Author Topic: SKM100 Mini DRSSTC  (Read 314 times)
Offline alan sailer
SKM100 Mini DRSSTC
« on: June 09, 2021, 12:39:09 AM »
Well after some small grief and a fair amount of learning my mini DRSSTC is basically done. The design is modeled after OneKone's SKM100.
After an initial scare (secondary flashover) I increased the spacing between primary and secondary. I also lowered the operating frequency a
bit to make it easier on the IGBJT's. I have not been able to fully test the output since it is getting dark later and I go to bed early. Inside it
arcs to the ceiling like crazy at about 64cm.
I also spent some though time decorating the coil and this is what I came up with,
There are no radical innovations in this coil. I did think of a nice way of easily adjusting the coupling using a plastic plumbing support from
the hardware store. I have not seen anyone post this idea but I doubt that it is new. All the bolts are nylon to avoid induction heating.
The plumbing fixture has a coarse plastic thread that allows about 4cm of adjustment. It made it very easy to try different couplings, just
remove the secondary ground wire, turn the entire toroid/secondary assembly to move it up or down relative to the primary. The fit of the
thread was pretty loose so I put in a couple of layers of teflon tape to make it tighter. I'm sure that a search could find bigger fitting
with closer tolerances, but for ~20$ and ten minutes of looking this did great.
I am willing to post more information about the coil if anyone is interested. But it really is nothing new, just a well executed mini DRSSTC.
This is my first DRSSTC and I was kind of surprised at how impressive these things are in a kind of scary way.
QCW coils put out refined thumps, like a cultured jazz drummer. Think Bernard Purdie. This thing is like Keith Moon, kind of barely under control.
Thanks to all the people who gave me help, both personally and from the archives.
Cheers.
« Last Edit: June 09, 2021, 12:44:41 AM by alan sailer »
Offline GrantV
Re: SKM100 Mini DRSSTC
« Reply #1 on: June 09, 2021, 10:29:11 AM »
Hey Alan,
That looks EXCELLENT! Very nice work you did there :-)
I have not seen the use of the plumbing support before. It is an excellent idea ... wish I had thought of that :-)
« Reply #2 on: June 09, 2021, 12:46:42 PM »
Dude.... That coil looks incredible! Those skm100 can definitely push some power. If you ever get time it would be awesome to see the coil in action.
Offline alan sailer
« Reply #3 on: June 10, 2021, 01:36:31 AM »
Well at least the plastic drainpipe idea was new to someone. That is good.
I'm glad to see you comment on this build OneKone. As I mentioned, your coil was the model for this. I had a few IGBJT bricks in my bin, the SKM100
was one, so that determined the build. I spent a lot of time obsessing over your post including trying hard to figure out what coupling you were using. My initial
try had too much coupling and led to a flashover at very lower power. So I moved one turn out...
As far as a video I may do that some point in the future. Right now it's just too light for too long. It's strange, but operating this coil stresses me out
and I'm afraid that doing it late at night would lead to a night of bad sleep. High voltage is not a relaxing hobby. I was surprised to recently realize that after building
a dozen or so coils, my real joy is building them, not operating them.
I'm also contemplating doing a video of a complete tear-down of this coil while describing all the parts. I have not seen anyone do that.
Cheers.
« Reply #4 on: June 11, 2021, 04:53:50 AM »
I find the same thing for my DRSSTC.  It is fun, but stressful too.  I get stressed both by the care it takes to operate safely and the concern that something may go wrong and destroy hundreds of hours of work.  Summer is when weather is dry enough here for outside operation, but also when dark-enough starts around 9pm.  Neighbors with kids in bed also limit operation (due to sound level), except for holidays such as US Independence Day (July 4th).
Offline Willsmith001
    • clickbankproductreviews
« Reply #5 on: June 11, 2021, 11:08:24 PM »
Thanks for your post.
Today at 03:20:42 AM
Today at 03:16:27 AM
July 23, 2021, 09:23:11 PM
post Re: IGBT question
July 23, 2021, 08:05:58 PM
July 23, 2021, 07:02:18 PM
July 23, 2021, 05:33:57 PM
GKnapp
July 23, 2021, 04:51:37 PM
July 23, 2021, 03:52:46 AM
July 22, 2021, 10:59:32 PM
GKnapp
July 22, 2021, 08:50:34 PM
July 22, 2021, 08:47:23 PM
July 22, 2021, 07:01:24 PM
July 22, 2021, 06:50:07 AM
July 22, 2021, 06:39:37 AM
July 21, 2021, 07:55:03 PM
GKnapp
July 21, 2021, 06:34:13 PM
[DSLR]
July 21, 2021, 05:10:18 PM
July 21, 2021, 12:42:29 PM
Chrisader
July 21, 2021, 08:15:00 AM
July 21, 2021, 04:57:04 AM
July 21, 2021, 03:50:33 AM
July 21, 2021, 01:50:19 AM
Chrisader
July 20, 2021, 10:06:14 PM
July 20, 2021, 06:24:29 PM
July 20, 2021, 05:37:36 AM
July 20, 2021, 05:08:24 AM
[DSLR]
July 20, 2021, 04:43:05 AM
[DSLR]
July 20, 2021, 12:09:36 AM
July 19, 2021, 11:13:13 PM
Maverikie
July 19, 2021, 08:56:04 PM
newage
July 19, 2021, 07:09:56 PM
[DSLR]
July 19, 2021, 06:49:08 PM
July 19, 2021, 04:39:05 PM
[DSLR]
July 19, 2021, 06:32:35 AM
July 19, 2021, 05:22:51 AM
newage
July 19, 2021, 04:24:38 AM
eli
July 19, 2021, 12:35:18 AM
July 19, 2021, 12:15:43 AM
post a typical sstc half bridge design, any considerations or tips?
eli
July 18, 2021, 11:44:03 PM
eli
July 18, 2021, 09:33:40 PM
July 18, 2021, 09:07:15 PM
July 18, 2021, 03:38:01 PM
post Best and stable version of video
Transgarp
July 18, 2021, 03:33:31 PM
post Sync RSG motor problems - help and thoughts needed
newage
July 18, 2021, 01:30:46 PM
post Re: DRSSTC design advise / Primary peak current calculation
July 17, 2021, 10:05:39 AM
July 16, 2021, 11:01:43 PM
Martin
July 16, 2021, 09:55:50 AM
July 16, 2021, 09:54:50 AM
July 16, 2021, 03:49:35 AM
post Hobby website and youtube channel with many "Maker" topics
[Hobby Sites]
July 16, 2021, 01:40:06 AM
