General Chat => Laboratories, Equipment and Tools => Topic started by: flyglas on September 14, 2020, 08:35:10 PM
Title: Rogowski current probe
Post by: flyglas on September 14, 2020, 08:35:10 PM
Hello,
does somebody have access to a (perhaps broken one) rogowski current probe for use with an oscilloscope?
I cannot find any pictures from the inside of such a probe (integrator part of the probe) anywhere in the internet.
I would be very happy if someone can open a probe and take some pictures.
Title: Re: Rogowski current probe
Post by: Hydron on September 14, 2020, 09:02:19 PM
I second this, but I'm also interested in the construction of commercial probes, especially the skinny high-frequency ones (you can get them thin enough to thread through a TO-247 leg!
It's one thing winding a skinny coil, another to do it such that it doesn't pick up all sorts of garbage from E-fields etc yet still is flexible and high-bandwidth (the obvious ideas like a shield tend to work against these).
Post by: johnf on September 14, 2020, 09:03:43 PM
 [ Invalid Attachment ]
Post by: davekni on September 14, 2020, 09:31:47 PM
Sometimes a very cheap simple solution works fine, especially if there's a way to calibrate.  I once needed to probe output current of a large H-Bridge.  Wrapped 10 turns around the end of a felt-tip marker and wedged that between the two wires of the output cable.  Coil ends connected to a scope.  Captured waveforms and integrated with software.  Used a known 800A waveform for calibration.  It was then very useful to capture high-frequency details of the current waveforms that weren't visible previously.
Also tried a similar test on my DRSSTC H-Bridge output.  This time I added a non-shorted turn of copper foil around the coil for shielding.  Worked fine, but I didn't keep it.  My CT already has a scope tap, and digital integration isn't convenient for real-time viewing.
Post by: johnf on September 14, 2020, 09:47:08 PM
I built a tiny current transformer to go over the source lead of a TO220 fet (actually a 5 pin PowerIintegrations SMPS device) to actually see what was going on
I had already tried a 0.01 ohm resister to scope over but introducing the resistor caused other effects and masked my problem.
I used the core out of a ISDN modem that had common mode chokes on the data ports i pulled the core out and wound with 38awg wire 200 turns on it and high voltage varnished it up along with a 1.0 ohm burden resistor. Net effect was this causes 0.000025 ohms of impedance on the source lead which in my case was low enough to go back to Power Integrations for them to ponder over. I ended up making a second transformer and sending it to them for their use in their lab
Post by: johnf on September 14, 2020, 10:55:54 PM
Kludgesmith asked me for some pics of the common mode choke i stole the cores out of so here they are
Post by: johnf on September 14, 2020, 10:57:36 PM
another pic
Post by: johnf on September 14, 2020, 10:59:25 PM
available from
https://www.digikey.com/product-detail/en/pulse-electronics-network/PE-65855/PE-65855-ND/3533394
Post by: flyglas on September 15, 2020, 06:41:58 PM
Here is a patent of a commerical unit:
https://patentimages.storage.googleapis.com/85/26/79/fd153583c08c2a/US6614218.pdf
https://patentimages.storage.googleapis.com/b4/12/0a/f6a3234c6cc7e7/EP1073908B1.pdf
Post by: Hydron on September 16, 2020, 09:38:14 PM
Hmm, will need to give the similar simple setup I tried and wasn't happy with another go given I have a better scope these days.
As for small CTs, I spied these guys in a power supply teardown once:
(from https://www.tomshardware.com/uk/reviews/corsair-ax1600i-psu,5406-3.html)
Can also be seen here: http://www.jonnyguru.com/wp-reviews/CorsairAX1600i/DSC_2384.jpg
I never had any luck finding a way to order these unfortunately - they look super handy! Any lead on them would be most welcomed.
Post by: flyglas on September 17, 2020, 07:43:00 PM
@Hydron: I have asked the manufacturer of the GaN switches in the Corsair PSU about the tiny current sensor via mail. Perhaps they will answer my question.
Yesterday i bought a rogowski coil PEM CWT from ebay. Perhaps the unit will satisfy my thirst for knowledge.
Post by: Hydron on September 17, 2020, 10:26:57 PM
May I ask how much you paid? I haven't really looked seriously, but what I did see was silly money (i.e. business purchase $$$, not hobby). I am certainly interested in what you find!
