Author Topic: newbie question here... terminating non-household wires...  (Read 2585 times)
  • Guest
« on: September 03, 2019, 03:57:23 AM »
Id like to terminate un-needed wires from a low voltage 60hz transformer in side a fully closed UL case. i only find examples of in wall type 120V terminating with cap nuts. Wire connectors are left tied out of the way in computer and server cases all the time.
Wire nuts dont seem to be right in this application.
-Patrick
Re: newbie question here... terminating non-household wires...
« Reply #1 on: September 03, 2019, 04:14:06 AM »
Hi Patrick.
How about crimp caps?  Same as you would use for making a crimp-style insulated pigtail splice, but with only one wire.
A few years ago I helped a friend with some wiring on his boat.  Was told that no screw-on wire nuts are permitted in the code for on-board wiring.  Will guess that the wire contact pressure and plastic deformation are insufficient, when the connections are subject to wires moving around on top of temperature extremes and corrosive atmospheres.
Anybody ever see a wire nut in a car, other than by DIY-ers?  What do car audio installers use for field splices, for example a power tap?
Offline shrad
« Reply #2 on: September 03, 2019, 09:49:46 AM »
I usually bend the wire end and put a piece of heatshrink over it so that the wire end is kept inside the shrinked plastic, where no harm can really happen… you can also put a heatshrink piece two times the length, put the bent cable in the first half, selectively heat that end, twist the non shrunk end like a sock and bend it over to wrap the shrunk part and heat it to end up with a somewhat sealed end
« Reply #3 on: September 03, 2019, 09:59:39 AM »
Since you already have a UL standard enclosure, you should have a DIN-rail available to install some wire terminal blocks on and connect all the wires up to that, leaves it open for future use, its installed as all other wires according to standard.
Alternatively I would also use the heat shrink on each wire and bundle the unused stuff up around the transformer.
« Reply #4 on: September 03, 2019, 12:10:24 PM »
I second the crimp-cap idea, but have also seen the glue-lined heatshrink used on wires (especially with no stripped-copper exposed) - if you squish the empty end while hot it will tend to completely seal off due to the glue.
All that said, I have no idea what is acceptable from a regulations compliance standpoint, and I do know that things vary with jurisdiction (e.g. I wouldn't normally see or use wire nuts).
  • Guest
« Reply #5 on: September 10, 2019, 09:22:07 AM »
ok thanks all ill post pictures when i get the chance.
post Re: Big Coil Build Log
Today at 05:47:34 AM
post Re: capacitor and diodes. Voltage values for a CW
Today at 04:45:07 AM
Today at 04:18:27 AM
post Push Pull VTTC
janno288
Today at 01:10:08 AM
Alberto
March 27, 2024, 10:54:52 PM
markus
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
post Re: Is the UD2.7C under voltage lock out basically worthless?
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
markus
March 25, 2024, 02:06:41 PM
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
March 25, 2024, 12:47:09 AM
Alberto
March 24, 2024, 07:36:32 PM
Alberto
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
Alberto
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
Alberto
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
Alberto
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
Alberto
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
Alberto
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
Michelle_
March 17, 2024, 04:15:14 PM
Michelle_
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
post 2x Panasonic Inverter Microwaves - what to salvage, dangers?
Michelle_
March 17, 2024, 04:17:51 AM
post Where's all this voltage coming from?
March 17, 2024, 01:29:32 AM
March 17, 2024, 12:33:06 AM
March 16, 2024, 08:46:20 PM
post Re: Bleeder resistor for MMC
March 16, 2024, 08:39:24 PM
March 16, 2024, 08:21:44 PM
post Best forum for vacuum tube amplifiers?
March 16, 2024, 08:20:13 PM
