 05:04:41 PM
post Re: Tesla Synth Player for Syntherrupter
AntoineRcbs
May 16, 2024, 12:13:47 PM
post Re: Help with primary voltages of unknown transformer
Domo
May 16, 2024, 06:58:12 AM
post Re: New EE student asks about Cutting-Edge fields
May 16, 2024, 06:47:09 AM
May 16, 2024, 06:00:49 AM
May 16, 2024, 05:45:08 AM
May 16, 2024, 05:03:41 AM
post Re: DRSSTC grounding issues
May 16, 2024, 04:58:40 AM
May 16, 2024, 04:36:40 AM
May 16, 2024, 12:28:27 AM
post Re: Watercooling
May 15, 2024, 11:13:48 PM
May 15, 2024, 10:58:05 PM
post colored 50 Ohm coax
May 15, 2024, 08:31:48 PM
May 15, 2024, 07:56:38 PM
May 15, 2024, 06:29:59 PM
Felix B.
May 15, 2024, 04:04:14 PM
post Re: Schmitt trigger schematic question
May 15, 2024, 03:32:57 PM
post DRSSTC grounding issues
Felix B.
May 15, 2024, 03:07:39 PM
post New EE student asks about Cutting-Edge fields
samsonwilliams
May 15, 2024, 05:50:59 AM
Domo
May 15, 2024, 05:38:14 AM
May 15, 2024, 04:58:02 AM
post Re: Big Coil Build Log
May 15, 2024, 04:34:49 AM
May 15, 2024, 04:30:18 AM
May 15, 2024, 04:00:55 AM
May 15, 2024, 03:21:51 AM
May 14, 2024, 11:12:22 PM
May 14, 2024, 11:00:00 PM
post Schmitt trigger schematic question
May 14, 2024, 09:45:38 PM
May 14, 2024, 09:02:28 PM
May 14, 2024, 05:55:24 AM
post Re: Weird AC/DC mini SSTC build review
May 14, 2024, 05:44:12 AM
May 14, 2024, 05:11:54 AM
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
post Help with primary voltages of unknown transformer
Domo
May 13, 2024, 08:43:49 PM
OmGigaTron
May 13, 2024, 06:50:59 PM
May 13, 2024, 03:47:08 PM
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
post Re: Quick question about steve ward mini SST5 resonant frequency
May 12, 2024, 05:10:40 PM
post Re: Help with LabCoatz's Staccato QCW DRSSTC Tesla Coil
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
May 12, 2024, 02:51:27 PM
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
post Help with LabCoatz's Staccato QCW DRSSTC Tesla Coil
hal7rr
May 11, 2024, 05:24:34 PM
post Re: Type 77 Metglas Laced Ferrite Core
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
post Type 77 Metglas Laced Ferrite Core
paulp1776
May 11, 2024, 06:23:59 AM
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
post Re: designing and building electron gun help!
May 11, 2024, 12:10:44 AM
post designing and building electron gun help!
Luca c.
May 10, 2024, 09:38:05 PM
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
post Quick question about steve ward mini SST5 resonant frequency
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
May 09, 2024, 03:42:49 PM
May 09, 2024, 03:06:19 PM
May 09, 2024, 01:05:26 PM
May 09, 2024, 09:15:24 AM