Post by: flyglas on September 18, 2020, 02:49:05 PM
Hi Hydron,
I paid 174 EUR including shipping from Italy to Germany. That is a fairly good price.
--> PEM CWT 6R
Post by: Hydron on September 19, 2020, 11:34:01 PM
Thanks,
I did see this internal picture, may be of interest as you wait for your unit:
https://gmw.com/wp-content/uploads/2019/03/CWT_Fuse_Replace_Instructions_GMW.pdf
Is not showing the cable entry from the coil (goes in the hole at the top), but there isn't a whole lot going on in there! Would be good to see and compare to the inside of the one you have coming.
I am definitely interested in how the coil is made, but unfortunately this is difficult to do non-destructively unless you have an x-ray machine handy.
From the info I can gather from PEM publications etc, some of their probes look to be shielded, some not, so there may be quite a range of performance in the presence of high dV/dt.
Post by: flyglas on September 25, 2020, 09:41:10 PM
Thank you very much for the fuse replacement PDF.
Half of the tiny PCB is a power-supply and the other half is the integrator and output driver.
Nothing much in there.
My probe arrived during the week, but the probe is in a not working condition.
As long as the situation is not resolved with the seller, i will not dismantle the probe.
Post by: klugesmith on September 26, 2020, 04:46:12 AM
Eager to hear your results.  Sorry to hear the instrument does not work.
I have taken some steps toward winding a flexible Rogowski coil for the purpose outlined in "current transformer for narrow spaces" thread.  Commercial ones for AC power metering come close, but all seem to have small end diameters bigger than 7 mm (0.28 inches).  If the current to be measured is a sinusoid of known frequency, we can skip the voltage integration.  I expect to get about 10 mV out, from 200 amperes at 60 Hz.
What dimensions are easy to see on little commercial probes like the PEM?
For any Rogowski coil, the sensitivity (in units of inductance) is simply u0 A N/L,  where A is the small loop area, and N/L is the winding density in turns per unit length.   Commercial ones with different size big loops, made from the same tightly wound flexible rod material, all have the same sensitivity.
Post by: flyglas on September 26, 2020, 10:57:58 AM
The smalles probe is the PEM CWT Ultra Mini with only 1.7 mm in diameter.
I have worked with this tiny probe a few years ago. In my application I have mounted the probe between a minibrick and a PCB on top of the minibrick.
Post by: Hydron on September 26, 2020, 05:27:37 PM
That's a shame about the probe - the pics and description looked good.
Did you notice much influence from nearby dV/dt transients when using the CWT Ultra Mini? That one isn't shielded (it looks like the only shielded probe they do is the CWT miniHF) which concerned me about it's use near fast switching transistor legs, but if interference from nearby voltages isn't such an issue then DIY versions become much more practical.
Post by: flyglas on September 27, 2020, 11:01:13 PM
A solution with the seller was found. The repair of the probe is in progress.
I did not noticed the influence of nearby dV/dt transients with the CWT Ultra Mini.
We also performed double-pulse tests with unshielded probes.
Post by: Hydron on September 27, 2020, 11:48:35 PM
Excellent, very interested in how the repair goes and to see what's inside.
Do you know whether the coil is damaged, or if the fault is in the integrator box?
Post by: flyglas on September 28, 2020, 12:30:58 AM
The fault is definitely in the coil.
If you wiggle at the output cable of the coil the output waveform sometimes becomes good. Therefore the integrator works fine.
So there have to be a faulty connection somewhere between the coil and the transition to the cable.
The next step is to open up the heat shrink at the coil and to dig deeper into the underlying plastic case (T-piece).
Post by: flyglas on September 29, 2020, 07:45:22 PM
The repair was a success!
I think the photos speak for themselves.
Post by: klugesmith on September 29, 2020, 08:08:22 PM
Very nice work.
Can we see what the free end of coil looks like?  I guess it's presently clamped in place at the middle of T shape, perpendicular to the output cable and fixed end of flexible coil.
Is there a schematic that shows what those resistors are doing inside the T ?
Post by: Hydron on September 29, 2020, 08:13:43 PM
Good to hear it was a successful repair, and as expected, not a lot going on in the head.
I am also interested in any light you can shed on the coil construction and termination - it's not completely clear how the termination is done. Are the two termination resistors soldered together to one end of the sensing coil (with the other end being the red wire)? Or are they each going to a separate end (in which case, what does the red wire connect to)? Is the input to the integrator a normal piece of co-ax or is there something else going on?
