Author Topic: BrOdin coil - High power Big sparks!  (Read 8614 times)
Re: BrOdin coil - insane racing sparks at 2000A OCD
« Reply #120 on: May 02, 2021, 06:03:41 AM »
It could be just the rectifier.  It could instead be that one or more IGBTs fried, which then fried the rectifier.  Unfortunately, that would be my guess.  Fried IGBTs likely have a collector-to-emitter short that you can measure with a meter.  If no IGBTs show as shorted, then I'd run the bridge at low voltage (say 5-50V) and scope the outputs.
Offline fh89
« Reply #121 on: May 02, 2021, 08:02:38 AM »
Just checked, no C->E shorts! Seems like I got lucky and it's just the rectifier!
The rectifier was only rated for 40A rms and I was pulling 180A+ even before upping the primary current, not only that, but after looking closely at it, the way I had it wired was not optimal, with all of the current going through a single diode pair instead of paralleling all 3 pairs like I should have! Kind of unreal that it didn't blow up before this! Just ordered the 100A version as a replacement.
« Last Edit: May 02, 2021, 08:30:40 AM by fh89 »
Re: BrOdin coil - High power Big sparks!
« Reply #122 on: May 02, 2021, 01:05:01 PM »
An interesting coil you got there. The combination of massive racing sparks together with only tiny topload breakout seems to imply, that the top load voltage can't alone be the source of the racing sparks. A much more likely cause is the voltage induced by the primary coil. The idea is, that there are 2 components to the magnetic field near the secondary. One component is the field caused by the current in the secondary. That field is pretty much constant along the secondary and causes a nearly linear voltage drop from the top down to the bottom.
The other field component is generated by the primary coil. That is localised around the bottom of the coil and causes an additional voltage drop there. The amount of voltage induced depends on the primary current and the geometry of the primary coil and its distance to the secondary.
The field of the primary coil drops off quite rapidly in the direction upward. The primary coil can be seen as a collection of rings, each one carrying the same current. The field of a single ring extends up to roughly its diameter, more precisely: The voltage induced in the region from the bottom to one diameter up the secondary will be about 90% of the total voltage induced along the complete secondary.
So there are two ways to avoid the induced voltage drop, which will cause the racing arcs.
1. Move the secondary away from the primary, i.e. up. The penalty for this is lower coupling.
2. Move the primary coil outward, i.e. make it larger and particularly avoid too small inner rings. That will cause the primary field to extend further up and will distribute the voltage stress along the secondary. There is also a coupling penalty, but it is less than solution 1.
You don't seem to have a large diameter primary, which possibly aggravates the arcing problem. But this just a guess and certainly a lot of work to change.
@davekni: The model implied by the above can be tackled almost analytically by calculating center fields of current rings. These are pretty simple. An even simpler model is a split of the secondary in 2 parts, one strongly coupled and the other not at all. Similar to a magnifier setup. I believe JavaTC obtains all these results but does not export them.
Offline Kizmo
« Reply #123 on: May 09, 2021, 11:53:35 AM »
That would be lucky indeed if only rectifier blew up.
Your currents and duty cycles are well within the region where i started killing CM600s
Offline fh89
« Reply #124 on: May 15, 2021, 06:47:43 AM »
Finally got my new rectifier (11 day shipping from 50 miles away, WTF USPS?) and we are back making huge, hot streamers!  It was only the rectifier that went boom.
I am not able to lift the coil onto the stand by myself, so had to run at ground level, limiting max spark length. Anyway here are some short vids. This is the same run shot from two different angles, one a gopro hero8 2.7k@60 and a note 8 at whatever max is.
« Last Edit: May 15, 2021, 07:10:57 AM by fh89 »
« Reply #125 on: May 15, 2021, 01:11:38 PM »
Have you tried touching the sparks at low power? At these high ontimes and low BPS it should not hurt. I would try to decrease the power so that it makes only a few inch sparks and try it. Imagine how cool would it be to touch so big streamers. But I guess that this hot plasma would burn your skin quickly.
