Author Topic: SSTC won't self-start  (Read 2318 times)
Offline ResonantEMF
« on: January 11, 2023, 03:19:31 AM »
I've built an SSTC using the circuit from Labcoatz's video. The way I built it is pretty much exactly the same but with irfp460 MOSFETs. And it works perfectly, I'm getting 6 inch arcs at 170v. But I need to hold my little slayer exciter wand near it to get it to start oscillating... I don't have much room in the base for a baby SSTC to get this running, so what can I do to troubleshoot this?
The schmitt triggers, driver, and interrupter are all healthy.
Another main difference is that I got impatient with the whole ground plane thing and just connected the base of the secondary directly to the antenna. I theorize that this might be the issue. I wonder if inverting the schmitt trigger might solve this and let me keep getting away with the direct secondary feedback. What do you think?
Re: SSTC won't self-start
« Reply #1 on: January 12, 2023, 03:56:33 AM »
With FETs instead of IGBTs, I'd recommend using a 1:1 GDT.  Can be made with much lower leakage inductance (by winding with two twisted pairs and paralleling one wire of each pair for primary).  Also reduces load on driver chip.
Feedback from secondary bottom is used by other coils (including my SSTC).  Secondary peak current is likely to be 1-2A.  A bit high for 1N4148 diodes even at low duty cycles.  Also can cause an issue of over-powering +5V supply.  Diodes feed current to +5V, more than circuitry consumes.  All designs I've seen using secondary feedback either use a current transformer (CT) or use high-power zener or TVS diodes to clamp voltage rather than clamping to +5V.  (Additional lower-power clamp to +5V may exist after series resistor limits current.)  If you decide to use a current transformer, clamping needs to be symmetric around 0V and/or AC-coupled before clamp.  Otherwise DC component of voltage will saturate CT core.
Good grounding is still necessary.  With secondary bottom feedback, grounding of logic supply negative rail becomes the most important.  At least connected to line ground.  Counterpoise is better.
Yes, polarity may need inverting when changing from antenna to secondary feedback.  This can be done by swapping GDT primary wires or SSTC primary wires or by adding an inverter stage.  You'll just need to try both polarities to see which works.
Adding bleed resistors across 0.82uF caps or across IGBTs can help with startup.  Makes sure that initial state of half-bridge output is centered so that initial half-cycle will generate some feedback.  A resistor across only one side can be better or worse depending on which IGBT turns on first, which is nondeterministic with this circuit.  My favorite fix is to add a resistor from HC14 pin 2 to far side of 1k resistor (junction of 1k and 0.1uF).  That keeps the HC14 toggling even when coil is off (between interrupter pulses).  There are some other threads here discussing this change.  Details for your case depend on what other changes you make first.
Good luck!
Offline ResonantEMF
« Reply #2 on: January 14, 2023, 03:06:42 AM »
Good luck!
Wow, this all sounds like great advice. I can see why adding that resistor to the HC14's pin 2 is your favorite, it sounds brilliant and I don't know why I didn't think of that myself. I'll give all that a try, thanks.
Offline MarcusFunt
« Reply #3 on: January 14, 2023, 05:19:44 PM »
Good luck!
use an antenna. Im pretty sure that will solve your problem
Today at 02:31:59 PM
Today at 02:30:10 PM
PhotonLab
post Re: Ramped DRSSTC
post Re: Lathe Restauration
Keybored
PhotonLab
PhotonLab
Luca c.
Keybored
PhotonLab
Keybored
post Re: TNY265 flyback issue
Lucasww
cnichols
post TNY265 flyback issue
michaelrcolton
post Re: How much power?
Terry
post Anyone used iCCFL.com?
Lucasww
post Re: SSTC bus inductance
post SSTC bus inductance
January 31, 2024, 11:43:32 PM
Ranni81
January 31, 2024, 08:03:40 PM
Hysteresis
January 31, 2024, 03:34:48 PM
January 31, 2024, 05:08:10 AM
January 30, 2024, 10:17:45 PM
post How much power?
Terry
January 30, 2024, 08:07:39 PM
post Ultrasonic Plastic Welding experiments with TA-40CS transducer
January 28, 2024, 11:37:30 PM
January 28, 2024, 03:07:12 AM
post Re: First time DRSSTC Build
January 27, 2024, 02:27:29 PM
January 27, 2024, 01:26:34 PM
post Re: Determine output voltage of DRSSTC
January 27, 2024, 01:15:51 PM
January 27, 2024, 01:13:29 PM
post Determine output voltage of DRSSTC
Pavol
January 27, 2024, 11:35:35 AM
post is there a standard pinout of optical audio output connectors?
January 27, 2024, 01:47:13 AM
January 26, 2024, 11:26:11 PM
January 26, 2024, 08:24:30 PM
January 26, 2024, 05:19:18 PM
post Re: Anyone had success using analogue/digital HV panel meters?
January 26, 2024, 04:28:38 PM
Luca c.
January 26, 2024, 03:34:10 PM
January 26, 2024, 11:49:48 AM
TizianoBll
January 26, 2024, 11:04:37 AM
January 26, 2024, 06:26:58 AM