Sorry for all the questions, the more I see about these the more it looks like a relatively simple DIY job to replicate!
Post by: flyglas on September 29, 2020, 09:12:52 PM
@klugesmith: I have attached some photos of the coil and the position of the free end inside the t-piece. The cap at the end of the coil is made out of metall.
The coil itself seems to be constructed around the inner part of a coax cable (plastic tube with center conductor).
At the free end the red wire is connected to the center conductor. After many turns the red wire reaches the t-piece.
The termination resistor in the t-piece is connected between the center conductor and the red wire.
The red wire and one end of the termination resistor is connected to the outer conductor of the coax to the integrator.
The second resistor is a series resistor and connected between the center conductor of the coil and the center conductor of the coax to the integrator.
As cable between coil and integrator a triax cable is used. The outer conductors (copper braids) are conntected inside the integrator but not in the coil.
In the coil the outer most conductor is unconnected.
Post by: Hydron on September 29, 2020, 09:50:02 PM
Thanks, makes a lot more sense with the diagram and explanation. I'm assuming the resistors you are seeing are the Rd and R0 as seen in this paper:
http://hotstreamer.deanostoybox.com/TeslaCoils/Misc/RogowskiCoils-816epe99.pdf
and that the rest of the circuit is similar to the non-inverting integrator they present there.
I suspect the major integration job is done by IC2, with IC10 as an output driver, though without knowing what's on the bottom side of the board it's impossible to tell exactly how it's laid out.
Some more relevant info:
https://gmw.com/wp-content/uploads/2019/02/ias_2000_pem-1.pdf
(I have a big stash of papers, patents etc that I've saved whenever I've gotten interested in these, just never found the time to do much more than some quick and dirty testing though)
Post by: Weston on September 30, 2020, 05:24:48 AM
These are so simple inside, its crazy they sell for so much. If anyone is down to collaborate, I would be down to work on an open source design.
Post by: klugesmith on September 30, 2020, 08:39:53 AM
Let's talk in a few days after I have rolled my own flexible Rogowski coil, and materially supported your Bee probe.
Many simple products for niche applications, well designed and produced, command lots of money.
It helps if vendor is on Approved Vendor lists.  Selling accessories for six-figure instruments is like options on six-figure automobiles.
For hands-free, solder-free probe positioning at home:
Post by: klugesmith on October 02, 2020, 06:08:07 AM
Flyglas, I hope this is not hijacking your thread.
Here is picture of a baby's first step.  Expected to grow into an open-able Rogowski coil for measuring currents at 60 Hz, without much concern for instrument risetime and waveform fidelity.
Is the commerical coil by PEM wound directly on exposed dielectric of a coaxial cable?  For my project that seems like needless trouble, and I have no coax with a suitable dielectric OD.  Finished coil must fit through a 7 mm gap. So I'm using the jacket from a multi-conductor cable, slipped over a straight steel mandrel.  Later it will slip over a coaxial cable dielectric.  The relatively thin, soft sleeve might help to prevent bunching of the small turns, on inside of the big loop.
This practice winding has 27 turns of 34 AWG magnet wire, made by twirling the mandrel by hand.
How do you all like to strip insulation from fine magnet wire?
Post by: flyglas on October 02, 2020, 04:38:51 PM
@klugesmith: No problem.
I do not exactly know the material of th dielectric inside the coil.
On some of my pictures you can see white material with approximately 4.5 mm diameter.
I like to strip fine magnet wire with a soldering iron using much solder melting the insulation layer away.
Post by: Hydron on October 02, 2020, 05:06:36 PM
I had an email from PEM stating the following regarding one of their much older probes:
"The Rogowski coil is manufactured as one continuous wire which is wound around a plastic tube, then the conductor returns down the tube centre."
If doing the same, I suspect it will be important to have a close fit of the wire in the tube to ensure it is as centred as possible.
Flyglas - did you get any pictures of the rear of the integrator PCB? Am trying to compare the implemented circuit vs what is written in papers/patents.
Post by: flyglas on October 02, 2020, 08:59:48 PM
Here is a photo of the backside of the PCB.