Offline fh89
« Reply #126 on: May 15, 2021, 06:22:43 PM »
I understand the skin effect and have touched the output from much smaller coils, even up to 4' sparks, but at much lower power levels, say 1-2kW. Those sparks leave pinhole burns in the skin and hurt a moderate amount. Holding something metal in your hand can eliminate the pinhole burns, but it still gives a strong shock feeling.
 The thought of touching the output of this monster is quite frankly terrifying, even at low on-time and BPS because of the energy in the bus caps/primary. One mistake there and it's pink mist and closed-casket.
At full power, the sparks are lighting the dry grass on fire and melting my frame bolts, I don't want to go anywhere near them, even with a 10' chicken stick. Getting hit by one of those suckers may not kill you, but I'm guessing it's a massive understatement to say it won't feel very good!
On another note, I just ordered materials to build a 14x52 toroid. Hopefully stacking that on the 10x36 will get the topload to where it needs to be for maximum spark length!
« Last Edit: May 15, 2021, 08:13:01 PM by fh89 »
« Reply #127 on: May 16, 2021, 02:13:58 AM »
Great that it was just fried rectifier diodes!  Nice performance again.  Looks like there was a little left-to-right breeze.  If you can get that sort of breeze when the coil is higher (and eventually with a larger toroid), that would be great for stretching arc length.
Offline Kizmo
« Reply #128 on: May 19, 2021, 08:28:52 PM »
Total capacitance of large tesla coil is so large that sparks do hurt like hell no matter what the duty cycle is.
I have touched tiny sparks from my BiggerDR, it was not pleasant.
June 16, 2021, 08:54:32 PM
June 16, 2021, 08:00:50 PM
June 16, 2021, 05:40:40 PM
post Demo Coil Protection
June 16, 2021, 05:39:14 PM
June 16, 2021, 10:20:30 AM
June 16, 2021, 07:33:15 AM
June 15, 2021, 01:21:38 PM
Rapy2
June 15, 2021, 12:02:58 PM
June 15, 2021, 06:52:56 AM
June 15, 2021, 05:43:07 AM
June 15, 2021, 05:26:34 AM
June 15, 2021, 02:27:03 AM
Rapy2
June 14, 2021, 01:06:02 AM
June 14, 2021, 12:44:31 AM
Rapy2
June 14, 2021, 12:41:33 AM
Rapy2
June 14, 2021, 12:11:13 AM
June 13, 2021, 11:52:11 PM
Rapy2
June 13, 2021, 11:38:44 PM
Rapy2
June 13, 2021, 10:26:51 PM
June 13, 2021, 09:57:56 PM
Rapy2
June 13, 2021, 09:29:08 PM
June 13, 2021, 08:53:25 PM
Rapy2
June 13, 2021, 07:22:05 PM
June 13, 2021, 07:02:28 PM
June 13, 2021, 06:25:20 PM
Rapy2
June 13, 2021, 02:48:59 PM
gianpaolo
June 13, 2021, 12:00:09 PM
June 12, 2021, 07:28:03 PM
June 12, 2021, 07:23:12 PM
June 12, 2021, 12:24:06 PM
post Re: Nice PC Board Tesla
June 12, 2021, 10:06:18 AM
June 12, 2021, 10:01:29 AM
June 12, 2021, 08:47:08 AM
June 12, 2021, 07:03:10 AM
PEDRO HENRIQUE
June 12, 2021, 06:42:56 AM
June 12, 2021, 04:20:53 AM
post Re: SKM100 Mini DRSSTC
Willsmith001
June 11, 2021, 11:08:24 PM
Willsmith001
June 11, 2021, 11:07:00 PM
June 11, 2021, 12:33:55 PM
June 11, 2021, 12:03:24 PM
June 11, 2021, 06:47:52 AM
Power-Max
June 11, 2021, 06:32:02 AM
June 11, 2021, 05:16:03 AM
June 11, 2021, 04:53:50 AM
post Re: Why are SGT50T65FD1PN soo cheap on lcsc?
June 10, 2021, 11:51:17 PM
June 10, 2021, 09:52:59 PM
June 10, 2021, 09:16:25 PM
June 10, 2021, 08:19:40 PM
post Fujifilm PMT module PMT12A, reverse engineering
June 10, 2021, 08:05:27 PM
post Nice PC Board Tesla
June 10, 2021, 07:46:12 PM
