Author Topic: Flashover  (Read 944 times)
Flashover
« on: May 04, 2021, 01:24:10 AM »
I am putting together a small/medium sized DRSSTC using SKM100 in a full bridge and a UD2.7C thru-hole
driver. The set-up is working to first order ie I am getting sparks and drawing current.
I was testing yesterday and I had a spark-over from the secondary to the primary. Didn't kill the IGBJTs
maybe because of the 44nF/3kV cap from buss negative to ground. This happened with a JAVATC coupling
of ~0.2. I do wonder if this hurt my secondary but the coil still coils.
The design I am using is closely based on OneKone's coil. To me the separation between the secondary coil
and the inner ring of the flat spiral primary has always seemed very tight. It is about 7-8mm.
It seems to me that with higher coupling factors the potential (ha) for flash-over gets greater.
Is there any guidance as to best practice? My past coils have all used an insulating lexan cylinder
with the primary wrapped in a rising spiral. This seems like a good idea but I have no experience
with DRSSTCs which involve higher voltages than my other coils.
My impression of DRSSTCs is that many people use the flat spiral and others use the inverted cone.
It seems like for all these designs an insulating lexan cylinder around the lower part of the secondary
would be a good idea.
Re: Flashover
« Reply #1 on: May 04, 2021, 09:56:30 AM »
0.2 coupling and only 8mm distance between primary and secondary asks for trouble.
That's a fact, higher coupling causes higher voltage/turn on the secondary coil. Once a certain critical threshold is exceeded, the secondary will flashover and it may even strike your primary, especially if your primary is so close to the secondary.
The coupling factor for a DRSSTC is usually around ~0.15, I would suggest decreasing coupling by making the inner most diameter of the primary bigger, which will even solve the tight proximity to the secondary.
Bc. Marek Novotny
www.uhvlab.org
Re: Flashover
« Reply #2 on: May 20, 2021, 04:09:18 AM »
I forgot to update and end this topic. I did decide to both lower the coupling and remove the primary inside turn to increase
the primary/secondary spacing.
I'm tuning the coil and have had no more flash-overs. Up to 27 inch sparks and expect more.
Thanks for the input.
Re: Flashover
post Re: Kaizer VTTC 1
Today at 10:23:02 AM
post Re: Capacitor in Parallel with Primary Coil
Today at 10:17:34 AM
post Capacitor in Parallel with Primary Coil
Today at 10:01:41 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
Today at 04:47:35 AM
Today at 03:59:27 AM
March 28, 2024, 09:15:11 PM
post Re: capacitor and diodes. Voltage values for a CW
March 28, 2024, 01:01:12 PM
post Re: Big Coil Build Log
March 28, 2024, 05:47:34 AM
March 28, 2024, 04:45:07 AM
March 28, 2024, 04:18:27 AM
post Push Pull VTTC
janno288
March 28, 2024, 01:10:08 AM
March 27, 2024, 10:54:52 PM
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
March 25, 2024, 02:06:41 PM
post Re: Odd MOSFET Driver Behavior
KrisPringle
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
KrisPringle
March 25, 2024, 12:47:09 AM
March 24, 2024, 07:36:32 PM
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
Luca c.
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
Keybored
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
March 17, 2024, 04:15:14 PM
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