Post by: davekni on October 03, 2020, 04:57:35 AM
I'm wondering if it really matters about centering of the return wire.  If the bandwidth is high enough to need constant impedance of the "coax" of the return wire, then I can see.  But that high a bandwidth seems unlikely.  Otherwise, any field picked up by wandering of the center wire position would be tiny compared to all the turns of the outer coil.
For simple construction, how about some soft rubber high-voltage wire?  That has thick insulation with a center conductor.  Wind it with magnet wire and solder one end to the center HV wire.  My guess is that the biggest error will come from any non-uniformity in winding pitch along the wire.
Yes, as long as the magnet wire insulation isn't the high-temperature (typically crosslinked polyimide enamel of some sort) type, soldering is the best.  Red and green magnet wire is fine.  The gold/copper colored enamel is usually this high-temperature version.  For fine wire as 34AWG, I use careful sanding with fine-grit paper.  Other options include chemical stripping and welding instead of soldering.
Post by: plasma on October 03, 2020, 06:54:25 AM
Just wondering is the turns right hand rule or left, I'm guessing you would want the two inductor to add?
Post by: Hydron on October 03, 2020, 11:20:37 AM
In my attempts I've used kynar wire wrapping wire. Easy to deal with for testing unless you want the maximum number of turns on there.
Post by: klugesmith on October 03, 2020, 06:22:34 PM
Like Dave, I believe centering of the return conductor within the small helix is uncritical.
Its purpose is so the Rogowski coil has zero instead of one net turn encircling flux that's perpendicular to the big loop.  That cancels the largest stray field sensitivity.
Plasma, you don't need to choose between left and right hand twists.  Can put both in the same space, joined to each other at one place and brought out on the other side of the "break".  Never seen that on a flexible RC, but I made two rigid RC's that way.
Both have 60 turns and calculated sensitivity of around 37 nH.   One is wound on a thick flat nylon washer.  The printed circuit version went in waste area of a 6 mm thick board I designed at work about 10 years ago. I have about 10 of them somewhere; does any pulse power experimenter here want one to play with?
I like the kynar idea, to save work in a proof of concept coil.  But my 60 Hz sensitivity estimate (order of 10 mV from 200 A) is for small loop diameter of about 6 mm (constrained by gap between current conductors) and winding pitch of 6 turns per mm (150 per inch). As with close wound 34 AWG magnet wire, more than twice as dense as 30 AWG wire-wrap wire.  Maybe it's premature to contrive a geared lead screw to feed the wire at constant pitch, like I guess is done for some Tesla coil secondaries.  In this case we want the turns a bit looser than touching each other, to allow for bending without bunching.
Mod edit: removed partial duplicate post above this one.
kluge edit: Sorry 'bout that.  Pictures seemed to disappear so I put 'em back.
Here's link to old 4hv post from which I scraped those thumbnails. It has more pictures, theory, and measurements. https://4hv.org/e107_plugins/forum/forum_viewtopic.php?p=1&id=82880#post-82880
Post by: plasma on October 03, 2020, 06:27:26 PM
Kludgesmith I've only got a DMM with inductance mH readings, it won't be sensitive enough, if I wrap two inductor on a common core and measure the inductance of one coil and pulse the second coil I should be able to workout the current,if the core is semi permanent.
I'm thinking it will be non linear, but you guys explained its only one turn, so wouldn't be that large.
Post by: Hydron on October 03, 2020, 06:59:57 PM
There are a bunch of papers out there regarding PCB rogowski coils, including stuff like integration into the board the power devices are mounted on. See also the following Ti reference design, with a differential PCB coil and digital integration (they include altium layout files btw):
https://www.ti.com/tool/TIDA-01063
Post by: Weston on October 03, 2020, 08:46:41 PM
What sensitivity do you need? It should not be difficult to design a high gain low noise amplifier given the limited bandwidth.
10 mV/ 200 A is probably more than enough sensitivity unless you were planning on feeding it directly into the scope input.
Post by: plasma on October 03, 2020, 10:03:25 PM
Weston 10mV / 200 then sqrt to give the nH, but the length of the centre wire has X inductance, so its a matrix of two (M1+M2)+(M1+M1)+(M2+M2)sqrt, its not just parrellel inductor, they are coupled.
Post by: klugesmith on October 03, 2020, 10:20:47 PM
Agreed, 10 mV is not weak as electronic signals go.
