Author Topic: Safe source for High Voltage Wire?  (Read 330 times)
Offline MrScrOggs
  • Going to trade school to be an electrician.
« on: May 16, 2021, 03:02:40 PM »
Hello everyone, I was looking on ebay and Amazon for high voltage wire but I don't know if I want to trust either of them when my life depends on it. I was wondering if you guys have any trustworthy and safe sources for high voltage wire, or if I should really be trusting shady amazon and ebay listings... ???
Evan
Offline Da_Stier
Re: Safe source for High Voltage Wire?
« Reply #1 on: May 16, 2021, 07:29:32 PM »
I ordered cable from these guys before:
https://highvoltageshop.com/epages/b73088c0-9f9a-4230-9ffc-4fd5c619abc4.sf/de_DE/?ObjectPath=/Shops/b73088c0-9f9a-4230-9ffc-4fd5c619abc4/Categories/6/Hochspannungskabel
This is propably a bad idea if you are outside of the EU because of shipping cost, etc.
Another possibility might be to use ignition cable (like for cars and motor cycles).
This stuff is however not really rated that well, I beliefe.
Greetings,
Michael
« Reply #2 on: May 16, 2021, 08:38:37 PM »
First, you should not trust your life on high voltage wire insulation. You do not touch high voltage conduction wires, you use a insulated rod if you need to more anything while powered up.
Second, look for neon sign shops / businesses in your local area/country. They usually have something rated for 20 kV.
Third, you can scavenge smaller lengths of HV wire from CRT TV sets and microwave ovens.
Offline johnnyzoo
« Reply #3 on: May 17, 2021, 08:58:05 AM »
Car ignition cable is OK for moderately high voltages and low...moderate currents. Note that many ignition cables are made with carbon composite conductor which has relatively high resistance and you probably don't want to use such cable. Buy copper cable instead. It can be found in some car parts shops.
And as said above, trusting your life on cable insulation is usually not a good idea in these hobby projects. Many things can go wrong. Maintain distance and use a non-conductive stick for adjustments and drawing arcs. Make sure that the stick is really non-conductive.
« Last Edit: May 17, 2021, 09:05:50 AM by johnnyzoo »
« Reply #4 on: May 17, 2021, 09:12:41 AM »
We use RG8/ RG213 coax at work up to 70kV
this comes with a caveat we test cable to handle this before use, except for Huber Suhner coax which is good to go out of the box.
We generally use it with the earth braid intact ie that is earthed for safety but each end the inner is extended by 250-300mm past the outer braid but inside respective cabinets at this point.
I also use the inner conductors on their own up to 50kV these I protect with Polyethylene pipe or similar to provide a hint of double insulation
« Reply #5 on: May 17, 2021, 08:36:30 PM »
John,
Is 70kV for RG213 or RG8 DC voltage?  I presume so.  If AC, how do you handle corona degradation?
« Reply #6 on: May 17, 2021, 08:52:28 PM »
Dave
that is DC voltage as used in our ion implanters for terminal acceleration voltage
Today at 02:49:00 AM
June 16, 2021, 08:54:32 PM
June 16, 2021, 08:00:50 PM
June 16, 2021, 05:40:40 PM
post Demo Coil Protection
June 16, 2021, 05:39:14 PM
June 16, 2021, 10:20:30 AM
June 16, 2021, 07:33:15 AM
June 15, 2021, 01:21:38 PM
Rapy2
June 15, 2021, 12:02:58 PM
June 15, 2021, 06:52:56 AM
June 15, 2021, 05:43:07 AM
June 15, 2021, 05:26:34 AM
June 15, 2021, 02:27:03 AM
Rapy2
June 14, 2021, 01:06:02 AM
June 14, 2021, 12:44:31 AM
Rapy2
June 14, 2021, 12:41:33 AM
Rapy2
June 14, 2021, 12:11:13 AM
June 13, 2021, 11:52:11 PM
Rapy2
June 13, 2021, 11:38:44 PM
Rapy2
June 13, 2021, 10:26:51 PM
June 13, 2021, 09:57:56 PM
Rapy2
June 13, 2021, 09:29:08 PM
June 13, 2021, 08:53:25 PM
Rapy2
June 13, 2021, 07:22:05 PM
June 13, 2021, 07:02:28 PM
June 13, 2021, 06:25:20 PM
Rapy2
June 13, 2021, 02:48:59 PM
gianpaolo
June 13, 2021, 12:00:09 PM
June 12, 2021, 07:28:03 PM
June 12, 2021, 07:23:12 PM
June 12, 2021, 12:24:06 PM
post Re: Nice PC Board Tesla
June 12, 2021, 10:06:18 AM
June 12, 2021, 10:01:29 AM
June 12, 2021, 08:47:08 AM
June 12, 2021, 07:03:10 AM
PEDRO HENRIQUE
June 12, 2021, 06:42:56 AM
June 12, 2021, 04:20:53 AM
post Re: SKM100 Mini DRSSTC
Willsmith001
June 11, 2021, 11:08:24 PM
Willsmith001
June 11, 2021, 11:07:00 PM
June 11, 2021, 12:33:55 PM
June 11, 2021, 12:03:24 PM
June 11, 2021, 06:47:52 AM
Power-Max
June 11, 2021, 06:32:02 AM
June 11, 2021, 05:16:03 AM
June 11, 2021, 04:53:50 AM
post Re: Why are SGT50T65FD1PN soo cheap on lcsc?
June 10, 2021, 11:51:17 PM
June 10, 2021, 09:52:59 PM
June 10, 2021, 09:16:25 PM
June 10, 2021, 08:19:40 PM
post Fujifilm PMT module PMT12A, reverse engineering
June 10, 2021, 08:05:27 PM
