Author Topic: looking at building a second coil any reccomendations?  (Read 243 times)
Offline nzoomed
« on: January 11, 2023, 01:30:14 AM »
I built a DRSSTC about 8 years ago and have not done much with it lately until now, mostly because I could not use it at home without it annoying the neighbours.
I have however done a couple of public performances with it with great reception and have a friend who has a place I can operate it in front of visitors. I want to build something bigger with a bit more power this time.
Seems IGBTS are not only cheaper than before, but there is more to choose from.
Should I stay with CM300 series? Is there any particular part numbers that are better to go for nowdays? There are quite a few different variants in the CM300 series than I remember at the time.
Spec wise, how large a coil could I go for with CM300s? I need to dig up the specs for my coil, but at the time I think the MMC was only rated at 700 APK, possibly 800, will need to check.
I have been getting by with an 8A variac at 230V mains. Been using loneoceans UD 2.7 and have been getting streamers at least 2 metres long at full power.
Am i better going with higher rated IGBT's to make it more reliable such as CM600 and just operate at lower power?
Also looking at power requirements if I want to run 2 large coils together. Its difficult to run 2 of them if they are drawing 10A each at the wall outlet, that means I need to connect them to 2 individual outlets on a different circuit breaker.
Not sure now others are getting by when running multiple coils, do most people just turn the power down? Could I get a single variac and run 2 coils through it if the outlet can provide the power?
Re: looking at building a second coil any reccomendations?
« Reply #1 on: January 11, 2023, 10:44:49 AM »
I think you can find many of the answers in my DRSSTC design guide: https://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/ especially look at the IGBT article and check out the table at the bottom for IGBT brick alternatives.
Stay with CM300 bricks or similar like (SKM200-400) if you have nothing more than 230VAC 10A available. A CM600 coil can easily pull up to 20kW from 3 phase 400VAC.
I also have a lot of calculators to help you design: https://kaizerpowerelectronics.dk/calculators/
Offline nzoomed
« Reply #2 on: January 12, 2023, 12:36:36 AM »
Yes i have been looking at your page of builds. Quite a good amount of info, I loosley built my last coil based on loneoceans design, albeit a little less powered, but I could upgrade it to a higher power if i upgrade the MMC.
Basically from what I understand, you need to make the coil taller if you want longer streamers, or else they will strike the ground (and ring) more often?
I think I will stick with CM300, since I already have a pair of them on hand.
Whats the most power that you can put through a pair of these? From memory its around 1100APK?
I wouldnt mind making the next coil close to 2M in height, is this too unrealistic from a pair of these?
I can probably push my outlet to 20A peak if i had to, the fuse box has a 20A fuse on here, so it should be able to supply enough power, although I probably would only run at 15A max I think.
post Re: improving zvs driver
x-rayLamp
Today at 12:04:20 AM
post Re: ud 2.7c poped caps
January 29, 2023, 07:15:43 PM
January 29, 2023, 06:13:45 PM
Mike
January 29, 2023, 05:53:11 PM
post Please, help me (financially) build a DRSSTC
[Crowdfunding]
Pavol
January 29, 2023, 03:02:55 PM
post ud 2.7c poped caps
January 29, 2023, 02:04:59 PM
post Showa SP-103 Standalone Xray Head Teardown