What's the noise level at microphone input to a PC audio "card"?  Digitized voltage signal could be low pass filtered, averaged, and (lest we forget) integrated offline.
Just remembered the commercial model 916 fluxmeter box.  It does voltage integration, is plenty fast for 60 Hz, and has offset voltage low enough for "DC" measurement.  Invites Rogowski coil tests on DC buses whose current can be switched on and off.
https://highvoltageforum.net/index.php?topic=819.msg5555#msg5555
This chat has served as reminder that fancy winding (34 AWG magnet wire, wound beautifully, maybe with mechanically controlled pitch) is probably unnecessary for stated objective, DIY flexible coil for a single application.
Would be a briefly engaging squirrel-chase.
Post by: flyglas on October 04, 2020, 04:21:24 PM
Here is a picture of the windings of the Ultra Mini probe: Page 19: https://gmw.com/wp-content/uploads/2019/01/APEC-March-2015.pdf (https://gmw.com/wp-content/uploads/2019/01/APEC-March-2015.pdf)
Post by: klugesmith on October 04, 2020, 06:16:24 PM
Thanks; the picture of "Old CWTUM" started a very satisfying squirrel chase.
Picture shows 50 turns in 6.1 mm, for winding density of 8200 turns/m (208 turns/inch). Estimated coil diameter is 1.15 mm outside and 0.91 mm inside. The larger red rectangle is 1.7 mm high, matching the Ultra Mini jacket OD.
Using coil mid-diameter, computed sensitivity is 8.55 nH.
Anybody seen that parameter given in literature from PEM, or other commercial RC maker?
My test of closely-wound AWG34 magnet wire got 5900 turns/m (150 turns/inch).  Can probably get 2100 turns/m with plain old wire-wrap wire.  In a 5.5 mm coil that would give us 63 nH.  On 200 A at 60 Hz, 4.7 mV.
Post by: flyglas on October 04, 2020, 07:49:17 PM
Thanks for image processing and the squirrel chase. I had the same idea but no time today.
I also have done the math (with your values) and calculated the same mutual induction as you.
The mutual induction value is plausible.
With a integrator time constant of 1.7 µs (R = 1700 Ohm and C = 1.0 nF) we have a sensitivity of around 5 mV/A.
Post by: flyglas on November 06, 2020, 08:37:32 PM
I have a short update.
A few days ago I received PCBs for a rogowski coil integrator.
Additionaly I wound a small coil onto the insulator PTFE of an RG178 coaxial cable.
The insulator has an diameter of 0.86mm and the used wire is 0.1mm. The windings are wound without space between the windings.
As a protective layer a heat shrink is on top of the wire. The total diameter of the coil is only 1,75 mm.
At the moment I only tuned the low frequency range (active integrator with opamp).
A test at 50 Hz and around 6 A peak shows the same respones as my professional coil.
Both coils are designed to have 5 mV/A output signal.
The next step is to tune the high frequency range (passive integrator).
For this task I designed a pulse generator (16 µs pulse with 150 A peak and flat top, rise and fall time around 800ns).
I found the calibration procedure/waveform in an official calibration document.
Post by: klugesmith on November 08, 2020, 03:25:03 AM
Very nice work.
It shows that 6 amps at 50 Hz gives a useful signal, even with the tiny area of minor loops in the coils.
Have you looked at the sensitivity to test currents routed outside the R.C. loop, or threading the loop backwards?
Will we get to see any pictures of your helical winding operation?
What is the low frequency corner of the active integrator circuit?
Post by: flyglas on November 08, 2020, 02:56:58 PM
I have build a current pulse generator (150A, ~750ns rise and fall-time, 20µs pulse width) for adjustments to the high frequency passive integrator.
With this puls generator and two turns of wire, I have tested the influnece of nearby current pulses.
Depending of the position the influnece is well noticable (see pictures influence_diy_1...3).
With the commerical unit the influence was also noticable, but almost only at the t-piece (see picture influence_prof_1).
The resumee is: Keep away with currents from the t-piece.
This was no big deal. I removed the inner conductor of the PFTE insulator and replaced it with the 0.1 mm enameled wire.
At the open end I applied a tiny ammount of epoxy glue. After curing the insulator was twisted between to fingers to wind the wire around the insulator.
Everything is held together with the heat shrink.
I did not tested it yet. Simulation shows good results down to 1 Hz.
