Author Topic: Safe source for High Voltage Wire?  (Read 429 times)
Offline MrScrOggs
  • Electrician in training.
« on: May 16, 2021, 03:02:40 PM »
Hello everyone, I was looking on ebay and Amazon for high voltage wire but I don't know if I want to trust either of them when my life depends on it. I was wondering if you guys have any trustworthy and safe sources for high voltage wire, or if I should really be trusting shady amazon and ebay listings... ???
Evan
Offline Da_Stier
Re: Safe source for High Voltage Wire?
« Reply #1 on: May 16, 2021, 07:29:32 PM »
I ordered cable from these guys before:
https://highvoltageshop.com/epages/b73088c0-9f9a-4230-9ffc-4fd5c619abc4.sf/de_DE/?ObjectPath=/Shops/b73088c0-9f9a-4230-9ffc-4fd5c619abc4/Categories/6/Hochspannungskabel
This is propably a bad idea if you are outside of the EU because of shipping cost, etc.
Another possibility might be to use ignition cable (like for cars and motor cycles).
This stuff is however not really rated that well, I beliefe.
Greetings,
Michael
« Reply #2 on: May 16, 2021, 08:38:37 PM »
First, you should not trust your life on high voltage wire insulation. You do not touch high voltage conduction wires, you use a insulated rod if you need to more anything while powered up.
Second, look for neon sign shops / businesses in your local area/country. They usually have something rated for 20 kV.
Third, you can scavenge smaller lengths of HV wire from CRT TV sets and microwave ovens.
Offline johnnyzoo
« Reply #3 on: May 17, 2021, 08:58:05 AM »
Car ignition cable is OK for moderately high voltages and low...moderate currents. Note that many ignition cables are made with carbon composite conductor which has relatively high resistance and you probably don't want to use such cable. Buy copper cable instead. It can be found in some car parts shops.
And as said above, trusting your life on cable insulation is usually not a good idea in these hobby projects. Many things can go wrong. Maintain distance and use a non-conductive stick for adjustments and drawing arcs. Make sure that the stick is really non-conductive.
« Last Edit: May 17, 2021, 09:05:50 AM by johnnyzoo »
« Reply #4 on: May 17, 2021, 09:12:41 AM »
We use RG8/ RG213 coax at work up to 70kV
this comes with a caveat we test cable to handle this before use, except for Huber Suhner coax which is good to go out of the box.
We generally use it with the earth braid intact ie that is earthed for safety but each end the inner is extended by 250-300mm past the outer braid but inside respective cabinets at this point.
I also use the inner conductors on their own up to 50kV these I protect with Polyethylene pipe or similar to provide a hint of double insulation
« Reply #5 on: May 17, 2021, 08:36:30 PM »
John,
Is 70kV for RG213 or RG8 DC voltage?  I presume so.  If AC, how do you handle corona degradation?
« Reply #6 on: May 17, 2021, 08:52:28 PM »
Dave
that is DC voltage as used in our ion implanters for terminal acceleration voltage
Today at 03:20:42 AM
Today at 03:16:27 AM
July 23, 2021, 09:23:11 PM
post Re: IGBT question
July 23, 2021, 08:05:58 PM
July 23, 2021, 07:02:18 PM
July 23, 2021, 05:33:57 PM
GKnapp
July 23, 2021, 04:51:37 PM
July 23, 2021, 03:52:46 AM
July 22, 2021, 10:59:32 PM
GKnapp
July 22, 2021, 08:50:34 PM
July 22, 2021, 08:47:23 PM
July 22, 2021, 07:01:24 PM
July 22, 2021, 06:50:07 AM
July 22, 2021, 06:39:37 AM
July 21, 2021, 07:55:03 PM
GKnapp
July 21, 2021, 06:34:13 PM
[DSLR]
July 21, 2021, 05:10:18 PM
July 21, 2021, 12:42:29 PM
Chrisader
July 21, 2021, 08:15:00 AM
July 21, 2021, 04:57:04 AM
July 21, 2021, 03:50:33 AM
July 21, 2021, 01:50:19 AM
Chrisader
July 20, 2021, 10:06:14 PM
July 20, 2021, 06:24:29 PM
July 20, 2021, 05:37:36 AM
July 20, 2021, 05:08:24 AM
[DSLR]
July 20, 2021, 04:43:05 AM
[DSLR]
July 20, 2021, 12:09:36 AM
July 19, 2021, 11:13:13 PM
Maverikie
July 19, 2021, 08:56:04 PM
newage
July 19, 2021, 07:09:56 PM
[DSLR]
July 19, 2021, 06:49:08 PM
July 19, 2021, 04:39:05 PM
[DSLR]
July 19, 2021, 06:32:35 AM
July 19, 2021, 05:22:51 AM
newage
July 19, 2021, 04:24:38 AM
eli
July 19, 2021, 12:35:18 AM
July 19, 2021, 12:15:43 AM
post a typical sstc half bridge design, any considerations or tips?
eli
July 18, 2021, 11:44:03 PM
eli
July 18, 2021, 09:33:40 PM
July 18, 2021, 09:07:15 PM
July 18, 2021, 03:38:01 PM
post Best and stable version of video
Transgarp
July 18, 2021, 03:33:31 PM
post Sync RSG motor problems - help and thoughts needed
newage
July 18, 2021, 01:30:46 PM
post Re: DRSSTC design advise / Primary peak current calculation
July 17, 2021, 10:05:39 AM
July 16, 2021, 11:01:43 PM
Martin
July 16, 2021, 09:55:50 AM
July 16, 2021, 09:54:50 AM
July 16, 2021, 03:49:35 AM
post Hobby website and youtube channel with many "Maker" topics
[Hobby Sites]
July 16, 2021, 01:40:06 AM