January 29, 2023, 01:04:56 PM
January 29, 2023, 04:24:43 AM
January 29, 2023, 12:54:13 AM
post Re: Welding a MOT
January 28, 2023, 11:47:22 PM
January 28, 2023, 11:34:58 PM
January 28, 2023, 10:14:54 PM
January 28, 2023, 04:53:39 PM
January 28, 2023, 04:59:05 AM
post Re: First test of the SSTC
January 28, 2023, 04:44:51 AM
January 28, 2023, 04:35:22 AM
LoOdaK
January 28, 2023, 03:29:09 AM
January 27, 2023, 11:15:03 PM
January 27, 2023, 08:43:51 PM
January 27, 2023, 08:17:06 PM
January 27, 2023, 08:07:12 PM
January 27, 2023, 01:30:02 PM
x-rayLamp
January 27, 2023, 01:01:01 PM
post Re: Phase lead problems on ud2.7c
vince1
January 27, 2023, 12:49:46 PM
January 27, 2023, 06:07:49 AM
January 27, 2023, 05:22:46 AM
January 27, 2023, 05:10:14 AM
January 27, 2023, 05:05:40 AM
January 27, 2023, 04:44:24 AM
post Phase lead problems on ud2.7c
vince1
January 27, 2023, 01:26:20 AM
x-rayLamp
January 26, 2023, 08:13:24 PM
LoOdaK
January 26, 2023, 12:02:14 PM
January 26, 2023, 12:01:48 PM
post Re: Ramped SSTC - Power Supply Issues
January 26, 2023, 05:35:32 AM
January 26, 2023, 04:55:24 AM
January 26, 2023, 04:14:49 AM
January 26, 2023, 03:57:19 AM
January 26, 2023, 03:42:01 AM
January 25, 2023, 10:21:43 PM
post Welding a MOT
January 25, 2023, 09:37:27 PM
January 25, 2023, 09:36:22 PM
January 25, 2023, 08:35:49 PM
post improving zvs driver
x-rayLamp
January 25, 2023, 04:32:37 PM
nzoomed
January 25, 2023, 08:27:01 AM
January 25, 2023, 04:08:42 AM
January 24, 2023, 06:37:39 PM
January 24, 2023, 05:21:49 AM
post Re: 8 kW Induction Cooktop Teardown and Reverse engineering
January 24, 2023, 04:41:01 AM
post Ramped SSTC - Power Supply Question + General Improvements
January 23, 2023, 10:48:17 PM
January 23, 2023, 10:23:54 PM
post Re: 160mm DRSSTC project
Mathieu thm
January 23, 2023, 07:21:10 PM
January 23, 2023, 06:21:07 PM
January 23, 2023, 01:23:41 PM
January 22, 2023, 07:17:25 PM
LoOdaK
January 22, 2023, 12:53:01 PM
January 22, 2023, 06:21:40 AM
January 22, 2023, 04:45:46 AM
LoOdaK
January 21, 2023, 11:47:55 PM
post [WTS] (free except shipping) 115V 3600RPM sync. motor
January 21, 2023, 08:50:05 PM
January 21, 2023, 08:19:31 PM
LoOdaK
January 21, 2023, 03:01:21 PM
January 21, 2023, 05:44:15 AM
Avenger
January 21, 2023, 04:44:09 AM
LoOdaK
January 20, 2023, 10:52:40 PM
post Re: QCW questions
January 20, 2023, 06:20:32 AM
January 20, 2023, 06:03:20 AM
January 20, 2023, 04:49:50 AM
January 20, 2023, 04:19:23 AM
January 20, 2023, 03:12:39 AM
January 19, 2023, 11:39:37 PM
LoOdaK
January 19, 2023, 10:54:51 PM
Mathieu thm
January 19, 2023, 09:19:19 PM
January 19, 2023, 08:33:18 PM
January 19, 2023, 03:48:02 PM
LoOdaK
January 19, 2023, 11:09:39 AM
January 19, 2023, 04:30:49 AM
January 19, 2023, 03:10:56 AM
January 18, 2023, 08:23:57 PM
January 18, 2023, 08:13:28 PM
January 18, 2023, 05:56:11 PM
post Creating arcs off my variac lol, popped my igbts
breezetix
January 18, 2023, 08:24:15 AM
January 18, 2023, 06:40:30 AM
January 18, 2023, 06:29:45 AM
January 18, 2023, 04:56:33 AM
January 18, 2023, 04:39:55 AM
January 18, 2023, 04:27:49 AM
Mathieu thm
January 17, 2023, 11:16:00 PM
January 17, 2023, 09:37:16 PM
January 17, 2023, 05:38:24 PM
post Re: I need a review of my circuit. Polarities specifically
RoamingD
January 17, 2023, 03:35:47 PM
January 17, 2023, 12:43:26 PM
January 17, 2023, 07:51:05 AM
January 17, 2023, 07:02:37 AM
January 17, 2023, 05:41:59 AM
January 17, 2023, 05:41:38 AM
January 17, 2023, 05:06:24 AM
January 17, 2023, 05:04:21 AM
January 17, 2023, 04:41:26 AM
January 17, 2023, 04:35:36 AM
Avenger
January 17, 2023, 04:24:24 AM
