Author Topic: Mains synced sstc questions  (Read 251 times)
Offline costas_p
« on: April 14, 2021, 05:00:12 PM »
Hello to HVF community, I am looking to build a mains synced sstc (here in Greece 230v 50Hz).
I am considering using Kaizer VTTC staccato controller as the AC pulse sensing, so a have some questions:
~ The output that goes into SCR/transistor/mosfet, can it be used in enable pin 3 on UCC3732x drivers? Should I omit R18 (100k) resistor?
~ I am planning to use an ac to dc 12v wall plug adapter for the logic, and a tiny VA rated  230:12v transformer in order to drive the Q1 (2n2222), so R3 resistor and Q1 emitter should be
   connected to the wall plug's dc negative side, or the neutral side of the small transformer? Or maybe for that to work, neutral side of transformer secondary and logic ground should
   be one?
Papadakis Costas
Re: Mains synced sstc questions
« Reply #1 on: April 14, 2021, 07:35:25 PM »
You need to have a common ground for it all, else there is no reference between AC to DC side through 2N2222, I can at least not tell you what would happen.
Grounding all power supplies negative and one leg of the secondary side of a isolation transformer is known as PELV ( https://en.wikipedia.org/wiki/Extra-low_voltage#/media/File:Extra_low_voltages_(third_safety_class).JPG ) and that is best practice for electrical safety.
R18 could properly be omitted, you do not need current limiting for driving the UCC gate driver IC.
Offline dexter
« Reply #2 on: April 15, 2021, 10:48:12 PM »
Hi. Here is my take on mains synced sstc using the same staccato circuit but with a few improvements :)
I used a single power supply (mains transformer) for both the zero cross detection and to power the controller. To do so you'll need to add a diode in series with the bridge rectifier (note 1)
This circuit will utilize both peaks of the mains sinewave giving you up to a max 100 bps
The phase control pot (Power) when turned to max will either never reach the max 10ms time or will exceed it clipping on the next period resulting in a noticeable drop in BPS. To fix this choose the timing R C a bit over 10ms but add a trimmer in parallel with the pot (note 2)
Edit 1. sorry for the messed up schematic :) but is the same as Kaizer VTTC staccato
controller
Edit 2. my profile pic is this mains synced sstc running at 100 bps and max power (10ms)
« Last Edit: April 15, 2021, 10:54:37 PM by dexter »
Offline Magneticitist
« Reply #3 on: April 18, 2021, 02:36:34 AM »
SciTubeHD's ramped PLL SSTC. He has his staccato output going to the enable pins. Beautifully simplistic overall circuit and results.
post Re: tiny arcs even at high powers?
Today at 03:36:37 AM
Today at 02:54:05 AM
Today at 02:06:04 AM
Today at 01:30:05 AM
post tiny arcs even at high powers?
tophat
Today at 01:02:16 AM
May 08, 2021, 10:31:25 PM
JCF
May 08, 2021, 05:14:46 PM
May 07, 2021, 11:08:04 PM
Miki_407
May 07, 2021, 08:57:06 PM
post Re: The global semiconductor shortage...
May 07, 2021, 03:43:13 PM
post Ud 2.7 thru hole problems
WayneSeng
May 07, 2021, 07:05:41 AM
May 07, 2021, 12:40:33 AM
May 06, 2021, 07:03:25 PM
JCF
May 06, 2021, 04:04:09 PM
May 05, 2021, 10:30:49 PM
May 05, 2021, 10:13:16 PM
May 05, 2021, 08:29:59 PM
May 05, 2021, 07:03:25 PM
May 05, 2021, 06:57:17 PM
May 05, 2021, 06:38:06 PM
JCF
May 05, 2021, 06:02:21 PM
May 05, 2021, 04:51:47 PM
Rapy2
May 05, 2021, 01:03:30 PM
May 05, 2021, 12:21:48 PM
Rapy2
May 05, 2021, 11:17:11 AM
May 05, 2021, 11:04:35 AM
Miki_407
May 05, 2021, 09:47:58 AM
JCF
May 05, 2021, 09:40:40 AM
May 05, 2021, 12:01:57 AM
Miki_407
May 04, 2021, 09:48:43 PM
May 04, 2021, 09:02:34 PM
JCF
May 04, 2021, 07:17:08 PM
Rapy2
May 04, 2021, 11:19:14 AM
post Re: Flashover
May 04, 2021, 09:56:30 AM
May 04, 2021, 01:50:12 AM
post Flashover
May 04, 2021, 01:24:10 AM
Rapy2
May 04, 2021, 12:57:12 AM
Rapy2
May 04, 2021, 12:34:29 AM
kilovolt
May 03, 2021, 10:08:05 PM
SimonNwardUK
May 03, 2021, 10:07:26 PM
May 03, 2021, 09:38:30 PM
May 03, 2021, 07:29:14 PM
May 03, 2021, 06:20:47 PM
Rapy2
May 03, 2021, 04:02:39 PM
Rapy2
May 03, 2021, 01:19:51 PM
May 03, 2021, 12:43:48 PM
May 03, 2021, 08:16:19 AM
May 03, 2021, 08:14:37 AM
May 03, 2021, 04:18:29 AM
May 03, 2021, 04:16:35 AM
